How to achieve this texture/grain effect???
Started Jan 29, 2013 | Discussions
Mark A. Small
Mark A. Small Contributing Member • Posts: 611
Can anyone help guide me in the grain textures techniques necessary to achieve what Vernon Trenton achieved in this image:
Image by Vernon Trenton
Thanks.
Mark
its all about creating a place you can be yourself, and in an instant, allowing me to capture you as art...
www.markandrewimages.com
Mark A. Small
OP Mark A. Small Contributing Member • Posts: 611
Re: How to achieve this texture/grain effect???
I'm using both Lightroom 4 and Photoshop CS6 if that helps with providing any guidance.
Thanks.
mikes
mikes Veteran Member • Posts: 3,430
What software do you use?. Many film emulation programs will do this too, but all it really is, is just adding a lot of noise with a vignette.
Only when you can criticize yourself, should you criticize others. Mikes.
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 8,263
Thanks.
Mark
he probably just used SilverEfex
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony a7R II Sony FE 55mm F1.8 Phase One Capture One Pro +25 more
Babine Veteran Member • Posts: 7,199
Grain and tone as stated, with Silver Efex, NIK, Topaz, just to name a few or something like this tutorial
http://photoshoptutorials.ws/photoshop-tutorials/photo-effects/natural-film-grain/
and additional curves adjustments for colour and contrast to suit.
Cheers.
Gary
http://forums.dpreview.com/Galleries/8298604696/photos
http://www.pbase.com/pictek
From a patient during his colonoscopy, 'Hey Doc. Could you write a note for my wife saying that my head is not up there?'
Mark A. Small
Won't all those programs just add grain?
What about the "brushed" effect - i.e. around her skirt and on the right side of the image in the middle?
Thanks.
Mark
Allen Gerdes Veteran Member • Posts: 5,638
Sure it will, and it appears that a strong grain effect was added in this image.  The "brushed effect" as you call it appears to be a textured overlay layer, with some areas masked out and the layer opacity adjust to taste (of course, the swirl marks could have been made with a special brush on a separate layer and blended in).  It is difficult to replicate the effect without having a better idea of the texture used.  I will try to work up an image with a similar effect and post it later to give you a better idea.
Regards...Allen
Mark A. Small
Katrin Eismann taught me the gray overlay grain technique years ago.  That definitely could contribute to this effect.  But the texture(s) need to be created and blended in.  Does anyone have any insights as to how to go about that?
thanks
