Old Nikkor 50mm/1.4 wide open horror
Started Mar 16, 2013 | Discussions
Sudo Nimh Regular Member • Posts: 281
I'd heard the pre-Ai 50mm/1.4 was "soft" wide open, but I wasn't expecting it to be unusable. It actually seems to focus sharply at all apertures, but at f/1.4 it seems to scatter light so that contrast is reduced and everything looks soft. It might be a desirable effect for portraits of aging actresses or other special subjects, but it's not optically good.
I took sample photos with an Olympus E-PL2. The sensor has a 2x crop factor, and I cropped the raw files further to get the central 1024x768 portion, on which I had focused. This is the top of a brush pile outdoors with overcast sunlight at the lens's 3 widest f-stops. These shots were taken on a tripod with a 2 second shutter delay and image stabilization turned off.
f/1.4
f/2
f/2.8
As you see, the milky distortion at f/1.4 is much reduced at f/2 and unnoticeable at f/2.8.
This is a mid-70s vintage, pre-Ai Nikkor 50mm/1.4. Do I have a bad copy of this lens? If this type of aberration is typical, does it have a name? Can anyone suggest any way to ameliorate it?
Olympus PEN E-PL2
jhinkey
jhinkey Senior Member • Posts: 2,814
Re: Old Nikkor 50mm/1.4 wide open horror
This is typical of old fast Nikkor glass in high contrast situations. They have a lot of residual spherical aberrations and not the best of coatings.
John
 jhinkey's gear list:jhinkey's gear list
Panasonic Lumix DMC-TS3 Panasonic LX100 Nikon D800 Sony a7R II Sony a7R III +27 more
Fave Photog Senior Member • Posts: 1,242
Pick up a copy of the 50/1.8 AI-S with a serial number between 2050340 and 2259472. It's an amazing lens even wide-open. Always use the deepest lens hood you can with every lens without causing vignetting.
The Five 'Ps' of Photography:
*Proper Planning Prevents Poor Performance!*
OP Sudo Nimh Regular Member • Posts: 281
Thanks, I'm relieved to hear that my copy is no worse than others.
inasir1971
inasir1971 Veteran Member • Posts: 3,708
If you're looking for a really good lens for use on MFT, the AF-S 50 1.8G (not the 1.8D) is one to look at. Very good performance wide open and nice bokeh - much better than my Ais 50/1.2 even on MFT.
The only catch is that you will need one of the adapters that allow operation of the aperture lever as the lens does not have an aperture ring but these can be had very cheaply on Ebay.
 inasir1971's gear list:inasir1971's gear list
Nikon D4 Nikon D850 Nikon Z6 Tamron 35-150mm F2.8-4
sunhorse Senior Member • Posts: 1,801
I never thought the lens was all that sharp. However, it made for a great portrait lens especially in available light.
Here is an old shot from the mid-70's with the 50 f1.4 (non-AI) on a Nikon F2 Photomic.
http://500px.com/photo/13394795
Ramesh
 sunhorse's gear list:sunhorse's gear list
Fujifilm XF10 Sony a6600 Sony E 18-135mm F3.5-5.6 OSS Carl Zeiss Biogon T* 2,8/28 ZM Sony E 10-18mm F4 OSS +2 more
Sergey_Green
Sergey_Green Forum Pro • Posts: 12,051
It is not the lens
Like most of the older lenses on a quarter of a sensor, you have way too much light in the chamber that is bouncing around without any real benefit to it. What you need to do is put the wafer on the back of the lens to cut this light of. I have seen the same results (as yours) with my own 50/1.4D on Olympus dSLR, and yet I saw less of it when I used the same lens on D200/300, and almost none on D800.
Look at this, faster lens, older, and many frames are wide open,
Nikkor ais 50mm f1.2 the fastes Nikon lens currently in production
Images by B.Leak.
