Do you think the image of SD14(SD15/DP1/2) is cleaner than that of SD1m(DP1m/2m) ?
Started Jan 12, 2013 | Questions
Roland Karlsson Forum Pro • Posts: 27,880
Re: A correction to my post above :-(
xpatUSA wrote:
After reading Clark's article again, "that limit" is stated quite clearly as 5um which makes the SD1, at 4.9um, almost perfect in that regard, especially around the f/4 mark. Cameras with larger pixels at that same aperture would show "jaggies" more clearly on edges.
The Clark article is simply wrong.
He first says that today´s sensors are photon limited. And then he goes on and says that increasing number of pixels increases noise and decreases dynamic range.
That is only correct if you assume that you are going to either crop the image or enlarge it so that the pixel density is the same in the print, and then also look at the image at the same distance.
Which generally is a bogus assumption.
If you print the whole image at the same size, then there will be no IQ problems with having more pixels, if you are photon limited.
Moreover - there is ABSOLUTELY not any 5 um limit. The limit is strongly dependent on the technology for the sensor. If the technology is such that the percentage of captured photons do not drop when having more pixels, then the noise and dynamic range is not affected at all. We are not there yet, but getting closer for each generation of sensors.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony RX100 III Pentax K-3 Pentax K-1 +14 more
digi2ap Contributing Member • Posts: 724
Re:YES
Interesting thread. I've not upgraded from my DP2X to a DP2M because I suspect this to be right. The DP2X images are wonderfully clean on screen and, for whatever printing I need, the DP2X can print plenty big enough. I may change my mind in time, though!
 digi2ap's gear list:digi2ap's gear list
Sigma dp1 Quattro Sigma SD1 Merrill Panasonic Lumix DMC-GH3 Sigma 10-20mm F3.5 EX DC HSM Sigma 30mm F1.4 DC HSM Art +2 more
xpatUSA
xpatUSA Forum Pro • Posts: 13,891
Re: The Clark Article is Simply Wrong
But Roger Clark is very well respected although sometimes a little hard to follow:
http://www.clarkvision.com/articles/does.pixel.size.matter/
Actually he says it a little differently: "there is one fundamental limit: photon counting statistics", by which he is referring to the signal-to-noise ratio. His table follows:
Photons, Noise, signal-to-noise (SNR)
9 3 3
100 10 10
900 30 30
10000 100 100
40000 200 200
If we agree that these figures are correct, it should be obvious to everyone that the sensor which counts 40,000 photons has a better SNR than that which counts 10,000. Better by a factor of two, do we at least agree on that? Indeed, if we can not agree that photon noise is the square root of the photon count, then our discussion might as well here.
(My only problem is with Clark's use of the word "limit" which is so often inappropriate in the world of photography, since it implies a solid barrier which can not be exceeded. Perhaps a photon count of one?)
Yes, when we make images the "same size" the implication is that one of the images is re-sampled. Upward and acutance is lost. Downward and acutance is improved.
I absolutely agree that there is not a 5um limit. In fact, "limit" is not even an appropriate word in this context.
A reasonable conjecture. Meanwhile, I believe the thread is about existing sensors.
Ted.
Sigma DP2 Panasonic Lumix DMC-G1 Sigma SD15 Panasonic Lumix DMC-GH1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
Yes, thats correct.
9 3 3
100 10 10
900 30 30
10000 100 100
40000 200 200
Yes, thats also correct.
He makes two errors in the article though.
  1. He is only talking about pixel peeping. He ignore that the more pixels you have, the higher pixel density you get when printing. Then you get averaging over more pixels, the more pixels you have. And then you get back (most of) the dynamic range and S/N you lost.
  2. Even for pixel peeping, there is no limit. You can make the well depth larger. You can have some kind of clever dynamic range enhancement. Both improving S/N ratio.
Raist3d Forum Pro • Posts: 37,986
Yes
In this case yes. This is an issue of the new Foveon. I can only hope it's something sigma can figure out to suppress in a future version of SPP.
