Advice on converting a 400D to IR
Started Feb 14, 2013 | Discussions
SwedishGoose
SwedishGoose Regular Member • Posts: 272
Hi,
I have upgraded from a 400D to a 6D and am considering converting the 400D to IR. I know you can send it to a company in Great Britain and get it done but I have heard that it is easy to do it yourself.
Any tips are welcome. Has anyone here perhaps done the same thing? Any links to tutorials etc...
/ Martin
Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X) Canon EOS 6D
TTMartin
TTMartin Veteran Member • Posts: 7,304
Re: Advice on converting a 400D to IR
SwedishGoose wrote:
Hi,
/ Martin
This doesn't sound 'easy.'
http://www.lifepixel.com/tutorials/infrared-diy-tutorials/canon-drebel-xti
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
rwl408 Senior Member • Posts: 1,802
I converted a Pentax DL to IR a few years back. The conversion process could be daunty if you don't have the experience disassembling/assembling small electronic gadgets. But the bigger problem is not the conversion process itself. Check out this site (http://ir-photo.net/ir_mod.html) to find out what you are up against before you take your 400D apart. That being said, I will most likely convert my XSi (450D) to IR again when I upgrade it. For one thing I can use more pixels than the 6MP sensor chip of Pentax DL provides (it essentially becomes a 1.5MP camera because only the red sensors are sensitive to IR wavelength). For another 450D's sensor chip has lower noise.
Rick
SwedishGoose
OP SwedishGoose Regular Member • Posts: 272
Thanks for the link....
Not too easy no. Maybe it's worth the money to have them do it for me...
Y0GI Veteran Member • Posts: 5,233
Rick
You both may find this interesting:  http://ghonis2.ho8.com/rebelmod450d13.html
Good luck!
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
