Help! Need advice on best m4/3 prime lenses.
Started Feb 20, 2013 | Questions
ultilil
ultilil New Member • Posts: 10
Hi all, I'm hopin for some advice from you!
So I've gotten the prime lens bug. Here's what I've got already:
Camera: Olympus Pen E-P3
Oly 45mm f/1.8
Oly 40-150mm f/4
Oly kit zoom 14-42mm
I feel like I'm pretty satisfied on the upper range but lately I've felt seriously limited on the lower range. This is partly because I hardly ever use the kit zoom unless I have to. I use my iPhone over the kit zoom. It's not that I don't shoot at that range, I just don't like the lens.
So I'm looking for 1-2 more primes lenses to cover all my bases.
I've been using the 45mm for street shooting and portraits and love how fast and sharp it is but ironically its low light performance is lost on many indoor situations where the close quarters call for a much shorter range. I have also been shooting a lot of scenery lately so I would love a super wide lens at some point.
I tend to shoot primarily: portraits, scenery, some indoor (e.g. architecture, gatherings). Here's a link to my flickr page if that helps: http://www.flickr.com/photos/ljampol
Right now my 45mm lives on my camera and I would ideally like something with fast autofocus for a more spur-of-the-moment lens that is versatile in many situations. I don't care too much about size, because I always carey a purse/backpack.
Right now I'm considering these lenses (one immediately and maybe one in several months):
Panny 20mm f/1.7
Panny 25mm f/1.4 (I know this is a popular one but I'm nervous about it still being too long?)
Oly 17mm f/1.7
Oly 12mm f/2
Panny 7-14mm
Oly 9-18mm
Do you have any favorites or advice? I ideally want something to cover mid-range and super-wide, but don't want them to be redundant. Also, price is not a *huge* issue if the lens is totally worth it, but I'm definitely trying to not overspend. I'm also an amateur so I don't have a good idea of what it is like to shoot at wider angles (except the crappy kit lens) or what the possibilities for my work are.
If you could choose 1 now and 1 later, given what my prefs are, what would you choose?
Thanks so much in advance!
 ultilil's gear list:ultilil's gear list
Olympus PEN E-P3 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +3 more
Alumna Gorp Senior Member • Posts: 1,531
Re: Help! Need advice on best m4/3 prime lenses.
Oly 45mm f/1.8
Oly 40-150mm f/4
Panny 20mm f/1.7
Oly 17mm f/1.7
Oly 12mm f/2
Panny 7-14mm
Oly 9-18mm
I`d say get the 9-18 wide zoom first and see how it goes.
Followed by a prime between 17 and 25mm, you should have added the sigma 19m to your list of options, its dirt cheap but good.
 Alumna Gorp's gear list:Alumna Gorp's gear list
Fujifilm X10 Panasonic Lumix DMC-G2 Panasonic Lumix DMC-GF2 Olympus OM-D E-M5 Panasonic Lumix G 14mm F2.5 ASPH +4 more
Chas2 Veteran Member • Posts: 3,715
Oly 45mm f/1.8
Oly 40-150mm f/4
Panny 20mm f/1.7
Oly 17mm f/1.7
Oly 12mm f/2
Panny 7-14mm
Oly 9-18mm
Without much more than glancing at a few photos, I would say use your kit lens taped off to various fixed focal lengths and see how you like the field of view.  Looking at some of your shots, I think you would be happy with either the Panny 20 mm f1.7 or the Oly 17mm f1.8.
Personally, I like the 17mm FOV more than a 25 mm, and would steer you toward the 17 mm because it is a fast lens, and a faster focusing lens than the 20mm.  This would fill out your need for a faster, lower light capable lens, hitting the wide normal end of the spectrum, and leave your 45 for the tele end.
After that,  I would go for the wide end, and here, it might be useful to try before you buy, even renting a wide angle lens, and taping the zoom ring to 12 mm and imagining how good things would be with an f/2 max aperture, or if the 7 or 9 mm FOV is just too much to pass on.  I like the 9-18 because it is small and light, sharp in the center, can get a little soft on the edges wide open, and can take filters...and is cheaper than the 7-14 or the 12 mm, but it depends on how much you need the wide angle in low light.  Admittedly, the 9-18 is slow, especially at 18.  That is why I suggest you get the 17 mm first to cover the low light and wide angle.  In the meantime, after you have some shots under your belt, you can rent a 9-18 or 7-14 and use them with the zoom ring taped to 12 mm to see how you get on.
Full disclosure, I have a 20mm, and love it for its sharpness and low light ability. Had the 17mm f1.8 been out at the time I bought, it might be a different story...I am not going to buy a 17 since I have a 20 however, so I will never know!
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +12 more
jeffharris
jeffharris Forum Pro • Posts: 11,409
Oly 45mm f/1.8
Oly 40-150mm f/4
Good range, IQ low light and a nice match for what you already have.
Panasonic 7-14mm and 25mm
Oly 17mm
If you want to save some dough and simplify: 7-14mm and 20mm
The 7-14mm is a fantastic lens… worth every penny!
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
Lights
Lights Veteran Member • Posts: 3,616
Although I don't have one, some people say the Pan/Leica 25mm is the sharpest (and it certainly is fast) of M43 lenses. I realize there is some debate in regard to this. When I hit it rich, or quit buying other M43 gear, thereby depleting my self allowed allowance imposed by my semi dictatorial better 1/2 I'm going to buy it...if another fast alternative isn't available in this FL. It is a lot of $ for a "normal" lens.
My Gallery is here -
http://www.pbase.com/madlights
Why so serious? :The Joker
tyhsu Regular Member • Posts: 212
The 25/1.4 is not that big, about the size of the kit zoom. On my E-PM1, it still fits in my jacket pocket, and I'm a small guy.
And if you need the autofocus speed (as you indicated), I would shy away from the 20/1.7, as that has the slowest AF of the bunch. It's very noticeably slower, especially on an Olympus body, especially in low light.
Anders W
Anders W Forum Pro • Posts: 22,144
The claim that the 20/1.7 is "very noticeably slower, especially on an Olympus body, especially in low light" has been proven wrong by rigorous tests like the one reported here:
http://forums.dpreview.com/forums/post/50877416
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
Anders W
That's what some people say, yes. The 25/1.4 is a good lens but there is no systematic evidence that I am aware of that it is the sharpest of MFT lenses.
ultilil
OP ultilil New Member • Posts: 10
Thank you all for your responses, they were very helpful! I still haven't decided but I definitely feel like I have more info to work with.
carlosvp Regular Member • Posts: 193
In addition to what others have said, you may want to consider the Panasonic 14mm prime (perhaps in addition to a wide zoom). It's great for indoors work as it's much wider than your 45mm (I love that lens too, but it can be hard to get far enough away from a subject indoors to use it), it's very sharp, at f/2.5 it's faster than the kit zooms, and focus is near instantaneous. It's also cheap, at least if you hunt around.
C.
