Is Canon EF-S 18-135 STM lens too soft in large apertures?
Started Feb 28, 2013 | Questions
massud New Member • Posts: 6
Please look at the following side-by-side comparison of exposures of my 18-135 STM lens in two different apertures (100x100 crop). As you can see, it is too soft in f/3.5 (the largest available aperture). I repeated this test with different focal lengths (50mm and 135mm) and images taken with the largest apertures are always too soft. I could not find any review/sample image on internet that confirms such a big difference in sharpness. Is this normal?
Left: 18mm f/3.5 1/100 Sec. Right: 18mm f/5.0 1/50 Sec.
biza43 Forum Pro • Posts: 15,074
Re: Is Canon EF-S 18-135 STM lens too soft in large apertures?
Yes, such zoom lenses are always softer wide open. But unless you print really big, you will not see it in prints.
www.paulobizarro.com
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
saisai Junior Member • Posts: 38
Yes, it is soft. The sony DT 18-135 SAM is much sharper than the canon's.
maarensv
maarensv Senior Member • Posts: 1,106
I'd be surprised if Sony's 18-135 is much better than the 18-135 STM. That would make it the first decent performing basis Sony lens.
Do not expect any lens in this class to be perfect wide open. From my short experience with the STM I found it to be quite capable though, definitely better than the non-STM 18-135. Fairly decent centre and not to bad corners either. Stopping down did help to improve sharpness, but mainly on the edges and in the corners.
If I were you I'd try to make some pictures with contrast detect focus, which means in live view mode. In that case you rule out focus errors (front or back focus). Compare the shots again after doing so.
Regards, Sandor.
 maarensv's gear list:maarensv's gear list
Canon 6D Mark II Canon EOS R Olympus E-M5 III Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM +22 more
OP massud New Member • Posts: 6
Regards, Sandor.
Thanks for your information. I have never had a non-STM 18-135 but my 18-135 STM is much softer than my 18-55 IS II lens kit wide open.
Below photos are taken in live view mode. Still it seems too soft in large apertures.
Left: 18mm f/3.5    Right: 18mm f/5
maarensv
Are those centre, edge or corner crops ?
center
maarensv
massud wrote:
center
OK, I expect those to be better than the samples you showed.
On the other hand, how many pictures do you take with aperture wide open ?
You showed only 18mm shots. How about the mid and tele FL ?
Regards, Sandor.
maarensv wrote:
massud wrote:
center
Regards, Sandor.
I have taken more than 50 sample shots in different focal lengths. Always same results. Here are two more samples in 50mm and 135mm.
50mm f/5
135mm f/5.6
photonius Veteran Member • Posts: 6,895
massud wrote:
maarensv wrote:
massud wrote:
center
Regards, Sandor.
50mm f/5
135mm f/5.6
the 135mm is almost sharper than the 50mm, should be the other way round.
I presume you did live-view focusing with 10x.
It does look like your lens is softer than expect from e.g. photozone tests
http://www.photozone.de/canon-eos/776-canon_18135_3556stmis?start=1
i.e. at 18mm in the center, it should already be quite sharp.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
maarensv
From my (short) experience I think both wide and tele should have been sharp in the centre wide open. Photozones test corresponds with that. It looks to me that your 18-135 STM is under par.
Regards, Sandor.
Regards, Sandor.
Thanks. What a disappointment. Can this be a lens calibration issue?
maarensv
Don't really know, but doubt it that calibration is the issue.
Maybe you can try another copy of the 18-135 somewhere ?
Regards, Sandor.
Regards, Sandor.
in the first (18mm) image it looks like the focus could be behind the branch.
but you said you did life-view focusing at 10x (on tripod and 10 sec timer or remote ??) so front or back-focusing should not be an issue?
Regards, Sandor.
As you said, the photo was taken in live view mode on a tripod. I am pretty sure it's not a focus issue. I tested the lens using a focus test pattern (45 degree) and there is no sharp area in the photo. Also, turning IS off did not help.
Timbukto Veteran Member • Posts: 4,988
You might have a poor copy.  Take a look at my 85mm 1.8 prime shots (I don't own a single zoom lens except on MFT currently because I got tired of finding *good* quality zooms).
My wide open f1.8 shots do not degrade as much from f1.8 to f4.0 and that is saying a whole lot.  It only sharpens up significantly in extreme corners of FF area.
 Timbukto's gear list:Timbukto's gear list
Canon EOS M Canon EF 200mm f/2.8L II USM Canon EF-M 22mm f/2 STM
Regards, Sandor.
hmm, you should try another copy then.
Perfecturenist New Member • Posts: 9
I just bought Canon 70D with 18-135 STM (Kit)
Guess what, I did extensive experiments and here is what I concluded:
18mm - Horrendous front focusing issue.
Gradually reduces to almost none by 100mm.
Micro Focus adjustment that seem to fix it:
Wide: +5
Tele: 0
Try taking a picture with 18mm in room with objects in range approx 3 ft. all the way to 14 ft.
Focus (Use single center focus only) on farthest object.
Viola!! The image focuses best on the object that is close to you. It sounds ridiculous but almost 4-5 ft object is in focus.
SHAME on Canon!!!!
Did I say S..H..A..M..E... on Canon !!!!!!!!!
Why? Because I might be ok to live with this Microfocus Adjustment only if it worked in all modes.
No, it does not work in any "Auto" mode. Only works in P,Tv,Av,M Modes.
Guess what, the kit is going back!!
To my previous post, there some correction:
With all shooting conditions (mainly distance from object), it seems that the adjustment needed is more than what I previously quoted, it is more like:
Wide: +10
Tele: 0
My other less expensive lens is fine on the same camera.
Correction to my previous post:
It takes quite a few measurements and fine tuning to come up with exact correction for micro focus.
I settled for more like +7-8 not +5 as I mentioned earlier.
