All ¨L¨ Lenses in One Package.
Started Dec 1, 2011 | User reviews
Chesapeake Imagery
Chesapeake Imagery Contributing Member • Posts: 605
Re: All ¨L¨ Lenses in One Package.
I shan't be remembered when I finally leave this mortal coil except perhaps if someone responds to my decade-old DP Review posts....
 Chesapeake Imagery's gear list:Chesapeake Imagery's gear list
Canon EOS R5
Herb Senior Member • Posts: 1,085
28-300 my walk around lens with 1DxIII w/RRS L bracket attached
Yup, it can be a load.  Took me a couple outings to get my wrist/forearm muscles used to swinging that sucker up for a shot.  I like it because of the range, I don’t like it because there are times I wished it was sharper.  That for me is the only drawback.  Well one more, it draws a lot of attention because of its size.  I have a lot of lenses in my bag of tricks to chose from.  My other walk around lens is my 24-105 f4.  That is a great lens for walking around except when I wished it had longer focal length.  It’s a world of compromises for sure!
Herb
 Herb's gear list:Herb's gear list
Canon EOS 5DS R Canon EOS-1D X Mark II Canon EF 24mm f/1.4L II USM Canon EF 50mm F1.4 USM Canon EF 85mm F1.2L II USM +8 more
And maybe not even then!
Herb
Chesapeake Imagery
at that point I guess I will be nothing more than "(unknown member)"
Canon EOS R5
Mike VanV Regular Member • Posts: 242
Re: All ¨L¨ lenses in one package, for...me
Na...
I sold my 28-300 when I found a 35-350L lens.
I found the 35-350 to be sharper (yeah, I'm a detail/sharpness snob) than the newer version.  The colors are the same, or as close as I can see, many of the other details are very close to the same, but the photo detail...the 28-300 can't match the 35-350.
The funny thing is, the 28-300 replaced...the old 35-350.  But...not in my book.
Mike
djphil Junior Member • Posts: 28
Mike VanV wrote:
Na...
Mike
For a "do it all" type lens 35mm is too narrow. That's probably why they went with 28 in the new version. For an amateur wildlife photography lens the 35-350 is probably better. But something like the Sigma 50-500 is now superior to both. For a general purpose lens the RF 24-240mm is better than all of the above.
Since the EF lenses are made to work on film cameras they're low distortion compared to mirrorless lenses so naturally, going super wide to super long results in some sacrifices.
Plus, we all know Canon hates poor amateur wildlife photographers...
bridge77 Contributing Member • Posts: 958
Re: High ISO limitation?
Jeff Peterman wrote:
I was a little disappointed using it at high ISO... it doesn't look ¨too¨ sharp as I expected to be an L lens of this price tag,
I must admit that your statement makes me question the whole review. Image quality due to the lens should be consistent across all ISOs - there really is no connection between the quality of the image leaving the rear of the lens and the camera ISO.
Now, the all-in-one lens is a little slow at longer focal lengths, and the slower aperture means you would need higher ISO. This is physical limitation of a lens covering such a wide focal length.
This may be better than average for a zoom covering such a wide range. But there is no way that it is optically as good as the newer L lenses covering narrower ranges. The main thing that makes this an L lens is the robustness and weather proofing, but I bet my cheap 55-250 STM lens is just as good optically over the 55-250mm range. (The STM lens is as good as my 70-200 f2.8L IS where there ranges overlap - except for the faster aperture, robustness, and weather sealing.)
is the 55-250 STM worth trading up for?  currently i use the 55-250 ll, the original lens that came out years before the STM.
thanks.
