Image stabilization; who has the best?
Started Feb 21, 2013 | Questions
TrapperJohn Forum Pro • Posts: 16,488
None of the above
The most effective is the Olympus EM5, with it's 5 axis electromagnetic IBIS system.
I have shot handheld at 200mm (400mm FF) down to 1/30 and 1/20, and gotten blur free shots. Not just one or two, most of them. Oly claims 5 stops with this system, and I believe them. It really does work.
And it works on legacy glass - manually enter the focal length.
EinsteinsGhost
Re: Image stabilization; who has the best?
joejack951 wrote:
EinsteinsGhost wrote:
I didn't say it was useless. In fact, one of the images I posted was mentioned with use of 2-stops of stabilization. My point being overstated need and overhyping of number of stops needed to get it right.
Do you prefer to shoot at ISO 1600 or 3200 vs. 100? If not, then you could have used more stops of stabilization for some of your photos. Nothing was moving so shutter speed is a non-issue. You wouldn't have shot at those high ISOs on a tripod, right?
To prove something? Or to actually rely on EVERY other aspect of the tool at hand? I prefer to shoot for the conditions, and definitely don't see a need to push limits on one thing when it can be spread across other areas. So, ISO 1600 worked with 2-stops of stabilization, instead of pushing for ISO 100 with 6-stops, holding 100mm (150mm equivalent) FL for 1/2s. May be if my cameras disappointed at anything but ISO 100, I would be pushing for help elsewhere.
And yes, I would likely use ISO 100, 1/2s and have the OS off with tripod because then I won't be pushing any limits.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sony 135mm F2.8 (T4.5) STF Sigma 70mm F2.8 EX DG Macro +12 more
Allan Olesen Veteran Member • Posts: 3,391
I don't know about you and EinsteinsGhost, but in my experience, there is almost always some kind of action when I use long focal lengths. Apart from the occasional moon shot, I can't remember using long focal lengths for still subjects. And if there is action, I need some rather high shutter speed anyway, no matter how good the image stabilization is. I pretty much agree that 2 stops of stabilization help is all I can utilize without getting motion blur from subject movement.
So that leaves the short focal lengths. I sometimes shoot non-moving subjects at short focal lengths, but most of the time it is only slow-moving objects like living humans or leaves in trees. With a 2 stop improvement it should be possible to hand hold an APS-C camera at around 1/10 of a second at 28 mm focal length. If the shutter speed get slower than that, even a slow-moving subject will be blurred.
So yes, if you are taking photos of really non-moving subjects, you may be able to utilize more than 2 stops of stabilization improvement. But if you shoot action or slow-moving subjects, I doubt it.
Leon Wittwer Forum Pro • Posts: 13,278
Most systems correct for pitch and yaw which are the dominant problems particularly at longer focal lengths.
Chris R-UK Forum Pro • Posts: 18,406
The one being used by the steadiest photographer
A reputable British photo magazine did a large IBIS v ILIS test a few years ago using 8 bodies and about 10 lenses including Sigma lenses that were available for both IBIS and ILIS systems.  At the time Olympus had both IBIS and non-IBIS DSLRs and some ILIS lenses so it was possible to use the same lens for testing both systems.
Their results were all over the place with no best/worse consistency.  Their conclusion was that the biggest factor was the ability of the tester to hold the camera steady which probably depended on how much sleep he got the night before and how many cups of coffee he had had for breakfast.
I have never seen a test as to whether the efficiency of one system against another depends on the focal length, e.g. is IBIS better at shorter focal lengths and ILIS at longer.
Note that almost all mirrorless cameras use ILIS - I think that Olympus is the only exception.  However this may be due to overheating in video mode.
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 +3 more
joejack951 Senior Member • Posts: 2,682
No, to get the best shot/image quality. If your camera offers four stops of stabilization, why not shoot at ISO 400 and take advantage of it (other than laziness or lack of confidence in the system)?
Well, that'd be dumb to suggest trying to shot at ISO 100 when your camera clearly doesn't have that capability (6-stop stabilization that is). But ISO 400 should have been well within your reach.
Pushing ISO decreases image quality. Pushing stabilization does not.
Yes, the tripod solves a lot of problems. If you could get that sort of stable support in-body, wouldn't you use it much more frequently?
 joejack951's gear list:joejack951's gear list
Nikon Coolpix P7700 Nikon Coolpix AW100 Nikon D300S Nikon D3S Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +5 more
Zone8 Forum Pro • Posts: 17,276
I have the best!
