Adding a Function To a Button:D800
Started Jan 4, 2013 | Discussions
Paul Spatafora Contributing Member • Posts: 944
Is there anyway to program a function button on the D800 to switch from FX to DX and back again? I'd like to program one the buttons to do this, but so far the only method I can find is to go through the menu system.
Any help would be greatly appreciated.
Paul
Nikon D800
Epic Light Regular Member • Posts: 231
Re: Adding a Function To a Button:D800
Paul
Yes you can.  custom settings under controls.  It's the purple section I think.
d800e, 16-35vr, 24 pce, 28g, 50/1.4d, 85/1.4g, zeiss 21
gitzo 5531s, RRS bh55,
sb910, 3 sb900s, 3 sb800s, 6 vintage vivitar 285hv, 3 PW flexttl, PW minittl, PW AC3
nikon j1, 18.5/1.8
sony RX100
"always just one light modifier away from greatness"
OP Paul Spatafora Contributing Member • Posts: 944
Paul
nikon j1, 18.5/1.8
sony RX100
YES!!!! I found it! Now only if it the unwanted area could ne shaded out!
Thanks again.
Paul
frank-in-toronto Senior Member • Posts: 1,034
Paul
Thanks again.
Paul
it's a weird way to do it but very possible.  you could do a search for "nikon dx mode greyd" and find a bunch of links.  on my d600, setting a4 AF point illumination" to "OFF" makes the outside part grey when in DX mode.
Thanks for everything! I found out how to implement the masking feature! It greatly enhances the cameras capabilities!
Thanks again.
Paul
Nigel45 Junior Member • Posts: 31
Thanks again.
Paul
ok, spill.
 Nigel45's gear list:Nigel45's gear list
Canon PowerShot G5 Nikon D70 Nikon D800E Fujifilm X-E2 Nikon AF-S Nikkor 50mm f/1.8G +6 more
Found it - but don't know why one is dependent on the other????
OldDigiman Senior Member • Posts: 1,960
Nigel, will you explain?  Thx.
___________________
ODM
www.ahfairley.com/gallery/index.html
www.olmstedactupuncture.com
___________________
ODM
Never mind, got it.  Set Crop mode in shooting menu, set AF illuminatiion off in settings menu.  It's a real shame the files get cropped in the captures, it would be nice to have the option to set a VF crop (eg, 4x5) and still capture the whole sensor to RAW, so you could fix slight mis-framings.  As in the Sony RX100 which will shoot in 4:3 mode but will capture the entire 2:3 sensor area in raw. Since I end to crop to 4:3 when I print, I am thinking of pysically masking the ground glass in the D800.  (Back in film day, I scribed 8x10 crop lines on my F3 ground glass -- a lot easier to do since it was designed to be interchangeable.)
___________________
ODM
