Remote trigger problem 1000D
Started Jan 21, 2013 | Discussions
hunkyfunkster New Member • Posts: 2
Hi Guys
i have a wired remote trigger and a wireless remote trigger for my 1000d, but when i use them to take a picture, the camera focusses, takes the picture, then the screen turns black and the whole camera freezes and won't take any more pictures until i disconnect the trigger.
does anyone have any suggestions? i was going to udate the firmware, but it's running 1.0.7 already.
please help
Alex
Canon EOS 1000D (EOS Rebel XS / Kiss F Digital)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
what brand/model remote trigger?
hunkyfunkster wrote:
Hi Guys
What remote triggers are you using?  Maybe not fully compatible?  Are you using Live View?  Do the triggers work with live view off?
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
(unknown member) Veteran Member • Posts: 4,085
Re: Remote trigger problem 1000D
Alex
It might help lots, if you told everyone what mode you are trying to take the photo in.
John
OP hunkyfunkster New Member • Posts: 2
hi there,
thanks for the replies so far.
i am using a Hama wired remote trigger, which works fine on it's own, but is only 6" long. i have an extension cable which screws onto it, but this causes the black screen to happen.
i also have a JYC wireless remote shutter release from eBay which causes the same problem.
Both are able to take one picture, but then the camera freezes until the trigger is disconnected.
I have tried in several different modes, but the same thing happens every time.
The wired remote works fine until i use the extension, so i know the trigger itself works
Any help would be great
Alex
WilbaW
WilbaW Forum Pro • Posts: 11,643
That sounds like a thing I get with a cheap radio remote. Once the shot is taken the camera appears frozen, but all I have to do is half-press again once or twice on the remote and everything is back to normal.
Check out the unofficial Rebel Talk FAQ - http://snipurl.com/RebelFAQ
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
