Will the ZS10 battery charger work with the ZS15 battery?
Started Feb 13, 2013 | Questions
DC Alford Veteran Member • Posts: 4,144
Maybe a silly question...
I received my new ZS15 today & have the battery charging in the camera right now, which is a good option to have(but isn't the ideal way to have to charge the battery imho).
My question is: Since the ZS15 uses the same battery the ZS10 used(DMW-BCG10), shouldn't I be able to use a ZS10 charger to charge my ZS15's battery?
I searched & found plenty of info on third party chargers but didn't find any info on using the ZS10 charger. I know it should be self explanatory, if it is the same battery then the charger should work just fine, but as my luck isn't always that good(!)with things like this I wanted to get confirmation before I tried it.
Thanks in advance for any help.
Dan.
 DC Alford's gear list:DC Alford's gear list
Canon PowerShot SD950 IS Kodak EasyShare C875 Fujifilm FinePix F200EXR +1 more
Panasonic Lumix DMC-ZS1 (Lumix DMC-TZ6)
Ron_43 Senior Member • Posts: 1,531
Re: Yes. (nt)
Dan.
OP DC Alford Veteran Member • Posts: 4,144
Thanks Ron...
I appreciate the help.
Dan.
rover220 Regular Member • Posts: 201
Re: Thanks Ron...
I too congirm it's possible as I am using the TZ9 charger for my TZ25 .
 rover220's gear list:rover220's gear list
Panasonic Lumix DMC-ZS15 Leica C Panasonic LX10 Kodak ESP 5250 FastStone Image Viewer +2 more
