GPS10 unit worth to buy? Some deals on NX gear too.
Started Jan 10, 2013 | Discussions
supeyugin1 Contributing Member • Posts: 912
I noted that GPS10 unit is available at Adorama at $99, which is half price. Is it worth to buy?
I also noted some other deals at Adorama, like 16mm black is $249, white is $199, 20mm is $199, NX210 is $499
 supeyugin1's gear list:supeyugin1's gear list
Canon G9 X II Fujifilm XF10 Samsung NX mini Pentax Q-S1 Panasonic G95 +14 more
Samsung NX210
Knallberto Veteran Member • Posts: 5,478
Re: GPS10 unit worth to buy? Some deals on NX gear too.
No, it isn't worth. Buy any small GPS tracker for $50 - you can use it for EACH camera, 100.000 till some millions trackpoints.
armin304 Contributing Member • Posts: 740
I agree, I own it...
It's big (It needs 2 AAA cells), unreliable, slow and badly implemented. Nevertheless. I will most probably use it again in my next holidays. Shame over me...
 armin304's gear list:armin304's gear list
Nikon Coolpix P900 Sony a7 II Panasonic Lumix DC-GX9 Nikon Z6
GPS10 unit makes few sense ...
€ 80/100/150
Bluetooth included, rechargeable, 32mb-64mb memory - with mSDHC card some millions waypoints
price €30 - €60
my GPS trackers ... 100.000 - 400.000 waypoints, power for 24 hours up to one week
battery AA only for size comparing - all have built in power
GPS data written to photos with one mouse click.
MOD Taffy Veteran Member • Posts: 5,020
Re: GPS10 unit makes few sense ...Hi Knallberto, a few questions for you, please.
Knallberto wrote:
€ 80/100/150
price €30 - €60.
Hi Knallberto, why do you own so many of these agps data loggers? Is one, better than the others, and does the same software work with all the differemt devices?
GPS data written to photos with one mouse click. Does this software work with the different devices, or does one have to have a different application for each individual device?
Have a good day.
Regards, Allan.
jonathanj
jonathanj Contributing Member • Posts: 999
I didn't realise it was that simple! I must be behind the times. Couple of questions:
- Are there any brands you'd recommend or not recommend or is just best to buy the cheapest available?
- Do they work well in cities? I ask because my phone GPS drifts alot in dense urban areas with lots of tall buildings
 jonathanj's gear list:jonathanj's gear list
Panasonic Lumix DMC-GX85 Sony a7R III Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH +8 more
Re: GPS10 unit makes few sense ...Hiya Knallberto, could you answer some questions please?
Hi there, Which of these GPS units that yu are showing, is, in your opinion, the best? Is the one that you recommend, the best build quality, or just the best at detecting the GPS? Do they all use the same program to link to the photo's, or do you have to have different interfaces for each unit? Thanks, in advance for your assisstance.
Have a good day.
Regards, Allan.
Each unit has advantages/disadvantages - memory, battery power, price, precision, chipset, software, up to more than 50 satellites ... for photography you can use each of them - switch on and put it in your pocket or photo bag.
It's all the day long active, you must not wait for sat connections, it writes/documents your route, it needs no power from your camera.
I like most the cheapest one - GT730 - USB connector, 256.000 way points, up to 65 satellites .. €30
http://www.voelkner.de/products/233927/GPS-Datenlogger-Gt-730-mit-Akku.html
Re: GPS10 unit makes few sense ...Hiya Knallberto, thank you for
your insight into these devices, greatly appreciated mate.
Have a good day.
Regards, Allan.