Ad this is Iso 100 and full spectrum light!  This is why I have to shake my head at this point when people refer to Foveon as ultimate image quality for the "knowledgeable photographer. "
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
The lack of white marred by green/magenta foveon splotches?
Laurence Matson wrote:
Am I missing something? Are these 100% crops?
Apparently you are missing the green/magenta color splotches that are on what should be pure white snow (or dirty snow or whatever variant of white snow it should be).  This is not new. Even the cat you had posted in a flash shot a while back had exactly the same problem. Photos I took with a dp2m also had this problem at low Iso a bit (some shots). Lin Evans posted one of his first shots here which also showed the problem.
My dp2 virtually never had this issue at low iso  I am hoping maybe Sigma can fix this in a future version of SPP.
Each camera has its own strengths, and a general comparison like this makes little sense. The SD14 and especially the SD15 are nice for faster write times and - in the case of the SD15 - a wonderful buffer for raw. The SD1 has just spectacular detail, which translated into amazing printed images at any size up to A0. Even at smaller sizes, this is true: set the image for 720 dpi and print away.
but we are taking about image quality. Surely one would expect the new Foveon to be unequivocally better.
In terms of noise, that is more of a processing issue. Detail, however, cannot be processed in.
the issue is not the typical noise per se but the magenta/green splotches- or "Foveon noise"- the color constancy issue. Not too trivial to process out depending on the photo.
Shooting a wedding professionally and having to watch for this is a nightmare.
michaeli wrote:
I found that there are more purple and green noise in the dark area of the images of the SD1m than that of the Sd14 when both in low ISO (ISO 100). Is the noise related to the Dynamic performance or is that just little purple fringes caused by lenses?
I think SD1m should have better dynamic performance than SD14, what do you think?
Comparison:
SD14:
SD14
SD1m:
SD1m
Laurence
laurence at appledore-farm dot com
Sometimes, life is going to hit you with a brick. Don't lose faith.
Steve Jobs
http://www.pbase.com/lmatson
http://www.pbase.com/sigmadslr
http://www.howardmyerslaw.com
Re: Yes
The previous sensor was optimised for daylight. It was VERY bad at tungsten.
In the Merrill sensor they made the blue layer thicker.
Its a kind of zero sum game. Improving tungsten, worsen daylight.
xpatUSA
He makes two errors in the article though.He is only talking about pixel peeping. He ignore that the more pixels you have, the higher pixel density you get when printing. Then you get averaging over more pixels, the more pixels you have. And then you get back (most of) the dynamic range and S/N you lost. Even for pixel peeping, there is no limit.
Looks like we're approaching agreement - I do agree that down-sampling, properly done, can improve IQ.
As far as S/N ratio is concerned,  I'm not certain that well-depth can simply be increased for a Foveon sensor because it's layers have to be at specific depths:
Foveon 14X3DP1
As to "some kind of clever dynamic range enhancement", can't really respond to such speculation - sorry.
Ted.
Yepp
For Foveon, I assume both are out of the question. Foveon pixels are enough complicated already.
But ... for ordinary sensors (with Bayer filters) thats a totally different story.
Lets say that you have
R X
G B
Instead of
R G
G B
Where X is a sensor without filter. Then that pixel would be moire sensible, digging deeper in the shadows.
X could also be a dark grey filter. That could improve high light properties.
There are other solutions. One could make the detectors logarithmic by making them less sensitive when they are charged. Possible? I dont know
What I do know though is that there is lots of reseach on this topic and that consumer products generally dont use the result from such research, for some reason
Re: Yes
Interesting take. Do you have a a particular link that explains this design choice?  Thanks Roland.
MOD Kendall Helmstetter Gelner Forum Pro • Posts: 20,280
SD-1 is cleaner, but you need to expose differently
I was busy in Death Valley and missed your post originally.
In the older Foveon cameras, we tended to be able to bring up shadows a little more.
Where the Merrill sensors differ is that they have more DR than the older sensors (substantially more) but to get at it you need to over-expose a bit.  In that sort of white snow shot for example, you'd probably expose the SD-1 at +1.7.  Possibly even higher.
The the shadows would look fine.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
Re: Yes
Nope.
