Help Me Select: E-PM2 vs E-PL5 vs E-P3
Started Mar 12, 2013 | Discussions
NoTx Senior Member • Posts: 2,071
Hey all,
So life happened and I was forced to sell off all my cameras a few years ago. And I am now looking at getting back into photography. So, I was looking at the various systems, and it looks like I am going to go back to Olympus.
So, this time around I have a fairly tight budget as far as body (or I would be getting an OM-D), but in the end I want either a 25/1.4 or a 17/1.8 and a body… so I am limiting my targets.
There are three bodies I am looking at, all Olympus: E-PM2, E-PL5 and E-P3. These are all within a $150 range. What would your recommendations be?
Old cameras were E-1s, Leica M6TTL or Contax rangefinders. Prefer street photography and portraiture.
Thoughts? Comments?
Thanks!
Rob
Rob aka NoTx... -Film: Fuji GX680, Leica M6TTL, Contax G2, Contax G1 -Digital: Olympus E1 x2
 NoTx's gear list:NoTx's gear list
Panasonic Lumix DC-G9 Olympus M.Zuiko Digital 17mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic Leica 12-60mm F2.8-4.0 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
Olympus E-1 Olympus PEN E-P3 Olympus PEN E-PL5 Olympus PEN E-PM2
JCB123 Senior Member • Posts: 1,274
Re: Help Me Select: E-PM2 vs E-PL5 vs E-P3
NoTx wrote:
Hey all,
Thoughts? Comments?
Thanks!
Rob
I have an E-PL5. It has very good image quality (same sensor as the E-M5) and runs close to matching the IQ from my D7000. The AF is snappy and accurate. You can set a very small AF target. Not so good for continuous AF so you might need to work around that if you shoot moving subjects a lot. I bought mine with the kit lens and added a 40-150 to create a very light weight system that I can carry any distance. I also carry the 9-18mm and 20mm f1.7. The zooms are quite decent and the 20mm is excellent.
The E-PM2 again uses the same sensor as the E-M5 and should therefor have the same IQ. haven't used one though. The E-P3 uses an older sensor though and again I have not used one.
Regards
John
 JCB123's gear list:JCB123's gear list
Sony RX100 Nikon D90 Nikon D7000 Olympus PEN E-PL5 Nikon D7100
jalywol
jalywol Forum Pro • Posts: 12,302
NoTx wrote:
Hey all,
Thoughts? Comments?
Thanks!
Rob
The sensor in the EPM2 and EPL5 is substantially better than the one in the EP3.  If you want to save money, and can live without the flip-up LCD, the EPM2 is the way to go.  If you need the screen to flip for street shooting, than the EPL5 it is.
My suggestion:  Get the 25mm for portraiture (fabulous lens), and a cheap 14mm f2.5 from Ebay  (around $170) for street.  That should have you covered in budget, and you'll get superb IQ to boot.
-J
PGR streetshooter Contributing Member • Posts: 977
I'm the odd man out. I use 2 EP3's and couldn't be happier. The 25mm on 1 and the 24mm on the other. I have all the m43 lenses but just use these 2.
I'm just a streetshooter so I want a camera that gets out of my way.
The other guys are right about everything but I prefer the Pen3 cause it works like my M cameras.
Marla
Marla Veteran Member • Posts: 8,994
Difficult decision.  I think I would go for the E-P3.....
BTW, where can the E-P3 be purchased for $150?  Thanks!
Maria
 Marla's gear list:Marla's gear list
Panasonic Lumix DMC-GF1 Olympus PEN-F Panasonic Leica D Summilux Asph 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +1 more
I just his another Pen3 with the 17 2.8, a much underrated lens...new with shipping for $419.00.
What a steal....
OP NoTx Senior Member • Posts: 2,071
No, they are all in a range of $150.
E-P3 $450
E-PM2 $499
E-PL5 $599
Rob aka NoTx...
-Always searching
photofan1986
photofan1986 Veteran Member • Posts: 3,841
Well, I would pass on the EP3, as it uses the old sensor, and the difference with the new one is rather substantial. Also, I bought the EPM2 a couple of days ago, along with a PL 25 1.4 and a Panasonic 14 2.5 (second hand for a good price), and I must say that I've been very, very positively surprised by this camera. I was a bit concerned about ergonomics, but actually the camera is a breeze to use! I really loved the small size and all...BUT...a couple of days later, the shop where I bought the camera made a great deal on the OMD that I could not pass on, so I exchanged it. The OMD is the superior camera, but I sometimes miss the very compact and lightweight body of the EPM2.
