canon 7D lens kit
Started Feb 5, 2013 | Discussions
bigelow New Member • Posts: 3
canon 7D lens kit
Hello, I'm new to digital, and I'm planning on buying a new canon 7D and I would like advice on deciding which kit lens to buy: either the EF-S 18-135 or the EF 28-135. I am leaning toward the EF 28-135 as it appears to be a better lens from what I have read, although I wonder if I would miss the width of the former. Additionally, I have a Tamron 28-200 (571D) that I could use until I scrape together enough funds to get a nice lens or two. Would getting the EF 28-135 be redundant given the Tamron lens I already have? I imagine the EF 28-135 is quite a bit better than my Tamron. Any comments would be appreciated.
KENTGA Veteran Member • Posts: 8,733
Re: canon 7D lens kit
I don't know about the lenses you mentioned, but I have 7D + 17-55. I'd probably use the lens you have until more funds become available. I love my 7D and the 17-55.
Good luck,
Kent
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO +14 more
glanzrabe Regular Member • Posts: 200
Perhaps you should have a look at the 18-135  IS  STM. From some reports it´s optically better than  the older version with a very good AF.
bert
happysnapper64 Veteran Member • Posts: 5,421
I got my 7D with the 15-85 IS USM in UK. It's a great carry round lens. Not as fast as some, but in reasonable light, the IQ is excellent. The extra 3mm on the wide end has almost made my 10-20 redundant. Oh, by the way, welcome to the forum.
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 5D Mark II Canon EOS 7D Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM +6 more
Steve Balcombe Forum Pro • Posts: 15,582
The 28-135 has Ring USM which is a better AF mechanism, but optically it's nothing special - probably on a par with the 18-135. Also it has a much older and less effective image stabiliser. I wouldn't describe it as a better lens.
And you're right, 28 mm would be very limiting. If you're coming from film don't forget the field of view of most digital SLRs is smaller - 1.6x smaller in the case of the 7D. This means a 28 mm lens on the 7D has the same field of view as a 28x1.6 = 45 mm lens on your film SLR. Would you be content with that as your widest lens?
Probably the best all-round standard zoom is the 15-85. Or if you want f/2.8 throughout the range, but at the cost of a smaller zoom range and higher price, it's the 17-55.
OP bigelow New Member • Posts: 3
Yes, I agree; I do need something wider than 28. Thank you for the 15-85 tip. I've read about it and I plan to get it for my standard walkabout lens when I can gather the funds. Do you think an EF-S 18-55 would be reasonable for the interim or should I go with the 18-135? I don't need much telephoto capability - I just want a reasonably good lens to use until I can afford to buy the 15-85.
jitteringjr Veteran Member • Posts: 3,608
You would get better pictures with a 60D and a good lens like the 15-85 than you would with a 7D and a cheap lens like a 18-55 or the first 18-135 non STM.  Think about getting a 60D instead to give you more money to spend on glass.
 jitteringjr's gear list:jitteringjr's gear list
Canon EOS 7D Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +9 more
eYn New Member • Posts: 18
When I moved from 7D to 5D... my biggest gripe is losing the 17-55 lens. If you can spend that much its the best walk round lens for crop
Its super sharp and 2.8 is a life saver indoors.
I would say, you can drop down to a t3i if that will make room for a 17-55... The next best is the 15-85. I would not get anything other than these two.
I have used the 28-135, though its a decent glass I hated the lens creep.
Limburger
Limburger Veteran Member • Posts: 7,841
For general purpose I also advise the 15-85 as long the light you're shoot in allows it.
Why no cheap as chips 18-55 IS till the funds allow to upgrade it?
In the long run a 15-85 + 70-200 (the f4 L is very cheap regarding it's performance). For low light a wide prime like a 28,30,35 or 50 f2 or lower.
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100 Canon EOS 7D Sony a7 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm F4L USM +3 more
BigBen08 Veteran Member • Posts: 7,473
I agree, especially considering that the OP is new to digital. Depending on the type of shooting he wants to do, the 60D might fit his needs.
BHP sells the 7D for $1199, and the 60D for $699, a difference of $500. And the 15-85 goes for $699.
I had the 7D and 17-55 (since sold), and that combo produced razor-sharp images. But I'm into event photography (parades, fairs, car shows, etc) and 55 didn't give me enough reach many times. If I had to do it over again, I'd buy the 15-85, which is optically a great lens, also.
Keith Z Leonard Veteran Member • Posts: 6,134
My recommendations in order
1.  Sigma 17-50 f2.8 OS / Canon 17-55 f2.8 IS  in a dead heat.
2.  Canon 15-85 IS very good and certainly might be chosen for increased flexibility
3.  Canon 18-135 IS STM the earlier version isn't very good, the newer STM looks good and a very good range as well.
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EF 70-200mm F4L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM Canon EOS 400D +16 more
I love my 15-85 on my 7D, but it also suffers a bit with lens creep. Mine creeps from about 30-55. Not too much of a problem for me personally.
lee uk.
