Do Manfrotto and Gitzo ball heads share same type of
Started Jan 22, 2013 | Questions
waynes Contributing Member • Posts: 917
release plates?
I know neither is Arca Swiss type.
Or can they at least fit into?
Thanks,
KentG Veteran Member • Posts: 4,518
Re: Do Manfrotto and Gitzo ball heads share same type of
Don't know as I only buy ballheads that have Arca compatible plates and plateholders. Much of my gear has RRS and other brand plates permenantly attached to the tripod mounts. Even my Clik Elite backpack has a Joby Ballhead X mounted onto its camera frame so I can swiftly attach one of my cameras/lenses with its attached Arca compatible plate quickly when I have the backpack flipped around to the front.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-5 IIs Pentax K-S1 Pentax K-1 Pentax smc D-FA 50mm F2.8 Macro Pentax FA 150-450mm F4.5-5.6 +3 more
miles green
miles green Veteran Member • Posts: 6,479
I don't think so. I think Manfrotto plates are hexagonal, gitzo are square? But don't take my word for it.
I also wouldn't get a non-arco-swiss compatible head. Maybe a head with traditional screw, and i'd fit a 3rd party quick release adaptor (RRS, novoflex, etc...)
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-1 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +8 more
OP waynes Contributing Member • Posts: 917
Both should be square now. My Manfrotto 486(?) has a square plate.  I also have a Gitzo head, but it is a non quick release type.
It looks like that neither Manfrotto nor Gitzo heads are popular....
Paphios Regular Member • Posts: 395
Manfrotto actually uses a number of different release plates that are not compatible with each other.
I use RC4 release plates for their stability and use both a ball head and a gear head compatible with those plates.
Arca-Swiss type plates do have a big advantage in wider compatiblity.
leopold Forum Pro • Posts: 14,083
I had an older Manfrotto head that use Hexagonal plates and the one i use now is a Manfrotto 469RC Proball head have a rectangualr QR plate.
Gitzo plates are different.
 leopold's gear list:leopold's gear list
Canon EOS 7D Fujifilm X-E1 Canon EF 400mm f/5.6L USM Canon EF 70-200mm F4L USM Fujifilm XF 14mm F2.8 R +3 more
My guess is:
The current Manfrotto plates with square or rectangular shapes will work for Gitzo heads.  But not the other way around.
Manfrotto plate holders are odd and specific..
