17-40mm f/4L vs 16-35mm f/2.8L
Started Dec 26, 2012 | Questions
psychoticpanda New Member • Posts: 22
Okay so I need some serious help, I am new to the forums so I very much apologize for a possible repeated question but I feel it is a on person to person basis for a lens decision so here goes nothing...
I have a newly bought Canon 60D and I'm looking for a new everyday lens for both photos and video. I want to get a higher quality lens compared to what I have now (50mm, 18-55mm, 70-300mm) but they aren't doing it for me.
What I am looking for out of a new lens:
  1. Better image quality then my standard outdated lenses.
  2. Wide angle for both portrait and landscapes (and portrait videos)
  3. A lens which will make me look the next level of professionalism because these small lenses aren't cutting it. (Not so important, haha)
I may be asking for too much in one lens, but can you please tell me what the difference is in these two lenses that makes one double the price? I am no pro at photography but I am not a beginner either. Although I do not know much about lenses, I know more about setting up a shot then anything else. Please help!
If you can suggest any other lens which is good for everyday use that would be great too. I can afford the 17-40mm right now but I will have to wait a little longer for the 16-35mm lens. Any other info you need to know just ask because I feel like I am forgetting a few things since it's so late right now...:-P
 psychoticpanda's gear list:psychoticpanda's gear list
Canon EOS 450D Canon EOS 60D Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS Canon EF 70-300mm f/4-5.6 IS USM +3 more
Gearóid Ó Laoi, Garry Lee
Gearóid Ó Laoi, Garry Lee Veteran Member • Posts: 6,490
Re: 17-40mm f/4L vs 16-35mm f/2.8L
Some years ago one of the photo mags compared them and concluded that quality-wise, at working apertures, there was no significant difference. I don't use wide angle much but I find the 17-40 quite adequate. I've never had the other. I do have the 20 f2.8 and think it's excellent
Níor bhris focal maith fiacail riamh (Irish Gaelic)
A good word never broke a tooth.
 Gearóid Ó Laoi, Garry Lee's gear list:Gearóid Ó Laoi, Garry Lee's gear list
Canon PowerShot S90 Fujifilm X10 Panasonic FZ1000 Sony Alpha NEX-7 Canon EOS-1D X +30 more
wolfbane Senior Member • Posts: 1,724
Hello Psychoticpanda,
Got the 17-40 and the EFS 60 macro and they cover a lot of subjects in which I am interested.
The 60 is pretty good as a moderate telephoto lens, while giving macro capability, although maybe  I ought to splash out on the 100! But at 72, how much weight am I willing to carry?
Consulted Photozone.de before I decided which lenses to use with the 7d.
No experience with other Canon lenses (Nikon convert) but am a very happy amateur shooter. You may find the 17-40 perfectly adequate as long as you are happy with APC format.
The 7d quickly persuaded me I had no need of FF! Alistair
Kevin Jorgensen Contributing Member • Posts: 745
I have the 16-35f2.8L II and like it a lot. I found this a very interesting read. Very surprised by the fact the 16-35 was the most used zoom.
http://www.petapixel.com/2012/12/02/the-most-popular-cameras-and-settings-for-reuters-best-photos-of-the-year-2012/
 Kevin Jorgensen's gear list:Kevin Jorgensen's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Samyang 14mm F2.8 ED AS IF UMC +2 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
On a 60D NEITHER of those.
You should buy lenses that are optimal for the camera you have. For 'normal zoom' on the 60D, the only advantage those two L lenses have over EF-S lenses is build quality. Or dual use only if your primary camera is 1Ds/1DX/5D.
The EF-S lenses (or Sigma DC or Tamron Di II) have as good (or better) image quality, have IS, have greater zoom range, have same or greater max. aperture.
Instead of the 17-40/4L or 16-35/2.8L you should instead be choosing between EF-S 17-55 f/2.8 IS USM, Sigma 17-50 f/2.8 EX DC OS HSM, or Tamron 17-50 f/2.8 XR Di II VC. Any of those would also give you your "look" as they are larger (77mm diameter front element). Getting and using the lens hood (comes with the Sigma and Tamron lenses) also goes a long way to making you look like you know what you're doing.
The image quality of the EF 70-300 f/4-5.6 IS USM should not be letting you down. But upgrade to that lens would be Tamron 70-300 f/4-5.6 Di VC USD, any of the EF 70-200 Ls, or the EF 70-300 f/4-5.6L IS USM.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
qianp2k Forum Pro • Posts: 10,350
First of all, I have to say these two lenses are mainly for FF bodies. You're better to consider EF-S alternative for your 60D - 17-55/2.8 IS, 15-85/3.5-5.6 IS, Sigma 17-50/2.8 OS (that I bought for my 60D), 10-22 UWA.
Now if you're still interest between these two L lenses and might consider to move to FF soon, you choose between these two based on you priority - do you need f2.8, do you care (slight) better IQ at edges/corners, weight/size, price.
I chose 17-40L.  Its IQ is quite good especially you stop down. Canon is due to upgrade both lenses especially 17-40L as Nikon did. Nikon relative new 16-35/4.0 VR IQ beats both Canon lenses at f/4 and it has VR.  Also this 17-40L is pretty sharp on my 60D that actually slightly edge out Sigma 17-50/2.8 OS at f/4.0.  But I used Sigma as it has F2.8, it has'OS' and longer range.
http://www.dpreview.com/galleries/7843305573/albums/17-40l
17-40L on 5D2
gipper51 Veteran Member • Posts: 5,904
The IQ of both lenses will be excellent on your camera.  The choice really comes down to f2.8 vs. f4 , size and how deep your pockets are.
