How Hard could it Be to Add Depth of Field Info?
Started Jan 20, 2013 | Discussions
AEP2 Forum Member • Posts: 80
If an iphone ap can do it, certainly the 5D3 should as well.  Camera knows focusing distance, lens aperture, and zoom value.  The depth of field button is pretty useless.  Give the info as 25-75, for example.
Canon EOS 5D Mark III
schmegg Veteran Member • Posts: 5,768
Re: How Hard could it Be to Add Depth of Field Info?
Not sure the camera always knows the focusing distance though. It's my understanding that older lenses don't report this (and I don't know about third party lenses either) so the feature would not always work. That's as far as I know - I could be wrong.
Lemming51
Lemming51 Forum Pro • Posts: 14,912
It is easy to add, but such a display implies greater precision than exists.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm f/1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Nigel Wilkins
Nigel Wilkins Senior Member • Posts: 1,006
It is easy to add,it used to be on most lenses.  I use one with depth of field scales.
The problem is, it's of limited use.  The camera doesn't know what you consider to be in or out of focus or how big you're going to print the image or from how far you intend to view it.  It's not an exact science.  How accurate is your iPhone app?
Personally, I find with live view, the depth of field button to be more useful than any theoretical limits.
 Nigel Wilkins's gear list:Nigel Wilkins's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 56mm F1.2 R +1 more
rrccad Forum Pro • Posts: 11,444
what's your observer distance and final image magnification?
DoF is varied and not exactly accurate to calculate at the time of the image being captured.  the most accurate calc would be on a 2lp calculation for DoF .. which would have some horrified to see how small it is.
if you use the standard DoF .. it's not realistic .. since that was based upon an observer distance of around 2 feet (I think .. ) and a print output of 12x8.
 rrccad's gear list:rrccad's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Canon EOS 5D Mark II Canon EOS M Canon EOS 7D Mark II +2 more
