Cheap legacy wide angle/fisheye lenses?
Started Feb 14, 2013 | Discussions
squirrelyfox Forum Member • Posts: 60
Hi all,
Having followed the forum for awhile, I'm well aware of the multitude of great and cheap legacy glass out there. I'm wondering though if there are similarly priced and decent quality wide angle/fisheye lenses out there as well?
If anyone has any samples or links to pages with samples of said lenses as well please let me know. Thanks!
 squirrelyfox's gear list:squirrelyfox's gear list
NEX5R Sony E 18-55mm F3.5-5.6 OSS Sony E 35mm F1.8 OSS
kev777zero
kev777zero Senior Member • Posts: 1,635
Re: Cheap legacy wide angle/fisheye lenses?
check out the Rokinon/Samyang 8mm f/2.8 fisheye lens. Not exactly legacy lens but manual focus. A VERY decent fisheye at only a fraction the cost & size of other fisheyes. A gold box deal comes around every once in a while on Amazon for ~$250USD
 kev777zero's gear list:kev777zero's gear list
Sony Alpha a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Tamron 28-75mm F2.8 III Sony FE 24-240mm F3.5-6.3 OSS Sony FE 35mm F1.4 +4 more
alterstill
alterstill Regular Member • Posts: 331
squirrelyfox wrote:
Hi all,
Not quite a legacy glass but I am more than happy with fisheye converter for 16mm pancake. It is cheap too.
 alterstill's gear list:alterstill's gear list
Fujifilm FinePix X100 Fujifilm XF1 Sony Alpha NEX-7 Sony E 10-18mm F4 OSS Sony E 16mm F2.8 Pancake +16 more
Photozopia
Photozopia Senior Member • Posts: 1,302
No. Never gonna be a wealth of cheap legacy wide-angles or fisheyes for Nex due to the crop factor.
A legacy 16mm FF focal length - although commonly available - is still a pretty extreme lens on 35mm .... but a 'ho-hum' 24mm FOV on APS sensor. And anything much wider than a 16mm (FF) is:
a) rare
b) expensive
c) HUGELY expensive.
Only the Rokinon/Samyang/X Brand fisheyes fall into the 'cheaper' legacy category ... but can be bought for only a little more in Nex mount anyway. Or buy native e-mount lenses - like the 10-18 - probably better value in the long run.
cptrios Senior Member • Posts: 1,352
It also really depends on what "cheap" means. For a lot of people, in the grand scheme of photography equipment, anything under $500 is "cheap." But then there are the actual cheap lenses like any number of the $50 MF nifty fifties out there.
There is that Zenitar-M m42 fisheye that goes for $150-200...but really it'd be worth just spending a bit more for the Samyang 8mm.
Someone already mentioned the SEL16...and while it's far from a great piece of glass, it's still the best WA option you'll get for NEX at that price level, legacy or otherwise. Though if you don't mind going a bit less wide, the Sigma 19 is loads better.
Mojn Contributing Member • Posts: 884
Maybe: Rokkor 21 mm f 2,8
SQLGuy Veteran Member • Posts: 5,884
a) rare
b) expensive
I paid $140 at a local camera shop for a good condition Sigma 14mm/F3.5 in Canon FD mount. It's a big ball of glass on the front, so it does tend to flare pretty easily, but I'm still quite happy with it.
Nex-7 with kit lenses, Contax G 35, and a number of legacy lenses (mostly Canon FD)
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 Sony Alpha a7 II Sony Alpha NEX-7 NEX-5T +12 more
Beaverhelmet Senior Member • Posts: 1,948
I have reached this conclusion as well. While I'm normally a huge fan of legacy glass, owning over 45 legacy lenses in various mounts, some very expensive, I have not yet found a wide lens that performs considerably better than the Sony 16mm in that price bracket. Good, fast and wide legacy glass is normally quite pricey stuff. So for really wide shooting, I will actually resort to SEL16F28, and the VCL-ECU1 and VCL-ECF1 I have just ordered. These may not be brilliant, but should be decent enough for everyday use.
