Hack to get ACR (CS6) / Lightroom to read D7100 raw files
Started Mar 17, 2013 | Discussions
Horshack Veteran Member • Posts: 8,739
Download exiftool for Windows or Mac. Run the following command line to hack a D7100 NEF to look like a D5200 NEF:
exiftool.exe -model="NIKON D5200" <nef filename>
For example:
exiftool.exe -model="NIKON D5200" myfile.NEF
By default exiftool will save your original file to a file with the same name but with "_original" appended to it. If you don't want exiftool to save the original, add the -overwrite_original option to it:
exiftool.exe -model="NIKON D5200" -overwrite_original myfile.NEF
Note that exiftool supports filename wildcards, so for example if you want to convert all the NEFs in a given directory:
exiftool.exe -model="NIKON D5200" -overwrite_original *.NEF
Special thanks to "theSuede" for the idea about hacking a D7100 NEF to look like a D5200 NEF.
Nikon D5200 Nikon D7100
Photo Exporter Regular Member • Posts: 188
Thanks, hope it works
My new bodies will be here Wednesday!
Only shoot RAW, was not looking forward to using NX
rockjano Senior Member • Posts: 2,653
Re: Hack to get ACR (CS6) / Lightroom to read D7100 raw files
Can someone explain to me line by line how to do it on a Mac
(with terminal of course but terminal is a strange animal for me
 rockjano's gear list:rockjano's gear list
Nikon D7200
OP Horshack Veteran Member • Posts: 8,739
Re: Thanks, hope it works
It does. Here's a D7100 NEF in CS6/ACR 7.3:
I don't have a Mac in front of me but it's the same cmd line I posted for Windows. You can probably drag 'n drop both the icon for exiftool (to start the command line, when you drop it I'm hoping it'll paste the path+name to the exiftool executable), type in the extra parameters, then drag 'n drop the D7100 file you want to convert to complete the command line.
inasir1971
inasir1971 Veteran Member • Posts: 4,071
For Macs
You can download "Exfitool" or similar. It is a paid App in the Appstore but can be downloaded as a demo through CNET - just google "Exiftool"
The entry "TIFF.Model" needs to be changed to "NIKON D5200" and Lightroom works fine with it (including lens corrections).
If stuck for sharpening values try something like 45,0.7,70,20 in Lightroom (so less sharpening - 45 instead of 60)
 inasir1971's gear list:inasir1971's gear list
Nikon Z6 Sony a6400 Sony a7C Sony a7 IV Nikon AF-S Nikkor 24mm f/1.4G ED +17 more
SverreE Contributing Member • Posts: 650
For example:
that's a very bad advice to overwrite original files and probably destroy them????
Sverre
 SverreE's gear list:SverreE's gear list
Olympus E-M1 III Canon EOS R5 Olympus Zuiko Digital 2.0x Teleconverter EC-20 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
Nepentanova Forum Member • Posts: 68
http://d7100.tumblr.com/post/45415740956/opening-d7100-raw-files-in-lightroom-mac
Nikonworks Senior Member • Posts: 2,202
For example:
If I have to do all this I'd rather go back to using film.
pagenine Forum Member • Posts: 92
How to undo?
Is there a way to put this back to the way it was?
I was seeing the preview images in LR4 before I did this, but now they're gone.
I have a bad feeling now.
Re: How to undo?
exiftool.exe -model="NIKON D7100" <nef filename>
Re: How to undo?
Thanks.
Fotaman New Member • Posts: 1
Horshack,
Nice tool however I am wondering if it is really as simple as that. I am awaiting my D7100 but I did a little test and converted a Nikon D90 NEF to a D80 NEF. The result opens in CS6 however due to the fact Camera Raw thinks it is a D80 file the result is completely off.
What is the impact of Camera Raw thinking a D7100 is a D5200 file? The result must me impacted to some degree, no?
Regards
Fotaman wrote:
Horshack,
Regards
The D90 and D80 have completely different sensors, sensor technology, and image dimensions, whereas the D5200 and D7100 have essentially identical sensors.
chrisncami Regular Member • Posts: 147
Forgive me, gents and ladies...I'm an idiot at command line stuff and never use Exiftool before.  I can't seem to get it to work on my Windows 7 PC.  I downloaded the program from CNET, put the exe on my desktop, and renamed it from exiftool(-k).exe to exiftool.exe.  I have a group of new D7100 files in a folder on my desktop.  Can someone please explain step-by-step how I batch all these files so they'll open in LR?  Thanks!
'Blessed are the flexible for they shall not get bent out of shape.'
GUI instructions
  1. Create a shortcut to the exiftool executable by right clicking on the executable and selecting "Create shortcut". Put the shortcut onto your desktop
  2. Right-click the shortcut and select "Properties". In the "Shortcut" tab, go to the Target field and add -model="NIKON D5200" after the executable (see screenshot below)
  3. Now all you need to do is drag your D7100 NEFs or a folder containing the NEFs to the shortcut and it will convert the files for you. It will save the original of any file(s) converted with the name "_original" appended to it, but I suggest backing up your originals somewhere else just in case.
Re: GUI instructions
VERY COOL!  Thank you!!!
EKP206 New Member • Posts: 1
This is awesome!  Thank you.  It worked like a charm but some of the RAW files are not populating and when I attempt to open them I get an error message reading "Could not complete the request because the file format module cannot parse the file."  Screen shot included.  Any thoughts?  Thanks again!
That's interesting, I haven't seen that. Any chance you can send me one of the unconverted D7100 NEFs that is giving you the error? You can use https://www.transferbigfiles.com/ to send the NEF to yourself and then post the link you receive here so I can download it.
Bruce Photography
Bruce Photography New Member • Posts: 11
That is quite a tool.  Are you aware of a tool that is Windows based that would allow you to look (but not maybe edit) raw files?  I noticed that this tool when it rewrote the files made the file 2 bytes shorter which I find disturbing.  It could mean nothing or it could mean quite a bit depending upon which two bytes were dropped.  Thanks again for the reference.
 Bruce Photography's gear list:Bruce Photography's gear list
Canon EOS 5D Mark II Canon EOS 7D Nikon D800 Nikon D800E Canon EOS 5D Mark III +32 more
