Unique lens
Started Nov 9, 2011 | User reviews
Felipe Rodríguez
Felipe Rodríguez Veteran Member • Posts: 3,302
Unique lens
5
Pros: Uniqueness, sharpness, overall image quality, build quality, lack of CA, lack of distortion, wideness.
Cons: Expensive, wideness (sometimes...), unprotected frontal element, no filters.
This is a truly unique lens: I'm glad Canon did it! With it, Canon shooters can achieve certain imagery that no other people using SRLs can...
The image quality is simply stunning. After using it, all my other TS-E lenses (the 24 Mk I and even the 45) seem lemons.
Of course, corner sharpness, if shifted/tilted, is not the same, but anyway the images are amazing.
It's very hard to hand hold the lens, even with an appropriate focus screen, but, well, any serious architectural work can hardly be done without a tripod...
 Felipe Rodríguez's gear list:Felipe Rodríguez's gear list
Nikon PC-E Nikkor 45mm f/2.8D ED Nikon Z7 II Nikon AF-S Teleconverter TC-17E II Nikon AF-S Nikkor 85mm F1.4G Sigma 35mm F1.4 DG HSM Art +13 more
Canon TS-E 17mm f/4L
Wideangle perspective control prime lens • Canon EF • 3553B002
Announced: Feb 18, 2009
Felipe Rodríguez's score
5.0
Average community score
4.8
havanna60 Senior Member • Posts: 1,640
Felipe Rodriguez: Canon TS-E 17mm/f4
Hi Felipe, I guess, today more Sony shooter use this lens that Canon; I think this lens is simply perfect on a Sony because of the number of advantages a Sony body gives: IBIS, focus peaking with magnification, 42M stunning image quality). Mine is on its way for my Sony A9. I used a Kipon Tilt-Shift adapter with a couple of Nikon-mount lenses on my mirrorless cameras, but now on the full-frame I decided to go for a dedicated TS lens.
When tilted corner sharpness goes away in most situation, that is normal. But, I'd expect (near) perfect sharpness for shifting.
Fortunately, today with the excellent focus peaking, and magnification combined, along with the IBIS in Sony full-frame cameras, I guess, handheld (fun/artistic) TS-E photography is possible, too. I fully agree, for architecture, where lines are terribly important, tripod is the way to use.
I am completely blown with your collection of tilt/shift photos you presented here http://www.felipe-rodriguez.com/Personal-Projects/Old-Seville/  Absolutely stunning.
Thank you for taking the time reading. I use DPReview as my photography/videography blog. If you like it, click Like, or leave some comments.
Have fun on http://www.flickr.com/photos/99398503@N07/sets
 havanna60's gear list:havanna60's gear list
Konica Minolta Maxxum 7D Nikon D700 Nikon 1 V1 Sony a7 Sony a5100 +9 more
Ed Rizk Veteran Member • Posts: 3,898
Re: Unique lens
Congratulations on your purchase of a truly great lens, Felipe.   I bought one recently and got a 6D to use it with.   It doubles as a 26mm tilt shift on my 60D, but is limited on it's shift range because of the built in flash.   I wonder if there is a practical way to remove the flash.
I do mostly architectural and landscape / cityscape photos, both for fun and for my real estate business as well as a few for other brokers.    I originally intended to use my 10-22 on the 60D for ordinary properties and the 17 for special shots, high end properties, or artistic shots.
Then I had a tripod accident with the 60D ad 10-22 and had to use the 17 for some ordinary property shots.   I got used to it after doing about a house and a half with it, and now it's not much more trouble to use at all.   The effect of the shift on basic interiors is dramatic.
I will fix the 10-22, but I may not use it as much.   As you said, using the 17 hand held is difficult.   Maybe I'll use it hand held more and get used to that, though.   There are times you want to walk throughout without a tripod and get snap shots of what you see but still need the width.
I looked at your shots where you used the tilt to affect the DOF.   Very interesting shots.  I have yet to use the tilt.   I shoot it on Av at f10 focused on infinity, and everything is sharp.
I like pretty pictures as much as the next guy, but I have to thoroughly document the properties I photograph, so I take some really mundane pictures.  As mundane as some rooms are, I want to make them look as good as I can.   Here is and example of what the 17 can do for the even the most mundane room in the house.
Better looking more complex rooms can hide the distortion, and unfortunately, I don't have two that are as similar.  Still the improvement is well worth the effort.
The quality of the photographs makes a big difference in the number of calls you get for the property.
Ed Rizk
 Ed Rizk's gear list:Ed Rizk's gear list
Canon EOS 6D Canon EOS R Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +4 more
Dan_168 Forum Pro • Posts: 11,055
Re: Unique lens
I agree, it's a pretty unique lens, I use it for both landscape and interior, mostly used on the A7R II these days, it works perfectly with the Metabones adapters. it doesn't really have a direct competitor until recently Nik0n came out with the PC 19 Tilt and shift, which I think it's even better, I will probably get one as well since I shoot with multiple systems.
I also have a TSE 24 II, in my opinion optically it's better than the 17, I use both  a lot.
