Inner fungal bloom issue, 6 month old Canon ef 70-300 L
Started Jan 18, 2013 | Discussions
OP sanderspics New Member • Posts: 8
Re: Inner fungal bloom issue, 6 month old Canon ef 70-300 L
nelsonal wrote:
I've cleaned out a bunch of lenses, newly formed fungus that's right behind the front element usually isn't a difficult repair. You might not want to do it yourself (taking apart an expensive lens isn't high in my list either), but I'd be surprised if you couldn't find a repair shop either in Thailand or back in the UK that would do it inexpensively, if the warranty isn't going to be valid anyway there's. A lot of UV light will kill any living spores in the mean time, if you have access to a UV source.
Hi Nelson, have you any idea haw much UV light is needed to kill off the fungas spores? I will have access to UV striplights in a couple of weeks when I make it to BKK.
I don't know what you consider as inexpensive, but I find what you say about having it cleaned reassuring and will look into that on my return to UK in a few weeks time. 'm in the middle of nowhere here and only in BKK for 3 days before setting off to India for the last 4 weeks of the trip. I hope that it won't worsen significantly in that time.
Thanks for your reply
RedFox88 wrote:
From reports I've read on here there's a good chance that if sent to Canon for warranty service, it would be declined since it is not a defect in the lens it self. Where the moisture got inside the lens is anyone's guess. Could have been when you had it or when Canon had it but they probably have a very controlled assembly area for lenses.
Yes I feel that would also be the result if I shipped it underwarranty, we all know that companies don't want to do after sales work if they can avoid it.
The reason I suspect this could be a factory fault is the one mark (the worse one) on the very edge of the front element looks like its the start of this problem, letting moisture in and then spreading to the front of the inner 2nd element, though I don't fancy arguing my case with Canon as they refuse to do the work.
Why on earth do Canon not have a worldwide warranty though, it seems very unfair that the only place the warranty stands up is in the original country of purchase. I think its very poor for an international top end camera manufacturer.
Thanks for your reply mate
Thanks to everyone else that has helped out by replying to this thread
(unknown member) Veteran Member • Posts: 5,590
It is possible that this problem was initiated by poor storage in high humidity at the dealer you purchased it from.  And one of the reasons why the warranty situation varies from country to country is because manufacturers can not control, and therefore guarantee, the condition of stock once it gets outside their official channels.  I'm not saying the place you purchased it from was unofficial but if you are purchasing in a country where you don't know the dealers very well you do need to be careful.
photonius Veteran Member • Posts: 6,895
Actually, at least L lenses should have an international warranty, search for it.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
nelsonal Senior Member • Posts: 2,464
Depending on the intensity a couple hours should kill it off.  Generally sunlight is intense enough over a few hours to do the job, so with UV bulbs much closer I would think any exposure would help but an hour should more than do the job (it won't, unfortunately, keep reinfection from happening).
If it's just on that first element, it would normally be under an hour to do the job (and I'm including time for me to figure out how the lens should be disassembled), so with overhead I would expect something on order of $100 in the US (googling reveals estimates of $50-$150 depending on severity).  I would expect that you could find more repair options for this issue in the tropics but I could be quite wrong about that.
Kevin Jorgensen Contributing Member • Posts: 745
How old is the lens? You say you bought it 6 months ago but is it a UZ lens? I have 4 L zooms and 6 primes but don't have any problems with humidity. But I have airconditioning which is on 18 hours a day and 2 Eureka Dry boxes. If you've looked after it as you said then the age of the lens becomes a factor and how it was stored before you purchased it. This is one of the 2 dry boxes I store my gear in. I live in Vietnam fulltime.
 Kevin Jorgensen's gear list:Kevin Jorgensen's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Samyang 14mm F2.8 ED AS IF UMC +2 more
RedFox88 Forum Pro • Posts: 30,738
My guess is because the different countries may be individual business units so you bought it from Canon USA and not Canon Asia for instance.  Canon Japan makes the camera but distributes and sells them to Canon USA, Europe, etc. ... maybe.  Then Canon USA sells them to store. .. maybe.
Anyway, doesn't hurt to check about warranty anyway. From another forum quotes:
" Most of my Canon lenses are bought in Bangkok. They give you two years warranty from Canon Thailand. And one year Canon International Warranty.
One page on my International warranty card me the rules. The lens is serviced free of charge for the original purchaser at all the worlds Canon Inc. And also at the Canon WWW systems distributors members that are listed as Canon members in Canons Service Facility Card. And at all Canon's overseas corporations. "
and
"I have 11 Canon L lenses with International Warranty Cards. I have serviced or repaired those in 3 different countries and 2 continents. When they where bought in another country. Only a few months ago I repaired my 24-70L with a stuck aperture in Bangkok's Canon Serive Center (free of charge). It was bought in Europe."
So, did you get that warranty card in BKK?
In contrast Canon Australia seems to not honor this.
Australia has some pretty tight laws protecting consumers. I wonder if that is true or just a rumor. I doubt it would hold up in a court of law.
Telhma Regular Member • Posts: 391
OhioBob wrote:
They are talking about humidity controled cabinets. When not in use store your lens's in them to keep them dry. You take them out and shoot as always but when you get back home you put them back into a dry enviroment to keep the mold spores from growing.
I putted such a little bag with something salty in my lens bag for my L lens. you see that some times with new shoes. is that a good idea?
greetings
greetings
Well, a bag of silica gel, to absorb moisture, yes.  But remember to dry the silica gel out occasionally in an oven at low temperature so that it continues to work.
Steve Balcombe Forum Pro • Posts: 15,582
meland wrote:
greetings
Or if you can't get hold of silica gel, rice works or so I'm told. (Presumably not rice bought from a hessian sack in a humid climate?)
(unknown member) Forum Pro • Posts: 11,521
if you read canon's financials they certainly do.  it would be nearly impossible to fiscally manage that with such a widely varying international currency situation.