Another option is the Metabones Speed Booster, making fast-ish wide-ish EF lenses fast and wide on the NEX, but the present adapter is just a little bit too expensive, so I will wait for the non electronic version.
Photozopia
That's a great deal you got - but not really typical. A quick glance through typical eBay sales for second user 14mm Sigma is around £500 average ... about $750. Not that cheap, particularly when a new 'native' 10-18mm can be bought for only £100/$150 or so - plus, 14mm is not much wider than 16mm ... again available cheaply in native e-mount.
Existing (or bargain) legacy lenses might be fine for some purposes - but there are few, if any, truly 'cheap' ultra-wideangles ... that translate to a decent wide FOV on a cropped sensor.
SasoV Junior Member • Posts: 43
Your images make me want to buy this lens emidiatly!
forpetessake
forpetessake Veteran Member • Posts: 4,892
Not cheap, but super quality wide angle lenses: Nikon 14/2.8D and 17-35/2.8D. And as a bonus, you'll be able to use them on FF camera as well.
http://www.flickr.com/photos/kevinwlyu/
I understand you have or had boat SEL 16mm with fisheye adapter and Samyang 8mm. As I am looking to buy a fisheye I would like to ask you wich one would you sudgest. I dont hawe a 16mm lens yet so I would have to buy a complete set.
Thanks.
EinsteinsGhost
Legacy wide angle/fisheye lenses are more difficult to find, for less. Among the new lenses however, one of my personal favorites is already mentioned: Rokinon 8mm f/2.8 E (Fisheye), normally selling for $325-350 but occasionally found (esp on Amazon, for $250).
Additionally, there's also a Samyang 14mm lens (which is FF) that should work well. And I believe a Samyang 10mm is also being made available.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sony 135mm F2.8 (T4.5) STF Sigma 70mm F2.8 EX DG Macro +12 more
kev777zero
Thanks.
The Samyang beats the SEL16 with fisheye adapter hands down. If all you are going for is the fisheye don't even bother thinking twice, Samyang beats all for fisheye on NEX.
On the other hand if you want wide angle, SEL16 also has a wide angle adapter, which I still use, that is still quite acceptable (obviously less quality than the SEL1018, but at 1/4 the price).
alterstill
Unfortunately that's not really wide on NEX.
Agree, so what (cheap) legacy or anyhoo lens?
OP squirrelyfox Forum Member • Posts: 60
Thanks for the advice all. That's too bad that there aren't as many cheap options for old glass.
richiemccaw Contributing Member • Posts: 920
Yeah thats what it seems like to me too. It's very tempting to get the 10-18 but the price is a huge stumbling block.
 richiemccaw's gear list:richiemccaw's gear list
Panasonic LX100 Sony RX100 Sony Alpha NEX-6 Canon EOS 80D Sony E 16-50mm F3.5-5.6 PZ OSS +7 more
tn1krr Senior Member • Posts: 1,236
I have the Speed Booster and the Samyang 14/2.8 and while the lens is a real bargain for it's optical quality and with booster gives about same FF equiwalent WA (15 mm as Speedbooster is 1.07 x "crop") as the SEL1018 I've yet to manage to correct it's distortion to satisfactory level. There are profiles for it in the LR4.3 (could be via lens downloader) and PTlens with different cameres that improve things, but obviously they do not take account the Speed Booster that seem to do it's own share in distortion; wheter it is decreasing or ioncreasing it, cannot be sure but it seems to break a bit the Lens profiles I've seen. I'm thinking about creating my own with the Adobe tool (takes some time/setup and we have a new baby in the house) or testing the manual controls in the Dxo Viewpoint.
Gonna check the Samyang with normal Metabones smart adapter that I also have next to see if any of the profiles much look better with it, to figure out the effect the Speedbooster glass has, but with the crop the 14 mm is not that wide anymore so I'm hoping to get the distortion with the Speed Booster under control.
 tn1krr's gear list:tn1krr's gear list
Sony Alpha a7R III Sony FE 35mm F2.8 Sony FE 55mm F1.8 Carl Zeiss Apo Sonnar T* 2/135 Zeiss Batis 85mm F1.8 +4 more
