Not A Fan of Viewfinders. Am I crazy?
Started Jan 26, 2013 | Discussions
Barrie Davis
Barrie Davis Forum Pro • Posts: 21,460
Re: Not A Fan of Viewfinders. Am I crazy?
zenit_b wrote:
Robert Anderson wrote:
I have to tilt my head back and view through the bottom part of my glasses. I
With the LCD screen I cannot tell if my distant subject is smiling or if their eyes are closed.
Then DON'T look through the camera, look over the top!
Best detailed view finder ever..
Golly! I am amazed anybody needs to be told this!!
Both excellent points Robert to which I wholeheartedly concur. Its harder I think for younger people to understand because they are still under the illusion they will have perfect eyesight for ever
Baz
"Ahh... But the thing is, these guys were no ORDINARY time travellers!"
 Barrie Davis's gear list:Barrie Davis's gear list
Konica Minolta DiMAGE A2
9VIII Regular Member • Posts: 455
ljfinger wrote:
KyleSlamchez wrote:
Now I understand that many screens can get washed out in bright sunlight. As far as I can tell, this is the only disadvantage. Is there something I'm missing here?
Yes...try shooting all day with a big lens that way, and try keeping it stable. Which looks more stable and comfortable to hold for, say, about 10 hours? Having that left elbow against your body is almost like having it on a monopod from a support standpoint.
Now stick a swivel screen on that and hold the camera at chest height.
I don't think anyone will ever prefer the EVF for daylight sports, that is an obvious weak point... Which may make the whole point of stability with a long lens irrelevant, but I digress.
 9VIII's gear list:9VIII's gear list
Canon EOS 1100D Fujifilm X-E2S Canon EF 400mm f/5.6L USM Sigma 150mm F2.8 EX DG Macro HSM Canon EF-S 18-55mm f/3.5-5.6 IS II +5 more
EternalOne
EternalOne New Member • Posts: 12
I shank my viewfinders and lcd screens with an icepick until they are destroyed. Then i make cross hairs with fishing line and a toilet paper tube and glue it to my hotshoe. Gives me perfect shots everytime.
Lee Jay Forum Pro • Posts: 54,498
It's often not so simple.  My camera's resolving power at around 35mm is about the same as my bare eyes.  So, if I'm shooting at, say,  200mm (which is extremely often for me) I can't see enough detail "over the top".  Further, looking "over the top" means losing your attention on framing which usually means missing the shot.
Lee Jay
(see profile for equipment)
 Lee Jay's gear list:Lee Jay's gear list
Canon IXUS 310 HS Canon PowerShot SX50 HS Canon EOS 7D Mark II Canon EF 70-200mm F2.8L IS II USM Canon EF 8-15mm f/4L Fisheye USM +23 more
Re: You are lucky your close range vision is still good ..
Barrie Davis wrote:
zenit_b wrote:--
ok .. what you will find when you get to your late forties/early fifties is that your close range vision How close do you hold your LCD Screen ? Mine has to be around 18" for me to be able focus comfortably. Then its quite small of course and I cant see all the detail.
I've never been quite able to work out why people feel they need actual detail in an arm's-reach style LCD viewfinder. Surely, all you need it for is framing of the main subject masses... [??]
If you need the most detailed view of what is actually happening IN your shot...
... surely you simply look over the top of the camera. (shrugs)
Note: This is what users of large format have been doing since the 1840's. They don't even have a choice. At the point of exposure there is no viewfinder to view with, as the ground glass screen is replaced by the darkslide holding the film.
Fine for stationary subjects at wide angle.  Heck, that's nearly 1% of my shooting!
Lee Jay
Bill Force
Bill Force Veteran Member • Posts: 6,607
But, do you use your "good eye" or the other one?
' You don't have to have the best of everything to get the best out of what you do have'.
EternalOne
I got tired of choosing eyes.....so i used said icepick to also jab out 1 eye and taped fishing line crosshairs over my only eye so i could compose shots even if i don't have a camera on me.
Barrie Davis
I wouldn't consider using a 200mm lens to shoot with an LCD viewing camera. Not a suitable combination.
And I am not a sneak-shot paparazzi, either, so I wouldn't really use such a long lens to shoot human subjects even with an eyelevel finder.
Hmm.... just thinking...
....the longest lens I have ever used for a fashion shoot was 180mm, and THAT was on 2¼" square...(Hassy). Even so, the models were so far away they couldn't hear me in the traffic noise of a city street, so I had to relay my posing directions via mobile 'phone to an assistant stationed just out of shot.
Baz
RedFox88 Forum Pro • Posts: 29,213
glasses
KyleSlamchez wrote:
Not only that, but because I wear glasses,
No, it is because you wear glasses. If you ever use an optical device such as an optical camera viewfinder or a telescope you have to not wear glasses if you want to see through it well.  It is fully because you wear glasses.
My SX260 has no viewfinder and goes to 500mm.
My 70-200 is my primary portrait lens.
I do it all the time from just 5-30 feet away.