Yes folks ...... ME!
As long as I go easy on the vino plonko before any shooting session!
Zone8: Although I am a handsome genius, when I stand in front of a mirror, I vaguely recognise the ugly idjit standing on the other side!
LINK: For B+W with Epson 1400 (and other models) using black ink only PLUS other useful tips:
http://www.photosnowdonia.co.uk/ZPS/epson1400-B&W.htm
Cleaning DSLR Sensors, including Kodak DSLR Factory Cleaning method:
http://www.photosnowdonia.co.uk/ZPS/KodakDCS-sensorcleaning.htm
Solving back/front focus problems on Sigma and most other DSLRs
http://forums.dpreview.com/forums/read.asp?forum=1027&message=35565277
PDF format list of lenses you can print or download - covers Italian Flag YES/NO for DCS 14n but applies to others. http://www.photosnowdonia.co.uk/ZPS/ItiFlagLensList.pdf
Look up Lance B.'s gallery. He posts a lot in the Nikon SLR lens forum. He frequently shoots wildlife with a 500/4VR and takes advantage of both the lens's VR and animals' freakish abilities to sit still.
That depends on the focal length, of course. At 800mm (not unreasonable with teleconverters and/or a crop camera), you can still freeze some action even at 3 stops of stabilization (1/100").
Dark interiors of rooms/churches/museums seems to be popular for short focal lengths and stabilization. Not something I shoot much of but I've seen enough pics like that to know that some people do a lot of it.
On super-telephotos a large benefit of in-lens stabilization is helping with framing and AF. You aren't counting stops there but the better the stabilization works, the easier it is to use those lenses even for action.
MPrince Senior Member • Posts: 1,695
Smartypants wrote:
No, no reason, I just wanted to better understand if one system is better that another.
I shoot Sony a850 with IBS and that great as I own older Minolta glass.
I'm thinking about moving to a Canon or Nikon and starting over with new glass and I've been looking at the current lenses by both vendors and thought I'd ask here.
thanks
That being the case, you should consider that with IBS, all your lenses are stabilized, whereas with Canon/Nikon, only certain lenses will be stabilized, and they will cost more and be heavier.  Some people claim in lens is better than in body, but I'm not convinced - I can get good results at 200mm (my longest lens) at 1/8s with my Pentax K-7.  Once you get much longer that you're probably better off using a tripod anyway, imo.
EinsteinsGhost
Does he hate using tripod?
Personally, I opt out of stabilization when shooting action. But, at least we're not talking about needing 5-stops anymore. That being said, what kind of action are we talking about freezing at 1/100s?
rjjr Forum Pro • Posts: 14,131
Tripod nt
EinsteinsGhost
As I said, to get the best IQ possible, under less than ideal conditions (no tripod/flash allowed), I personally prefer not to push one aspect to the extreme, but taking advantage of all aspects. Instead of ISO 1600, 100mm, f/8 and 1/40s (an example I posted earlier), I see no point to going ISO 400, 100mm, f/8 and 1/10s when the camera can deliver the results I care about. May be if it didn't.
Not necessarily. Why don't you show me your handheld examples so we have something to discuss where you did not want to move past ISO 100.
It seems you missed my point. If tripod were an option, there would be no need for IS much less the need to push the limits of IS.
headfirst
headfirst Contributing Member • Posts: 670
Re: The one being used by the steadiest photographer
Chris R-UK wrote:
Note that almost all mirrorless cameras use ILIS - I think that Olympus is the only exception. however this may be due to overheating in video mode.
Sony have said that they didn't go with IBIS for NEX for next due to space considerations - they wanted the thinnest bodies.
 headfirst's gear list:headfirst's gear list
Sony Alpha DSLR-A700 Sony SLT-A77 Sony Alpha DSLR-A580 Sony Alpha DSLR-A200 Konica Minolta Maxxum 7D +8 more
KimTeo Contributing Member • Posts: 951
The chicken ..
Midwest Forum Pro • Posts: 17,871
thanks
With a DSLR, you need optical stabilization. It stabilizes the optical viewfinder view as well as the image that the autofocus and metering have to work with. You may not be convinced that optical works better than in-body but the weight of expert opinion from all I have seen is that optical is decidedly better than in-body.
Optical stabilization does not make lenses noticeably heavier, and when even inexpensive kit lenses can have it, it is not that expensive a proposition either.