On that note, I have to say that the 25 1.4 was quite front heavy on the EPM2. It balances well on the OMD though. On the other hand, the 14 2.5 is a perfect companion to the EPM2, as is the Panasonic 20 1.7. Actually, if I had to go with the EPM2 again, I would probably buy the 20 instead of the 25.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Sony a7R III Olympus E-M5 III Panasonic Lumix DMC-GM5 Olympus M.Zuiko Digital 45mm F1.8 +15 more
artzook
artzook New Member • Posts: 17
I have the E-p3 (with pana 14mm, Oly 45mm , Oly 40-150mm) and I like it.
E-pl5 is a very good choice to.
I did not like the e-pm2 menu as mush
Pierre
 artzook's gear list:artzook's gear list
Olympus OM-D E-M5 Apple iPhone 4
Jorginho Forum Pro • Posts: 15,370
I can't comment on the other two. I have an EPL5 and a GH2. I like the EPL5 a lot and it has better IQ than my GH2 which in itself is clearly better than my G1. Hence, if you shoot RAW, the EPL5 has much better IQ than the EP-3. However: a camera is more than just IQ of course. Good luck with your choice.
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +8 more
hindesite Veteran Member • Posts: 4,893
2nd hand E-P3
These are available quite cheap sometimes.
Don't worry about the sensor; it still produces results as good as it ever did, and the extra controls on the PENs make them easier to use.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
E-PL5 naturally
6
I have E-PL1, E-P3 and E-PL5.
Though the E-P3 feels a nice camera to use and does have that extra Fn button plus the thumbwheel, it's the E-PL5 that gets 99.999999% of the shots in my hands.
Better image quality, better focus in low light, bend up/down LCD, ability to use OIS of unswitched OIS Pana lenses, and my total favourite feature = ability to assign MySets to any Mode spots - suddenly MySets are extremely useful.
Those features plus the results that I get make it the best of the Oly cameras at present, even better & more useful than the E-M5 to use. OK the IBIS is old but who needs that all the time? The better high ISO ability compared to the old sensor makes the need for IBIS less anyway.
I see that I will get rid of the E-PL1 and E-P3 and get a second E-PL5 body and then wait it out until global shutters become available.
My pages slowly growing on E-PL5 info.
Regards.... Guy
Tapper123
Tapper123 Senior Member • Posts: 1,934
I probably shouldn't comment since I don't own any of those cameras, but to me the EPL5 would be the most attractive. Same sensor as OMD, and the folding screen IMO is a huge advantage for any camera, especially for street which you are interested in. Plus I think you can also add an EVF if desired? Nice option there.
I just ordered an OMD EM5 today in fact, but EPL5 is extremely attractive if small size and lower price is more important than weather sealing, EVF and the fancy IS.
 Tapper123's gear list:Tapper123's gear list
Sony RX100 III Sony Alpha NEX-F3 Olympus E-M5 II Olympus E-M1 III Olympus 12-40mm F2.8 Pro +7 more
Sergey Borachev Veteran Member • Posts: 5,338
Hi, I have been through some of the same things, having sold my previous cameras, coming back, and being constrained in budget too, among other things that come with age.
I researched for about a whole year, before making my decision and I believe I can help. I studied all these cameras, and also some other alternatives like the NEXes and I think the E-PL5 is the best small interchangeable camera on a budget at this time unless there are very special requirements. IMO, there is no reason to consider the E-P3, due to a huge improvement in the sensor available to Olympus since that camera - a fact well reported and tested. The E-P3 (and also all the Olympus cameras) before the E-M5 is known for relatively poor IQ, especially high ISO performance and DR performance, compared to others. The important question here is whether that its IQ is adequate for you. For most it is not. While there are many things you can do to get better quality in your photos with the E-P3 (and even excellent pictures given the right conditions and using all the tricks in the book), life will be a lot easier with the new E-M5 sensor. You will be able to do a lot more in cropping, in post processing, to salvage a shot, to get special effect, etc with the great 16MP E-M5 sensor in the E-PL5 or E-PM2.
While on a budget, often it is tempting to cut corners that could result in long-term grief and hence come out worse off. For a student or young person, with expectations of more income and continued accumulation of wealth, it is fine and a budget camera can be replaced soon. If that is not you, and you think you want to use this camera for a number of years, it is more important to think about TCO, total cost of ownership, over those years because you don't want to have to upgrade. The E-PM2 is a bit basic and can take away some enjoyment in this hobby. The E-PL5 has the same capability in terms of photographic functions, but the user interface and features that help you capture the photos successfully and easily are important.
