How prevalent is the lens error with the G12?
Started Feb 25, 2013 | Questions
SUE O''''''''''''''''''''''''''''''''BRIEN
SUE O''''''''''''''''''''''''''''''''BRIEN Contributing Member • Posts: 927
I've had a couple G12's and upgraded to the G15 but too many pictures were soft with the G15. I decided to buy another G12 and just read about the lens error and that the whole mechanism has to be replaced. There is actually a guy on EBay doing this for $35 and how I first heard about it and then researched the problem on the WEB. I didn't have any problem with mine or my G9 or G10. The mechanism has been changed on the G15 so it won't happen on that model.  Any help will be appreciated.
Canon PowerShot G12 Canon PowerShot G15 Canon PowerShot G9
B1ackhat Senior Member • Posts: 1,980
Re: How prevalent is the lens error with the G12?
This is the first I've ever heard of it and I frequent several photog forums, so I'm betting it's not common at all.
"We can judge the heart of a man by his treatment of animals." ~ Immanual Kant
Norman B Regular Member • Posts: 300
I have a G12 and no lens problems. That is even after it accidently banging it into a chair with the lens extended. I was carrying it by holding the strap fully extended at arms length and the camera hit a chair. I was lucky I guess but I sometimes wonder if user abuse has a lot to do with lens issues including the shutters scratching the glass. I noticed soon after I bought the camera that it is natural to pick the camera up in a way that fingers apply pressure the lens shutters. I have been careful not to do that. There have been compaints by people of the shutters scatching the glass.
I wouldn't worry about it. The G12 is a fine camera and I would buy mine again if I had the opportunity.
ddan Contributing Member • Posts: 735
G12 for 2+ years with no problems. Only problem I had was thinking the P7700 would be an upgrade to the G12. Silly me! Keeping the G12 until Canon adds the 28-200 lens.
Dale Buhanan Veteran Member • Posts: 4,280
I have never heard of a lens error on the G12.  I have one myself, and read the forums daily, but I have never heard of a G12 lens error.  You may be thinking of the S100, which has a similar sensor and did have lens errors for a certain range of cameras.  But I think you are safe with a G12.
I also have a G15, and it seems faster and better than the G12 to me.  You do need to bump up the sharpness, contrast, and saturation a notch in My Colors.  But after doing that, the camera is marvelous.  Don't give up on the G15 quite yet. Great camera!
Best luck to you...
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +35 more
OP SUE O''''''''''''''''''''''''''''''''BRIEN Contributing Member • Posts: 927
I didn't adjust anything so I will probably go with the G15. I googled, 'canon powershot G12+lens error' and it brought up a lot of things about that particular lens assembly on the G9 thru G12, plus S series. The G15 assembly has been corrected so it won't happen.
Thanks,
Sue
Thanks Blackhat!
Sue
Thank you!
Sue
Thank you ddan!
Sue
PC Wheeler
PC Wheeler Forum Pro • Posts: 17,902
Must have had a bad sample of the G15. I've seen none of that.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Panasonic ZS100 Sony RX10 IV
Rod McD Veteran Member • Posts: 8,578
Re: Never had any errors of any kind
Hi Sue,
I've never heard of a G12 lens error.  I have a G12 and a G1X and both have been extremely reliable.  No errors of any kind, ever.  I've also read this forum very regularly, and I don't think I would say that the G12 is error prone - the number of posts about G12 problems have been very few over the last year.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
MisterPootieCat
MisterPootieCat Veteran Member • Posts: 3,123
I found it on the Internet
This is what happens when we spend too much time trying to find faults with our gear. Did your original G12's ever give you any trouble? I'm guessing they didn't since you went out and bought a third one.
The fellow on eBay might be totally legit but as others have already suggested, based on forum chatter the G12 doesn't have a particular weakness as far as the lens is concerned. My main beater G10 did develop a lens error but I contribute the failure to too many bounces off pavement and concrete. I use LensMate adapters on my G10's now to at least protect the lens when it's extended and just added an adapter from Bower to my G15.
Sharpness with the G15 is more than decent, although it falls a bit short of what the G10 can deliver. I think CMOS sensors in general need a bit more in-camera sharpening or post processing to get the micro-contrast (real or perceived) of older CCD sensor cameras. That being said, I've just recently had some 12x18 prints done at Costco from the G15 and they look great. They were in-camera JPEG's with all of the settings zeroed out.
