Re: Can Zoom ring of 18-55 kit lens be lubricated/fixed at home?
EDIT
I sort of got gestalt and largely changed my mind -
Best thing to do is to sit to listen to your favorite programming and just TWIST THE ZOOM RING to break it in. This will definitely improve the smoothness of a cheap new lens. Worked well on my 15-45 canon EF-M kit lens - no stuttering at any speed or spot.
This is after about 10minutes of twisting it stop to stop. It's still 'growling' a bit, but I'm going to keep doing it a while. Much better!
I'm checking out other advise for specific experience but here is my plan
Canon kit lenses simply do not have smooth manual zoom - but why?
Try this: push on the zoom ring just a tad - see if it smooths out.
Then, PULL and see if it gets more friction. And visa-versa of course.
In my case with the latest 14-45 lens, is that pulling just closes the gap between the ring and the lens body enough to add friction *THAT IS NOT IN THE INTERNAL CAM* - and it makes sense that Canon engineers would do whatever it takes to come up with a smooth internal design - even if it's low-cost.
But what they did not do is consider that last tiny bit of tolerance in the installed ring.
SO - it's nice because the friction can be isolated, and it's right on the surface, in my case in the crack between the rear of the zoom ring and the lens body.
NEXT QUESTION - what kind of oil?
I have quite a bit of experience working with paraffin wax. It's an excellent lubricant - and the key is that it's a solid, attracts zero dirt, The trick to applying it is to melt it in a hot water bath, and to apply it with a brush, and then wipe off the excess.
Since this is an "irreversible application" - paraffin wax is not going to "wick" into the innards beyond where you place it - which is where the friction is. And you can push it into the crack and it will stay there. The wax actually does fill low areas and provide lubrication all around, but it will need to be reapplied eventually with usage. So plan on that.
BTW I use a jam jar in a quart jar of hot water which I can microwave a couple of minutes. I think a q-tip might work in this case, but be sure to use virgin wax for this job. If you have any issues you can add about 10% acetone to lower the melting point and smooth out the solid to a creamy consistence.
