Help with Lightroom 4....Please
Started Feb 25, 2013 | Discussions
Dr Hal Senior Member • Posts: 1,182
When I bought Lightroom 4, I bought Scott Kelby's book for my Kindle and it has helped me very much and I really like using Lightroom.  I am having one HUGE problem that I am ashamed to admit but I cannot find the answer.  I import my files into Lightroom and store them in files on a hard disc just as Scott Kelby said and I can find the files with no problem.  The problem is:  I cannot get the files back into Lightroom again to use them if I want to go back and work on a file that has been previously imported back into my Lightroom program to adjust.  I just get a message that the file has been previously imported into Lightroom.  How do I get a file that I have previously imported back into my Lightroom so that I can make further adjustments on it?  I know that it is something simple but I just cannot find it and I have spent hours looking through Kelby's book.
Thank you for your help.
Hal
 Dr Hal's gear list:Dr Hal's gear list
Sigma dp2 Quattro Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +4 more
richarddd
richarddd Senior Member • Posts: 2,995
Re: Help with Lightroom 4....Please
If you've imported it once, it should still be there unless you've deleted it.
Go to the Library, look at the left pane (click the little triangle on the middle of the left edge if it's not visible) and click on "All Photographs" under Catalog near the top. What happens?
When you import, LR only shows you a grid of those newly imported files unless you tell it to show you older files. That's likely why you're not seeing the old photos.
 richarddd's gear list:richarddd's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 UMC Fisheye MFT +3 more
RedFox88 Forum Pro • Posts: 27,555
unclear
It's unclear what  you are actually doing.  It ​sounds​ like you are trying to double click a photo file or drag a photo file into lightroom.  Simply open Lightroom and navigate to your drive and folder and then you'll see the photos from that folder that are in Lightroom while in "library" view.
Dan Marchant Senior Member • Posts: 2,793
+1 to what Richard said. You don't need to import again as it is already imported. You just need to locate the image using the navigation pane as Richard describes. Exactly where the image is (thus where you need to look for it) will depend on what settings you used when you imported it.
Dan
I love my girlfriend, my dog and my canon 5DIII - even though none of them ever do what I tell them
I am learning photo graphee - see the results at www.danmarchant.com
 Dan Marchant's gear list:Dan Marchant's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +1 more
William Porter Senior Member • Posts: 1,676
Hal,
+1 to what's already been said: if you've imported the files into Lightroom, they're still there. I have only a couple extra comments.
The key thing with Lightroom is to realize that, once you've imported files into it, you need henceforth to use it as your file manager. If you want to find a file and open it, don't do it in the Mac OS X Finder or Windows Explorer: get into Lightroom first, and use the browser in the library. To view and edit a file that's been imported, start in Lightroom, find the file and just select it.
I find it not just useful but pretty near essential to organize my photos by date taken. Lightroom understands this method of organization, and it's based on something absolute (date taken) not something squishy like content or project or whatever. Basic organization by date looks like this (these are folders):
2012
2012-12-30
2012-12-31
2013
2013-01-01
2013-01-02
etc
If I import from an SD card, Lightroom is able to parse the files out into the right folders for me.
Final note: One thing that will cause you problems is moving or renaming a folder (or an image file) on the computer using the computer's filing system rather than Lightroom. That's why I say, once the files are indexed in Lightroom's database, use Lightroom as your asset manager, even if you use another program to process them (as I sometimes do).
Will
 William Porter's gear list:William Porter's gear list
Panasonic Lumix DMC-LX7 Olympus E-M1 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +7 more
OP Dr Hal Senior Member • Posts: 1,182
Thank you
I am at work right now and cannot wait to get home to put your suggestions to work.  I really appreciate the help and hope that someday I will be able to help you.
Hal
Re: Thank you
I use the same system as Will. I import images using a card reader and have the Lightroom import defaults set to put the images in their own folder based on the date which is in turn inside a year folder. However I then usually rename the folder to add a subject or location (EG "2013-01-11 Rugby" or "2013-02-06 Hong Kong") just to provide extra detail when browsing folders.
I then tag all my photos making it much easier to search for them later.
Dan
chkproductions
chkproductions Senior Member • Posts: 1,104
Hal
I'm going to come at this from another angle.  When I read as written above, "The problem is...." it seems to me your'e trying to work on an image file you've already worked on and either make more adjustments to it or start making new adjustments from scratch, but without changing the one you've already worked on.  If that's the case (and I may be wrong here) then right click on the image you want to work on, and down the list is Create Virtual Copy.  A copy will be made and a little page turn symbol will appear in the lower left of the image to show it's a copy.  Click on the Develop module and either make further adjustment or click Reset and clear all the adjustments you've made and start from scratch.  In order for it to be a real and virtual file, you would have to export it in the file type of your choice.
I'm not sure if this is what you were asking.
Cirrus888
Cirrus888 Forum Member • Posts: 63
I had a similar problem. Did you untick the "don't import suspected duplicates box" . it is default to checked.
 Cirrus888's gear list:Cirrus888's gear list
Olympus PEN E-PL2 Nikon D800 Olympus PEN E-P5 Nikon D750 Olympus E-M5 II +6 more