I've had some shots that were OOF with the G15, quite a bit more than my other P&S's from Canon. It might be a trade off due to the much faster focus. I'm on the fence about sending it to Canon for a check-up, mostly due to a horrible experience when they repaired my G10 last year. For now I'm keeping an eye on it and trying to get a feel for the when and why of the AF misses. Other than that the G15 is giving my G10's something to worry about.
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon EOS 40D Canon EOS 300D Canon EOS 7D Canon EOS 80D Canon EF 50mm F1.4 USM +24 more
toomanycanons Forum Pro • Posts: 14,167
Did you have any "lens errors" with your previous two G12s?  If not, why are you concerned now, you already have experience in the lack of "lens error" issues.
Thanks,
I just had a thought, Sue.  I'll bet the 'lens error 'you are talking about is the lens getting scratched by the lens cover leafs that are too close to the lens on the models you referenced.  There have been several reports of the lens cover leafs causing fine lens scratches...  That must be what you are talking about.  I myself have never had it happen on any of my G-series cameras and I have both the G9 and the G12, but I have read about it happening to others.
I cannot verify if Canon increased the lens cover spacings on the G15, but it would be nice if they did.  I have heard of no one mentioning scratches from the G15 cover blades yet.  (crosses fingers)
kind regards
Dale
Thanks Rod.
Sue
@Dale
I read on the net that the closing over the G15's lens is different and after looking closely at both of them, I can see the difference. I have always found the CCD sharper than the CMOS and that is my personal experience. I also have shaky hands and hate tripods.
Sue
http://www.pbase.com/osusana
HM888 New Member • Posts: 1
Hi Sue,
I think the lens error is quite prevalent. I had the G10. whilst using the camera, the battery went flat and the lens became stuck in the extended position even after replacing a fully charged battery. I brought it to canon singapore and was told the lens had to be repaired for an exhorbitant sum. I was encouraged to trade-in for the G12. One year after using the G12, the same incident occured. While taking pictures, the battery went flat, leaving the lens in the extended position. This led to the same lens error message when a fresh batter was replaced. The camera is used indoors in the office, and never dropped or handled roughly. I am quite disappointed that there seems to be an inherent problem with the lens mechanism. The people at Canon tried to pass an excuse that the camera was handled poorly and that "dust partlcles had gone into the lens mechanism", but I disagree completely.
Anyone out there with similar gripes?
#annoyed
Daveajh New Member • Posts: 1
Having the same problem. G12 is nearly 3 yrs old, been one of my all fave cameras. A couple of times at power up the lens failed to open and shut down, tried a few times and all ok.
But now after taking a few shots I got the lens problem error, lens is now fully extended and camera gives lens fail error and shuts down. Recharged battery but no luck, its dead :(.
As an engineer I am tempted to dive inside. Feels like the lens motor has jammed, has never knowingly been bashed or damaged. Great camera but always weary of too many electrical bits, gimme me a manual zoom any day.
debdrunner New Member • Posts: 3
This lens error has just happened to me. I was outside taking pictures of my Sons birthday party and out of the blue I got this message"lens error, will shut down automatically, Restart camera".
The Camera has not been dropped or abused in any way. I started doing some research and found that I am not the only one with this problem. Canon needs to own up to this problem just like they did with the s-100.
It has been confirmed that some PowerShot S100 digital cameras encounter a lens error caused by a disconnected part inside the camera. This announcement conveys the details of the issue and Canon’s service policy for affected cameras.
Canon continuously strives to provide our customers with high quality, reliable products that can be used with confidence. We offer our sincerest apologies to any customers who have been inconvenienced.
Phenomenon
Some PowerShot S100 units (with the serial numbers listed below) may encounter a lens error due to a part becoming disconnected inside the lens. In particular, this lens error may occur when the camera is used in certain environmental conditions such as high temperature and/or humidity.
Affected Product
Some PowerShot S100 Digital Cameras within the following serial number range:
The first and second digits of the camera’s serial number are any number from"29" through"41."
For example: "29xxxxxxxxxx", "30xxxxxxxxxx"………"41xxxxxxxxxx"
alanw55 New Member • Posts: 1
Had my G12 since  Oct 2012 , been a great camera till Sat 28 May 2016. After taking a couple of shots zoom half out  The camera made a sound like a fax on the phone. and displays the (Lens error will shut down  automatically restart camera ), message. Now every time the camera is turned on the same thing happens the camera stays on for about 4 seconds.  As this has happened to others it should be easy and I hope not too costly to get  this fixed,  I shall find out soon.