Shooting T/S lenses handheld can be a little challenging with DSLR, it's much easier wtth the Mirrorless, but I still prefer to shoot on tripod no matter what platform I use, just because I am landscape guys and wants to maximize the quality output.
mmarian
mmarian Senior Member • Posts: 2,139
Re: Unique lens
When shooting interiors with ceiling downlights this lens is succeptible to flares. I always try to cover with hand the front element protecting it from any ceiling light shining directly at it.
Re: Unique lens
I haven''t noticed that, but I haven't had the lens long.
Ed Rizk
BlueRay2 Forum Pro • Posts: 14,816
Re: Unique lens
i agree with all points noted here, it is a bit too wide for landscape!
points i'd like to add are: seems too wide for landscape (i have noted above), steep learning curve, but luckily there are plenty teaching material can be found online! you really need to go out and try this lens on the field for days, especially huge buildings. Lee makes filter holder that is pretty wide and all other filter fit nice and tight. i have it but haven't used it yet. other manufacturers may have started to build filters as well, i am not sure though.
but...like i noted, one needs to take this lens out and practice a lot!!!!!!!!!
TS-E 24mm II is absolutely stunning for landscape and even portrait! the color it renders and micro contrast this lens produces are out of this world!!!!!
agreed!
mmarian
Re: Unique lens
I bought the lens straight away when it first became available and learned about this quirk the hard way.... Just take my word and be mindful of it...
Re: Unique lens
yes, depending on the light source and where you are point to, this can be a big issue, same for landscape, when the sun is in the " right" angle, the flare is crazy.
TGM1234 Contributing Member • Posts: 602
Re: Unique lens
I owned this this lens and sold it but there are times I have sellers remorse. I didn't find I used it too much but when I needed it (architecture), it was great.
www.tommarronphotography.com
 TGM1234's gear list:TGM1234's gear list
Sony a7R IV Sony a1 Canon EF 300mm f/2.8L IS II USM Sony FE 90mm F2.8 macro Sony 1.4x Teleconverter (2016) +12 more
mmarian
Re: Unique lens
In interior situation with multiple light sources, especially the bright ceiling downlights the situation can become very serious. The multiple bright flares of various colors and sizes can populate the entire frame and they can ruin your photo unless you would be prepared to spend time in PS trying to retouch them out which can be very tricky indeed. Try to schield the front element as much as possible without getting the shields in the frame, would be my advice.
Re: Unique lens
I guess one solution would be to turn the lights off.   Sometime I turn off most lights, or all if there are good windows, just to solve the problem of many different colored lights in the same room.    Of course you can't do that in a public place.
Ed Rizk
mmarian
Re: Unique lens
Ed Rizk
Or when photographing interiors at night with the ceiling lights being the main light source iluminating the room, which I do very often
HibikiTaisuna Junior Member • Posts: 30
Re: Unique lens
Hi Felipe, thanks for your review. I see that you now own the 19mm PC-E from Nikon. How do you think theses two compare? I want to get a Tilt Shift for my Z7 until something native is released by Nikon for the Z-mount and am wondering if it's worth to spend the extra money on the 19mm.
 HibikiTaisuna's gear list:HibikiTaisuna's gear list
Nikon Z7 Nikon Z9 Nikon 500mm F5.6E PF Sigma 28mm F1.4 DG HSM Nikon Z 24-70mm F2.8 +6 more
Eddie Rizk Senior Member • Posts: 1,224
Re: Unique lens
Since I was in this thread originally, under my old account, I feel qualified to comment.
Wider is better. If the Z-EF adapter allows you to control the aperture, get the TSE 17.
That's my opinion, and it's worth what you paid for it.
Eddie Rizk
The race is not always to the swift nor the battle to the strong, but that's the way to bet.
Formerly "Ed Rizk"
My email was hacked and unrecoverable along with all associated accounts, so I got permission to create a new one.
 Eddie Rizk's gear list:Eddie Rizk's gear list
Canon EOS R Canon EOS RP Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +3 more
yettercume New Member • Posts: 2
Re: Unique lens
Very expensive
 yettercume's gear list:yettercume's gear list
7artisans 35mm F2 Amazon Kindle Fire HD Wifi 7"
Sittatunga Veteran Member • Posts: 5,413
Re: Unique lens
Very expensive
Yes, but the 19mm f/4 PC Nikkor is £1000 more expensive.  None of these things are cheap and this one is rare second-hand.
mmarian
Re: Unique lens
From my personal experience from owing and using the 17 and 24 I'd say get the 24mm. I use it maybe 85% for interior and exterior architectural photography. The 17mm is reserved for tight spaces i.e. bathrooms where there is no room to step back and use the 24. The 17 has steep perspective and the distortion near edges can be a problem, so the shifting and composition need to be carefully considered. Also the 17 mm is prone to blooming when downlights hit the front bulging element. I try to shade it with cartboard or hand in such situations
Re: Unique lens
A lot of people shoot interiors with a 24.  I'm not that good.  I need 17.  I'm also obsessed with showing the general idea of a whole room in one shot and sometimes the relationship of several rooms to each other in one shot.
Eddie Rizk
Formerly "Ed Rizk"
Re: Unique lens
Very expensive
Not for what it is, my friend.  Many lenses cost more, but none can do what the TSE 17 does.
Eddie Rizk
Formerly "Ed Rizk"
