Take a drill and a deep breath.... mounting a Zeiss with Leitax
Started Jan 27, 2013 | Discussions
RemcoR Senior Member • Posts: 1,214
I got a Carl Zeiss planar T* 50mm F1.7 C/Y mount cheap and bought a Pentax mount from Leitax. I could not remove one screw from the C/Y mount, and took the lens to my local photo/repair shop. No problem they said, but after a week they handed it back with the damn thing still in it. So I took a drill and drilled the head of the screw out myself. After that, mounting the Leitax was a piece of cake.
Note the one screw missing at the top right.
More pics here: https://picasaweb.google.com/RemcoRog/CarlZeissPlanarT50MmF17?authkey=Gv1sRgCO2m-M_ru_6xcQ
RemcoR
Pentax K-5 K100D Sigma 17-70 F2.8/4.5 DC Macro
Pentax 35mm F2 AL Pentax 55-300mm 4-5.8
SMC Pentax 35-105mm F3.5 macro
Carl Zeiss Planar T* 50mm F1.7
http://picasaweb.google.com/RemcoRog
http://www.pentaxphotogallery.com/RemcoRog
leopold Forum Pro • Posts: 14,083
Re: Take a drill and a deep breath.... mounting a Zeiss with Leitax
 leopold's gear list:leopold's gear list
Canon EOS 7D Fujifilm X-E1 Canon EF 400mm f/5.6L USM Canon EF 70-200mm F4L USM Fujifilm XF 14mm F2.8 R +3 more
OP RemcoR Senior Member • Posts: 1,214
So far I am very impressed with it. Manual focus at F1.7 is shall we say an art, but when nailed, this baby is sharp wide open like nothing I have seen (yet).
Please take a look at this pic (It was F1.7, all photo's show F2.4 as exif info) at max magnification:
https://picasaweb.google.com/RemcoRog/CarlZeissPlanarT50MmF17#5838246701348537506
I am planning to do some "head to head" tests against the Pentax SMC 35mm F2 AL. Both are impressive in their own right. The Zeiss, as the 35/F2, has its own distinct characteristics, quite different from anything I shot with Pentax.
And heck, just doesn't she look great?
RemcoR
ozdean
ozdean Forum Pro • Posts: 25,094
Registration distance is right? ie infinity ok?
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-50 Pentax K-70 Pentax smc DA* 55mm F1.4 SDM +13 more
Yes, that is the beauty of Leitax, it's not an adapter but a proper PK-mount. It costs about the same as a good adapter, around €50.
RemcoR
ozdean
Very good - well done.
awaldram
awaldram Forum Pro • Posts: 13,270
I would drill and re-thread that mount point , it's unlikely the lens will sit square with one mount missing leading to de-centering type issue with image quality.
RemcoR
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Olympus PEN E-PM2 Pentax Q7 Pentax K-3 +17 more
A re-thread is not needed. I drilled out the (head of the) screw from the old Contax/Yashica mount and replaced the whole thing with a pristine Pentax mount. The remaining base of the lens still has the original thread so the only thing I have to do is order a new screw (did that yesterday).
A comparison with my FA35/F2 coming soon.
RemcoR
baldeagle21b Contributing Member • Posts: 987
The only problem I see with this story is that you used the words "Zeiss" and "cheap" in the same sentence.
 baldeagle21b's gear list:baldeagle21b's gear list
Pentax K20D Pentax K-01 Pentax Q7 Pentax K-3 Pentax K-1 II +9 more
awaldram
Looking forward to that .
RemcoR
manueljenkin Forum Member • Posts: 90
Hey, need some help. Is there a tutorial on how to get the screws drilled out? Any drilling kit/drill size you'd recommend.
I was trying to leitax mod the Zeiss 35-70 and stripped the screw head.
https://www.dpreview.com/forums/post/62854242
You only need to drill out what is left of the screwhead. I used a drill machine with the smallest drill I could find, about 1/2 the size of the screwhead. After removing the mount, I used pliers to turn the rest of the screw out.
Or, send it to David from Leitax, because the 35-70 is known to be difficult.
After all is done, you get a lens that is able to render wonderfull pics
Good luck!
RemcoR
Pentax K-5
Samyang 14mm f/2.8 IF ED UMC Aspherical
Pentax FA 35mm F2 AL
Carl Zeiss Vario-Sonnar T* 35-70mm F3.4 Macro
Carl Zeiss Planar T* 50mm F1.7 Contax
Carl Zeiss Planar T* 85mm F1.4 ZK
Carl Zeiss Distagon T* 21mm F2.8
https://www.flickr.com/photos/126796413@N03/
GPGeneralPhoto
GPGeneralPhoto Senior Member • Posts: 2,153
 GPGeneralPhoto's gear list:GPGeneralPhoto's gear list
Canon PowerShot SD400 Pentax K-01 Pentax K-5 IIs