So, I recommend the E-PL5, given the small difference in cost. I myself bought the E-M5, upgrading from the E-PL3, which is a very nice little camera that does everything except delivering the IQ I wanted. The E-PL5 should be very similar, but has the E-M5's sensor and therefore IQ. Putting a highly regarded sensor in the flagship model in value cameras is very rare in cameraland. I think you should take advantage of that and forget the E-P3. Consider carefully, and consider also all your requirements, and the consequences long term. Good luck.
reggieandtfe Regular Member • Posts: 238
I'd go with the E-PL5 with the 17 mm f/1.8.
The 25mm is a great lens but doesn't balance well on those bodies (well it might be OK on an E-P3) and I got sick of constantly dealing with the CA.
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
E-PL5 wins hands down; but what about the Panny G5?
hi Rob
I went through similar questioning when i was moving from the G1 (my first digital interchangeable lens camera) year or so ago.
I bought the E-PM1 for lightness, got some great results and found it just a little unhandy, upgraded to the E-PL3 and found it to be an excellent camera.
The E-P3 just wasn't what I wanted on account of weight and size and the fixed screen (one of my reasons for moving up from the E-PM1).
Now you have the E-PL5 with vastly improved IQ -- vastly improved over the E-P3, E-PM1, and E-PL3, all of which had the same sensor.
The bit extra the E-PL5 costs over the E-PM2 is well worth it in my opinion for better control; and they are BOTH superior to the E-P3 for IQ.
But what about the Panny G5? That's my current front runner in the upgrade stakes. I shoot nearly all the time using the VF2 accessory eye level viewfinder on the E-PL3, so I am looking at the G5 with interest. It's REAL dimensions when fitted with a lens are fractionally SMALLER than my "little" E-PL3 with lens plus VF2, and it has ergonomics that are streets ahead and a built-in pop-up flash for fill in and family snaps.
Cheers, geoff
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital 45mm F1.8 Panasonic 12-35mm F2.8 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +7 more
rrr_hhh Veteran Member • Posts: 6,024
NoTx wrote:
Hey all,
Thoughts? Comments?
Thanks!
E-Pl5 : has a much better sensor than the E-P3. Has a fillip up LCD which is a dream for street photography : you can use it at waist level touch the display to focus where you want.. Or even touch the display to focus and shoot in one single gesture.
rrr_hhh
 rrr_hhh's gear list:rrr_hhh's gear list
Sony a7R Olympus OM-D E-M5 Canon EOS 6D Olympus E-M5 II Sony a7R IIIA +15 more
Ulfric M Douglas Veteran Member • Posts: 4,828
Re: E-PL5 naturally
Guy Parsons wrote:
... bend up/down LCD, ability to use OIS of unswitched OIS Pana lenses, and my total favourite feature = ability to assign MySets to any Mode spots - suddenly MySets are extremely useful....
This. e-pL5
Flip LCD, MySets on mode dial, excellent low-light results.
sigala1 Veteran Member • Posts: 3,911
Don't buy E-P3
The E-P3 has an ancient sensor that's no better than a modern small sensor camera like a Panasonic LX7.
E-PM2 and E-PL5 are identical cameras except the latter has a tilting LCD, a mode dial (not really needed at all unless you switch modes all the time) is slightly bigger and heavier to account for the tilting LCD.
purpleray Senior Member • Posts: 1,261
Re: Don't buy E-P3
While I agree the E-PL5 has the latest sensor and thus makes sense, I'm not sure the E-P3 would be out of bounds because of IQ - or because of low light capability and DR.
I have an E5 with the same sensor as the EP3 (but an older processor) and the OMD with the same sensor as the Epl-5.  While the OMD is better, it is probably only glaringly better if you look really closely.
The community opera I shoot has very low light and high DR - and because I choose to shoot a wide FOV to record the whole scene, it is very challenging for any camera or photographer.
Here is a jpeg straight out of the camera - shot from probably the first E5 sold in Australia a couple of years ago.
Carmen - the Gang jpeg OOC
Here is the same shot using Archgeolab's preset for LR4 to process the raw file with very minimal other PP.  So, with raw you can do quite well with the old processor.
Carmen - Gang Archgeolab preset from raw
So while, I think the Epl5 sensor is better, the old EP3 is not so bad you can't take a reasonable shot and get respectable results.
Cheers
Ray
