I want a red eye!
Started Jan 13, 2013 | Questions
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 15,180
I want a red eye!
Photographing coots is challenging with basically two colors black and white. Losing the feather texture or bleaching the beak is far too easily done. I class this one a reasonable effort but there is a third colour, the red eye which is hardly visible.  Does anybody have a suggestion how I can bring out the eye subtly just enough to know it’s there while keeping the rest of the shot intact.
Panasonic Lumix DMC-GX7 Panasonic G85 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S +1 more
Priscilla Messinger Senior Member • Posts: 2,992
Re: I want a red eye!
It looks like your focus wasn't on the eye, but on the back. Also, there is not enough light on the head. Not your fault, of course, as you had to deal with the lighting conditions and the position of the bird.
Allen Gerdes Veteran Member • Posts: 5,638
Besides bringing up the color of the eye using a curves adjustment layer and mask, I also denoised using Topaz Denoise, added some contrast and adjusted highlights and shadows using Topaz Adjust, and brought out a little more detail with Topaz Detail.
Regards....Allen
faith2 Veteran Member • Posts: 3,296
Re:Very nice edit, Allen!! re: I want a red eye!
Regards....Allen
-Lois-
"God doesn't give us what we can handle; God helps us handle what we are given." -Unknown
Re: Thanks Lois (nt)
Allen
Pixel Poetry
Pixel Poetry Veteran Member • Posts: 5,639
Used Lightroom to increase luminance and saturation to red.
 Pixel Poetry's gear list:Pixel Poetry's gear list
Canon EOS 550D Canon EF 50mm f/1.8 II Tamron SP AF 90mm F/2.8 Di Macro Canon EF-S 18-55mm f/3.5-5.6 IS II
Re:Chris, another fine edit. re: I want a red eye!
-Lois-
Pixel Poetry
Thank you Lois (nt)
Skip
Skip Senior Member • Posts: 1,925
I have PSE 11. It seemed like a straight forward way was to select just the eye with the round selection tool, increase the red saturation, then increase the brightness - I guess similar to what the LR reply said. I don't know how this bird should look so what follows is probably over the top, but the sliders could be adjusted as required. Anyway, I understood you to say that you didn't want the rest of the photo messed with, so the selection tool seemed like the way to go.
 Skip's gear list:Skip's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DC-ZS70 Panasonic Lumix DMC-G5 Sony a77 II
Sailor Blue
Sailor Blue Forum Pro • Posts: 13,227
In Photoshop zoom in then select the eye using the Elliptical Marquee Tool.  Hold down the Shift + Alt keys to keep the selection round and expand it from the center of the eye.  You can simultaneously press the Space key to move the selection while creating it.
I feathered the selection by 1 pixel the created a new layer containing only the eye by pressing Ctrl + J. I reset the Blend Mode to Screen, which brightens but doesn't effect the color of the eye. You can duplicate this layer again if you want it even brighter.
Flatten if you want or just do all the other edits you want such as levels, noise reduction, etc.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Michael Edward Rudge Veteran Member • Posts: 7,076
Re: Lovely shot, I just tweeked it a bit
In PS sc2, I changed to CMYK and adjusted the levels, then sharpened 1 step, popped on a border.
Thanks for the play
Michael North Wales
Red Eyed Duckypotimiouse
 Michael Edward Rudge's gear list:Michael Edward Rudge's gear list
Canon EOS 60D Canon EF 50mm f/1.8 STM Canon Pixma MG5350
Trevor Carpenter
OP Trevor Carpenter Forum Pro • Posts: 15,180
Thanks to everybody especially Pixel Peeper and Michael, who I thought did extremely well at getting the subtle change I was looking for.
Trevor Carpenter
Thanks for the play
Michael North Wales
Excuse my ignorance why does changing to CMYK help? Do you change it back after?
I seem to get more control over the color range, when adjusting levels, then change back to RGB to post it on dp
