One Lens Works and One Does Not
Started Feb 7, 2013 | Questions
SheriLynn512 New Member • Posts: 1
I am having a problem with my Canon EOS Rebel 1100D. I was attempting to take pictures in a large room with low light - I had it set on MANUAL and noticed that the pictures were coming out extremely dark, even with the flash. I changed it to AUTOFOCUS and it would not take the picture. It seems to be stuck in a continuous state of trying to focus. I took the lens off and a rather small black piece, with gold prongs fell out of the camera. However, when I changed lenses to my zoom, the pictures came out perfect.
I don't know if it's a problem with the lens or the camera. I'm trying to figure out if it makes more sense to buy a new lens for everyday use or if my camera needs repairing. I hope I've explained the problem - it has me stumped. Especially because I can't see anywhere that looks like this piece came out of.
Canon EOS 1000D (EOS Rebel XS / Kiss F Digital) Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50)
Hank3152
Hank3152 Forum Pro • Posts: 13,499
Re: One Lens Works and One Does Not
Sounds like the issue is with the first lens since the other lens and body are working as expected. Can you submit a closeup pic of the part that fell out and the rear of the lens ? Which lens is it and is it under warranty?
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm F2.8L Macro IS USM +5 more
brightcolours Forum Pro • Posts: 15,885
You have not told us which lens that is.
You have to show us that something, we have no idea otherwise.
You have to tell which lens this is too.
You have to provide more details and a pic, else no one will be able to get an idea...
iancrowe Senior Member • Posts: 1,477
Stop using the camera/lenses until you've checked...
Hi.
It sounds like the AF/aperture electrical contacts have fallen off either your camera body or one of your lenses. Have a close look at the rear of your two lenses and see if they look like this.
If you can't see the gold contacts on one of them then there is your problem. Stop using the lens and have it serviced by the manufacturer.
if both lenses have the contacts then check the camera body which should look something like this:-
If it is the camera body stop using it immediately and have it serviced by Canon ASAP as there could well be two screws floating around inside the body with the potential to do more damage.
I have to say from your description I suspect it is the plate from the camera body (as shown in the second photograph) rather than one from one of the lenses.
Hope this helps.
Ian
photonius Veteran Member • Posts: 6,895
Well, you got already some information, in particular that you should provide more information.
but given the second lens seems to work fine, everything points to the fact that the contacts fell off your first lens. Was it an old manual lens with a focus confirm chip attached to it? Those could come off easily.
Now, even though there may be something wrong with your lens, the scenario you describe is also problematic. I.e. a large dark room will give issues, because the built in flash of the camera will probably not be strong enough to light it up, and if the room is dark, no lens will be able to focus in a very dark room - and you need focus assist lights from the built-in flash, or from an external flash. However, if the flash is not strong enough it will not help either. It depends how big the room is, which you did not specify. In any case, if a lens cannot focus because it's too dark, of course it will hunt trying to focus.
The fact that the pictures come out dark in manual mode simply mean that you did not set the settings right. While it may be too dark for automatic operation, in manual mode you should be able to set aperture f2.8 for example, and 15 seconds (or some other long exposure, depending on the situation) exposure time (on tripod), which should give you a good exposure even in dark situations. Of course without tripod, this would be blurred.
So, there may be a whole lot of things going wrong here, not just the lens. Having said all about the dark room, given that you state the second lens gave fine pictures, it would indicate that room was not that dark, and was good enough for AF.
However, in the absence of sample pictures, iinformation on what shutter speeds, aperture, ISO etc you were using, it's not easy to judge what is going on.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