I only have two "evidences" for this.
  1. The previous sensor was totally cr@p at tungsten. And looking at the raw data, the blue layer was almost empty, only noise. I have not heard about any complaints about tungsten performance for the Merrill sensor.
  2. The RAW data in the Merrill cameras has a strong blue tint, where the RAW data from the previous cameras was brownish. Note that the Merrill cameras dont have any AFE, so the bluish tint probably is a real artefact, and not due to some amplification.
Re: Yes
Nope.
I would love to see the DP2M put through tungsten next to a DP2 as a curiosity for this. But to be honest if that's what happened, I think I rather have better splotch-free daylight performance.
I wonder why they removed the AFE or why they thought the AFE would be better to begin with (or maybe it is- I never quite understood that- except that it seemed to band).
Anyhow, really hoping SPP monochrome allows good B&W into the high iso.
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
Re: Yes
Yes, me to, on both accounts. I could live with a non tungsten camera. Even Bayer cameras are really not good at tungsten, and produce best yellowish images. If you try to compensate they normally look bad.
The main reason for AFE is the limited dynamic range of the A/D converter. There is some information down in the noise, even below the least significant bit.
But ... the Foveon chips has quite high noise and quite low DR (contrary to what many here claim). Then AFE might only introduce problems. A shhotout between a DP2s and DP2x would be interesting.
It should. B&W high ISO done normally is already better than color images from Foveon cameras.
Re: SD-1 is cleaner, but you need to expose differently
I thought the old cameras had problems with the shadows, requiring exact or even some over exposure.
Can you point to any measurements showing this?
Snow should always be over exposed, one or even two stops.
But, you claim that normal shots also shall be over exposed some? In that case it hints at Sigma being somewhat too optimistic regarding to ISO number.
(unknown member) Senior Member • Posts: 1,857
When shooting at ISO 200 i mostly overexpose with the "Merrills"
For example this image:
Overexposed by 1 stop, highlights can easily be recovered in SPP and i don't have to push shadows.
Maceo
Johan Borg Senior Member • Posts: 2,673
I think Kendall is maybe proving your theory with a real life example:
The older cameras had better red/brown tone detail than the Merrill, the kind of color that often exists in shadows in nature. Thus, overexposing prevents these areas to go monochrome when pushed.
I'm not sure the dynamic range is very different between the generations, my DP2 and DP2M feel rather similar in practice, but the SD15 is completely different from both of them in that it has less highlight headroom.
He can do that of course.
That might be right. It seems like the blue layer is thicker in the Merrill sensor.
As far as I know, the SD15 is optimized for color accuracy. Due to the strange RAW color space of Foveon sensors, I think that it was possible to do some tricks that extracted more dynamic range in older cameras. Those tricks offered some color accuracy.
xpatUSA
Here y'are, not to scale though:
SD1
The noticeable thing about the Merrill is the reduction in transistor count, according to ChipWorks, IIRC.
Ted
Foveon F7X3-C9110
Not that I found, beyond that old adage of "expose to the right" always being a good idea for any digital camera.  With the Merrill sensor, you want to go a bit more if you want the most DR from an image.
Forum search.  You even posted in the thread. It was some photography website somewhere, months back.
Or just look at the DPreview info.
http://www.dpreview.com/reviews/sigmadp1/11
http://www.dpreview.com/reviews/sigmasd1/12
Even with the SD-1 testing at ISO 100 it still showed more DR than the DP-1, although it's hard to compare those two pages exactly...
Of course there is also the fact that everyone who has shot both cameras for a while says the same thing.
Of course, I mean about +0.7 more than whatever exposure compensation you would apply normally for the scene.  That's why I was saying +1.7 for that scene would yield better results.
It's not required if you have limited range in an image.  It's just a good general setting since most images shot during the day have full sun mixed with deep shadow, to get the most possible DR.  The metering is probably trying to be conservative (as it is in most cameras) to make sure JPG highlights do not clip.  In the end even with +0.7 you are getting better shutter speeds than with the older cameras since you use that in conjunction with ISO 200.