- sergey
Neocon
Neocon Senior Member • Posts: 1,183
Re: It is not the lens
I found my 50mm f1.4 Nikkor (cica 1991) to be problematic shooting wide open.  It was rare for me to nail accurate focus.  Here is a lucky example when it works.  Taken with my D80 -
https://picasaweb.google.com/lh/pho
 Neocon's gear list:Neocon's gear list
Nikon AF-S Nikkor 70-200mm F4G ED VR Samyang AF 24mm F2.8 FE
Neocon
(unknown member) Veteran Member • Posts: 4,624
Re: Old Nikkor 50mm/1.4 wide open horror Nikkor-S 50MM 1.4 at 1.4 examples
Here are some quick examples with Nikon D300, SOOC of Nikkor-S 50mm 1.4 all shot at 1.4.
One indoors, without flash, one indoors with flash, one outdoors without flash and last (bag) indoors and flash. Seems sharp enough.
.....Just from an amateur......''Sometimes it's to your advantage for people to think you're crazy.” I am only a hoobyist, I cannot and do not give expert advice, dont expect it, just take it as a suggestion to think about, but only if you wish to. We should try to not wait for life to happen, while it passes us by.
CFynn Veteran Member • Posts: 5,224
On your MFT camera this is equiuvalent to about a 100mm lens on 35mm. So try using a lens hood for a 105 mm pre-Ai lens on your 50mm lens. That might ameliorate things.
 CFynn's gear list:CFynn's gear list
Fujifilm X10 Nikon D800E Nikon D850 Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 180mm f/2.8D ED-IF +14 more
That's a nice sample. I agree, the lens seems well suited for portraits. I expect I'll keep it for the deliberate soft focus wide open, and its sharpness at smaller apertures.
Neocon wrote:
https://picasaweb.google.com/lh/photo/PaTWuiINyYI9gNHsFDWfBdMTjNZETYmyPJy0liipFm0?feat=directlink
That's a nice shot. The lens will be worth keeping if I can get some portraits like that.
That's interesting. Can you get the "wafer" as an accessory to reduce light that falls outside the MFT sensor? I'm not sure this would help, though, because the softening appears very similar in dimly lit scenes that have less light bouncing around the chamber.
The wide-open images do look better than mine, but there's still softening or reduced contrast wide open. Compare the lettering on the baseball with f/2 and f/1.2.
I wonder if the softness seems worse on a crop sensor because it is magnified. It would be interesting to compare an image from a small-sensor camera with the cropped image (so that both images have the same view) of a full-frame camera. If the blurring looked similar, you would know that magnification was to blame, rather than reflections inside the camera.
BobSC Veteran Member • Posts: 4,440
That looks about like mine. I think it's mainly loss of contrast and light scatter due to the single coatings (as opposed to multicoating). If you go out and shoot at 1.4 in the full sun and look at the histograms they end up being bunched in the middle.
At 5.6 mine is sharper than the 18-55 kit lens at 5.6; more contrasty too, which is sad.
I recently bought a 50/1.4 AIs and I like it a lot.
Neocon
The point about a good lens shade is important.  I lost my lenshood and substituted a hood from a 135mm Rokkor.  With the cropped sensor of the DX camera, there was no vignetting.
Sergey_Green
Indeed
There is no such accessory. Someone just made a wafer out of paper on the Olympus forum once, and posted samples. The difference was enormous.
Because it is magnified, good point. But as I said I did try the very same lens on FT, APS-C, and FF, and on FT the results were the worst. I did not pixel-peep, just saw the same what you posted.
- sergey
primeshooter
primeshooter Veteran Member • Posts: 6,066
f/1.4
f/2
f/2.8
Nope, it's just poorly focused. Try contrast based LV for this, and get the exposure right. Both will help. The f/1.4 is badly over exposed.
Sergey_Green
Although you can attach many lenses to Olympus cameras, they can only be used in aperture priority mode, and the cameras tend to over-expose the images from wide open.
Here is Nikon 50/1.4 attached to Olympus @ wide open, notice the exposure compensation,
So it is about 2 stops to compensate. This funny haze is still present, although I do not see it anywhere in these quantities when the same lens is put in front of a larger sensor.
- sergey
It's not overexposed at all. Drop them into PS and look at the levels. What you see is flare.