Lee Jay
tbcass
tbcass Forum Pro • Posts: 42,832
If it works for you great. I won't tell you that you're wrong. I have cameras with both LCD only (Sony RX100) and ones with both EVF and LCD (Sony A55 and A65). I grew up with Film SLR's and optical viewfinders dating back to the 60s. I find that it is easier to hold the camera steady while looking through the eye level finders which allows me to use lower shutter speeds in hand held low light situations.
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony RX10 IV Sony a99 II Tamron SP AF 90mm F/2.8 Di Macro Sony DT 35mm F1.8 SAM +10 more
AlbertTheLazy
AlbertTheLazy Veteran Member • Posts: 7,892
I've used most sizes of film camera in my time -- the biggest one took 15x12 INCH negatives. I've also (once) shot an air show with a 5x4 MPP micro-press (with viewfinder and rangefinder) and used Rolleis, Hassleblads, Bronicas, Nikons, Pentaxes, Canons, Exactas, Sinars  and a few you've probably never heard of.
Nowadays I mainly use a Fuji X-E1 and and an elderly Canon PowerShot 720.
Personally, I would never have a camera for hand-held use that didn't have a viewfinder I can put my eye to. I occasionally use my wife's little Pentax digital and have to hold it out to see the rear screen. I hate that. I find it difficult to see the screen clearly in bright light, hard to keep the camera still. My arms hurt and my eyes complain.
If you are one of the people who is happy with the rear screen and don't like viewfinders then that's your choice. What I don't understand is the number of people I see holding DSLRs out at arms length, rather than using the V/F. There is no way that you'll realise the potential benefits of a DSLR using it that way. And why lug all the weight and bulk associated with a DSLR around if you are not going to use it finder?
Albert
Every photograph is an abstraction from reality.
 AlbertTheLazy's gear list:AlbertTheLazy's gear list
Canon PowerShot G15 Fujifilm X-T1 Sigma 70-300mm F4-5.6 APO DG Macro Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Re: Not A Fan of Viewfinders. Am I crazy? Undoubtedly, but...
…there's room for you in the world! LOL
Seriously, it's the picture that counts, not how you composed it. I posted a picture the other day that turned out to be beautifully composed and only half a degree off horizontal -- which I took shooting totally blind,  pointing the camera back over my head in a speeding boat!
But I do love my EVF!
Cheers, geoff
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Bill Force
Ditto that!  I used a Speed Graphic for 8 years and a variety of other cameras over a 20 year period and have to have a viewfinder of some type.  I also pick up my wifes little Nikon P&S and laugh at myself because it has no viewfinder but I still attempt to hold it up to my eye first before I realize I have to hold it at arms length to see anything, old "fire house dog".
toomanycanons Forum Pro • Posts: 12,772
Not a fan of cameras without viewfinders.   Maybe it's a generational thing but...I hate composing with just an LCD.  There are no downsides to OVFs and maybe EVFs will catch up sooner or later.
Mark B. Forum Pro • Posts: 25,849
I respectfully disagree
I've worn glasses since my first SLR.  Inconvenient maybe, but I can see well enough - but I'd never trade an optical VF for going LCD only.
Mark
Digirame Forum Pro • Posts: 36,711
Using a viewfinder, allows the photographer the ability to anchor the camera to the face, making it more steady.  Using a LCD and holding it out gives us more camera shake.  That's important for us photographers that use the long end of a telephoto lens in low light with low shutter speeds (that don't use a tripod).  Also it depends on your eyesight.  Some of us are so nearsighted that we can't see the image in the LCD when using glasses for things in the distance.  The viewfinder has a diopter adjustment, however there's no such thing on the LCD.
Boris
Boris Veteran Member • Posts: 9,257
Even a peep finder is better than using a LCD....in my humble opinion.
 Boris's gear list:Boris's gear list
Ricoh GR Digital IV Sigma DP2 Merrill Ricoh GR Ricoh GR II Canon EOS-1Ds Mark II +41 more
Re: I respectfully disagree
I was not at all saying that using the LCD is better, never said that.
And if you've always only used glasses, you argue that using glasses isn't an obstacle to using a viewfinder.  I wear glasses and also use contact lenses.  Whenever I'm going to use an SLR camera, I use contact lenses.  The difference is that significant.  You don't know what you're missing if you've never had the chance to use a viewfinder as it was meant to be designed.
GodSpeaks
GodSpeaks Forum Pro • Posts: 13,913
Re: So many viewfinders; all have their merits.
Barrie Davis wrote:
I'm thinking of large format cameras (sheet film, say, 10x8" and 5x4" ) with a ground glass for composing on. With this type of camera the image is large but also upside-down and very dim...
I am also quite sure that you are fully aware of the fact that large format cameras are not a part of this discussion.  Hence not included in the 'any' part of my comment.
and please, don't bother responding.
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
- Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic FZ1000 Sony Alpha DSLR-A850 Nikon D800E Panasonic Lumix DMC-GX7 +49 more
