menu in dimage A2
Started Feb 27, 2013 | Questions
Sketchley New Member • Posts: 1
menu in dimage A2
My Dimage A2 problem. The menu will not move up or down or left or right.
How do I fix this?
Thanks Walter
Jim N'AZ Veteran Member • Posts: 7,595
Re: menu in dimage A2
Walter, Do you mean this menu will not move via the four-way controller?
The only thing I can think is that the four-way controller is stuck/jammed in some way. Have you tried manipulating the four arrows rapidly and/or eyeballing the four arrows to see if one or more is depressed more than the others?
Regards, Jim
How do I fix this?
Thanks Walter
Barrie Davis
Barrie Davis Forum Pro • Posts: 21,460
If the 4-way is not functioning correctly, I'm pretty sure there would be other symptoms... the fault would not be confined to menu navigation only, I am thinking...[??] The extent of the problem is something that can be tested with the camera in other modes.
Suggestion......
Maybe the camera firmware has become confused, and is not following instructions correctly...[??] This does happen sometimes. A camera reset, followed by a cold boot procedure, will usually fix this.
Cold Boot: Following reset, take the battery out and leave it out for 30-40 minutes, then replace and switch on. (Good Luck!)
Otherwise, all I can suggest is to exercise the 4-way with repeated pressings, say, by 'grinding' your thumb round in a circular motion. If the problem is caused by switches that are not giving positive connection, using them repeatedly will tend to clean them.
If I have not been using them, I take my A2 cameras out every week or so and give their switches and systems a little gentle exercise. I think it helps.
But if the switches are worn out, well, that is a bigger problem....This camera is now considered a very old model, and the manufacturer is not even in the camera business anymore.
Baz
"Ahh... But the thing is, these guys were no ORDINARY time travellers!"
 Barrie Davis's gear list:Barrie Davis's gear list
Konica Minolta DiMAGE A2
