FL300-R Flash on a Olympus E-3
Started Feb 24, 2013 | Discussions
Ivo Verhaar
Ivo Verhaar Regular Member • Posts: 346
i am looking for a compact (wireless) flash for my travelkit.
Does anybody have experience with the Fl300-R in combination with the Olympus E-3?
And yes i have the 50R, but i always leave it in the room.... too big.
Olympus: E-3, 12-60SWD, EX25,EC20, FL50R, 50-200SWD http://www.flickr.com/photos/iverhaar
 Ivo Verhaar's gear list:Ivo Verhaar's gear list
Konica Minolta DiMAGE A2 Olympus Stylus 720 SW Olympus XZ-2 iHS Olympus E-3 Olympus E-M1 +6 more
Olympus E-3
goblin
goblin Veteran Member • Posts: 3,498
Re: FL300-R Flash on a Olympus E-3
On the up side, it will be like an FL-36/R on steroids (four batteries instead of two). Which will bring it close to perfection.
On the flip side - no more discreet red AF illuminator. There's some ugly video pilot illuminator which will probably work, but it will be just as discreet as the ugly strobo epilepsy trap original illuminator of the E-3.
 goblin's gear list:goblin's gear list
Ricoh GXR P10 28-300mm F3.5-5.6 VC Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp2 Quattro +73 more
drj3 Veteran Member • Posts: 8,182
I think you are referring to the FL600R using four AA batteries [I have it and it is fairly smal (9 oz) and works well on E5].  The FL300 uses 2 AAA batteries.  It should work and has limited bounce capabilities. however the guide number is only 28 (ISO 200), so it would be limited in range.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +7 more
Ivo Verhaar
OP Ivo Verhaar Regular Member • Posts: 346
http://www.olympus.nl/site/nl/c/cameras_accessories/pen_om_d_cameras_accessories/pen_om_d_flash_systems/fl_300r_1/index.html
i realy mean the 300 which is small and light,
i know it is limited in output, but it is wireless, making it possible to take it of for macro work,
I have the big 50R, which is much more potent, but too bldy big and heavy... to carry around all the time so it tends to end up in my suitcase only seeing action with podium shots.
So realy looking for some compact stuff, if needed in conjunction with a difusser like: http://dx.com/p/30cm-mini-flash-speedlight-diffuser-for-slr-white-179278 which should be here in a couple of weeks. for either the internal or external flash.
