Bees with the 100wr
Started Feb 10, 2013 | Discussions
ozdean
ozdean Forum Pro • Posts: 24,927
Bees with the 100wr
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax K-5 IIs Pentax K-70 Pentax smc DA 15mm F4 ED AL Limited +12 more
Gerry Winterbourne Forum Pro • Posts: 14,478
Re: Bees with the 100wr
Nicely done, Dean.
Gerry
_______________________________________
First camera 1953, first Pentax 1985, first DSLR 2006
ozdean
OP ozdean Forum Pro • Posts: 24,927
Thanks Gerry, are you up early or late, 9 pm here?
miles500
miles500 Senior Member • Posts: 1,005
Great pictures.  I always find that bees are prone to dart away just as I have framed the shot.  I am looking forward to the spring when I hope to capture some similar shots with my newly acquired Tamron 99mm 2.8.
Miles500
 miles500's gear list:miles500's gear list
Fujifilm X70 Fujifilm X-T20 Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
Just an ordinary day, Dean - 11 am here.  I actually thought you must be up late: the time difference is obviously not what either of us thought!
Gerry
Benoz
Benoz Veteran Member • Posts: 6,225
 Benoz's gear list:Benoz's gear list
Pentax MX-1 Pentax K-70 Pentax KP Pentax smc DA 35mm F2.8 Macro Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +4 more
Greyser Veteran Member • Posts: 5,699
Nice macros, as usual :-). I remember your last year shots with Lester Dine 105/2.8. How do you compare these two?
 Greyser's gear list:Greyser's gear list
Pentax K-01 Pentax K-3 Pentax K-1 Nikon D500 Pentax K-5 IIs
Zablot Contributing Member • Posts: 649
Nice shots and I'm glad that you are having a nice Summer down under.  My bees were out yesterday even though it was only 39 degrees...........................Jim
ozdean
Hi Miles thanks for your complements and you are right they are busy little fellows, you need to keep your shutter speed up or use flash. I find the built in flash and 100wr do a very good job, you will find the same with your Tammy.
ozdean
LOL - you know 9pm is my bedtime!
ozdean
Thanks Ben
ozdean
Thanks Greyser, both are excellent when compared with ring flash mounted. The Elicar (LD) has a slight blue cast to it when using AWB but has this intriguing smooth sharpness. I really need to do some in house tests. I have these 2, a dfa 50 and Da 35 ltd and like each one. Differences are really subtle apart from the obvious perspective but certainly the Elicar has the most different rendering; typical of film lenses ie not as contrasty.
ozdean
Thanks Jim, so they are up ready for work - you have subjects laid on I have to hunt for mine - LOL
leopold Forum Pro • Posts: 14,083
 leopold's gear list:leopold's gear list
Fujifilm X-E1 Canon EOS 7D Fujifilm XF 27mm F2.8 Fujifilm XF 18-55mm F2.8-4 R LM OIS Canon EF 400mm f/5.6L USM +3 more
Jim Beverlin Veteran Member • Posts: 4,566
Excellent shots.  Thanks for posting.
JRB
ozdean
Thanks Steeve glad you liked them.
ozdean
Thank you Jim
kitsios_spyros
kitsios_spyros Senior Member • Posts: 2,634
All nice. I find #3 & #4 the most interesting ones.
Kind Regards,
Spyros
 kitsios_spyros's gear list:kitsios_spyros's gear list
Pentax K-01 Samsung NX300 Pentax K-5 II Pentax K-3 Pentax K-3 II +12 more
Joseph Tainter Forum Pro • Posts: 10,408
Very nice.
You actually used the pop-up flash? No vignetting? (I thought regular flashes were good only to within 0.7 m.)
Joe
ozdean
Thanks for your comment Spyros
