Pentax MG lens use on Pentax K-r?
Started Jan 31, 2013 | Questions
competitions New Member • Posts: 3
First time poster and been over 20 years since I've used an SLR.
I have an old 1980's Pentax MG with unknown (maybe Tamron) telephoto lens and have tried placing it on the new(ish) K-r and while it appears to physically fit, doesn't seem to be just point and click in that pressing the shutter does not take a photo.
Is there some setting required to use the old lens on the newer digital camera?
brandrx Forum Pro • Posts: 28,337
Re: Pentax MG lens use on Pentax K-r?
In the menu somewhere there is a setting for "Using Aperture Ring". Make that setting equal to 2 and then leave it there from now on. It has no afect on any other lenses.
If you lens as an A position then set that lens to the A position.
Cheers.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
M R Padmaraju Veteran Member • Posts: 3,789
Set the camera for manual mode and try. you may be able to take a picture .( And depress the shutter firmly). Good luck.
M R Padmaraju.
 M R Padmaraju's gear list:M R Padmaraju's gear list
Fujifilm FinePix F40fd Pentax K-x Pentax K-01 Pentax K-500 Pentax K-S1 +8 more
OP competitions New Member • Posts: 3
Cheers.
Ron
Thank you Ron.
I set the lens to 'A' and that allowed pictures to be taken.
With your answer, was it do either or should I also set the Aperture Ring to 2?
Cheers.
Ron
Thank you Ron.
The Aperture Ring = 2 setting has no affect on any lenses except for lenses without an A setting and M42 screwmount lenses.
You set the Aperture Ring to 2 for use with lenses that do not have an A setting. I set all of my Pentax DSLR's to Aperture Ring Setting equal 2 and never look at it again.
Cheers.
Ron
brandrx wrote:
Cheers.
Ron
Thank you Ron.
Cheers.
Ron
Thanks again, much appreciated!
