Pls colour-correct this
Started Mar 1, 2013 | Discussions
akkers5 Regular Member • Posts: 212
Can anyone colour-correct this image to bring out natural colours, please. Instructions/settings will be appreciated.
Allen Gerdes Veteran Member • Posts: 5,635
Re: Pls colour-correct this
Not sure if this is accujrate or too saturated, but here is my version:
Regards....Allen
charleyd Senior Member • Posts: 1,103
my try. in Photoscape; Backlight, Contrast low, Deepen.
Pixel Poetry
Pixel Poetry Veteran Member • Posts: 5,588
 Pixel Poetry's gear list:Pixel Poetry's gear list
Canon EOS 550D Canon EF 50mm f/1.8 II Tamron SP AF 90mm F/2.8 Di Macro Canon EF-S 18-55mm f/3.5-5.6 IS II
ArtMar Contributing Member • Posts: 548
Adjustment in LAB space; Topaz Dejeg; Perfect Effects brush.
Adjustment in LAB space; Topaz Dejpeg; Perfect Effects
mikes
mikes Veteran Member • Posts: 3,421
Color by Corel. Color is very subjective to an individual BTW. What is right on one screen may be wrong on another. Is your equipment calibrated? I adjusted this with Corel to warm it up a bit and enhance the yellow/green detail in the mountains. A bit o' sharpening and  contrast, that's it.
Only when you can criticize yourself, should you criticize others. Mikes.
Michael Edward Rudge Veteran Member • Posts: 7,073
Re: Hope you like my Play
 Michael Edward Rudge's gear list:Michael Edward Rudge's gear list
Canon EOS 60D Canon EF 50mm f/1.8 STM Canon Pixma MG5350
Greg.
Greg. Senior Member • Posts: 1,144
Greg.
Twilight35 Senior Member • Posts: 1,038
What software program are you using? If it's Photoshop, try this.
Photoshop Work Flow With Lab Color
  1. Bring up picture in Photoshop
  2. Go to Image _Duplicate
  3. Go to Image _ Mode _ Lab Color
  4. Create a new adjustment layer and click on Curves
  5. To create a 100 square dialog box, Alt-Click in the dialog box
  6. Click on the “a” channel
  7. Move the bottom point 1 to2 squares right and the top point 1 to 2 squares left
  8. Click on the “b” channel and do the same as you did for “a” and click OK
  9. Go to Image _ Mode _RGB
  10. Go to Image _ Adjustments _ Levels
  11. Going through the Channels, “R”, “G”, “B”, move the End Sliders to the Mountains if necessary and adjust the Middle Slider until you get the color and lightness that suits you and click OK.
If you’re used to duplicating your background layer after coming out of #1 and not using #2 click “Don’t Merge” after coming out of #3 and click “Merge” after coming out of #9.
Personally, I like to use #2 so I have a copy on my window to compare my work to as I go along.
This is experimentation for you or anyone else. Just remember, "You have to make yourself happy".
Just because a famous photographer "Just Loves" the color in picture XXX, doesn't mean "YOU" have to like it.
I hope this helps.
Fred
imabel Contributing Member • Posts: 891
My try with Photo Ninja.
benross Senior Member • Posts: 1,004
Here's my take.
Done with Aperture.
I manually set WB to 4500 K. WB reading off the snow was warmer but I tend to make it cooler in the shadow. Here is the rest of adjustments:
OP akkers5 Regular Member • Posts: 212
Many thanks to all who took time to help me out.
Actually I took this photo (and many others) in Neelum Valley of Kashmir in 2005 on an early Nikon DSLR which was not so good on white balance. Even though this day was very hazy with fairly bad weather, the other pics on different days had a warm tendency as well. I was not trying to get a particular look, its just  that this photo and others do not reflect what I saw there with my own eyes.
The Nikon gave me no end of grief and eventually I got rid of it after paying £160+ for a mirror repair. That was my nightmare with a camera for which I paid £1500 at the time. Jumped ship to Cannon after that.
My monitor is calbirated with a Spyder.
Again. thanks to all.