That said, I would not buy either of these lenses unless you plan on getting a FF camera down the road.  If not you really should look in to one of the APS-C standard zooms a poster above mentioned.  Greater zoom range, IS, and less money for f2.8.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
OP psychoticpanda New Member • Posts: 22
I have always been confused to what to do in this situation because I want a great lens, but then I realize it will be somewhat wasted with the crop sensor and wasting money unless I plan to purchase a mark d in the near future. I just got the 60d and it is not my full profession, more of a hobby or aid to my graphic design desires.
So do you think I should get the EF-S compared to a EF lens? I mean I know lenses usually last a while but camera bodies only a few years before they are outdated. I just don't want to have to invest in another few lenses that won't fit a FF camera in the future.
Now that I am thinking about it, I may just pick an EF-S lens and save some money, then worry about the EF exclusive lenses when I get there. Any suggestions comparable to the lens I mentioned? Or even any general suggestions to use as an everyday lens for walking around the city...? Thanks everyone!
gdanmitchell
gdanmitchell Veteran Member • Posts: 7,991
Neither the 17-40 nor the 16-35 are your best choices on your 60D cropped-sensor camera.
The 17-40 is a fine lens for small-aperture, tripod-based photography of subjects such as landscape, architecture, or similar on full frame cameras, where its stopped down performance can be very good. I own the lens and like it a lot for these purposes. However, I once used it on cropped sensor cameras and was not so impressed. Its center sharpness was quite good, but at f/4 there were corner softness issues, and they even affected some f/8 photographs. The problem here is that due to the different way that diffraction blur shows up in cropped sensor images, you don't want to stop down beyond this much, at it is at f/11 and f/16 where this lens truly comes into its own.
The 16-35 f/2.8 L is also a fine lens that is best used for hand held, low light, ultra-wide full frame shooting. it could be fine on a cropped sensor body, but it is not the best option.
The EFS 17-55mm f/2.8 IS is a better choice that either of these for your camera. It provides the f/2.8 maximum aperture of the 16-35. Its image quality is at least equal to and in many ways better than that of the L lenses on your camera. It has a larger focal length range. It includes the useful IS feature.
Price alone is not always the best indication of what lens is "best" for your purposes. In this case, the best lens for you is almost certainly the one in the middle of the price spread.
jrarsenault Senior Member • Posts: 1,151
I would strongly suggest getting the Canon EF-S 17-55 f/2.8. I bought this lens for my 7D and it was my go-to workhorse lens for most of the time that I owned the 7D. If you plan to sell your 60D and head towards the full frame world or stay in crop land, I would get the 17-55 regardless. In the case that you do decide to venture into full frame territory, the 17-55 is an easy lens to sell.
A second suggestion would be the Canon EF-S 15-85 f/3.5-5.6. IMO it is a close second to the 17-55 closely matching it in sharpness and IQ. The major difference is its low light capability and focal length.
The 17-40 and 16-35 are fine lenses, however they wouldn't add much value over the 17-55 or 15-85 lenses other than build quality and a red ring. If you truly want a 'wide' lens, I would advise that you consider the Canon EF-S 10-22, Sigma 8-16, Sigma 10-20 or the Tokina 11-16. All are excellent lenses with several satisfied crop users.
Yes, I would go with an EF-S lens.  The Canon 17-55 IS is probably the absolute best one, but also the most expensive.  There are several very good alternatives from Sigma and Tamron for significantly less money.
Reading the reviews of these lenses on this site might help with your decision:
www.photozone.de
http://darwinwiggett.wordpress.com/2011/05/09/sigma-17-50mm-f2-8-vs-canon-17-55mm-f2-8-and-tamron-17-50mm-f2-8/
http://photo.net/equipment/canon/efs17-55/
I personally picked up Sigma 17-50/2.8 OS as a walk-around lens for my 60D after carefully read several reviews (such as two above) and after read many owners' experiences. I used it to cover my entire trip of Disney parks last year together with 70-200L/4.0 IS with pretty good result for example. I appreciate constant f/2.8 in low light that I shoot virtually exclusively hand-held in evening.
http://qianp2k.zenfolio.com/f975306243
You choose EF-S 17-55/2.8 IS - It's Canon first and keep value better down to the road. But it's overpriced on my opinion. It's slightly better than Sigma version in edges/corners at f/2.8 (but I don't bother by dim corners/edges in low light when I only need to shoot F2.8 in my usage). It has FTM (full-time manual overrun that is not really a big deal on my experience with Sigma copy). It has extra 5mm at tele-side.
You choose Sigma 17-50/2.8 OS - $400-450 cheaper with lens' hood included, a huge deal to me. It has very similar IQ as Canon copy if not slightly sharper in center at f/2.8 and beyond f/8. Arguably it also has better build.
You choose EF-S 15-85 because it's 15mm at wide side (that equivalent to 24mm on FF that is noticeable wider than 17mm) and 85mm at tele-side but it's slow in low light. It has latest 4-stop 'IS'.
To OP: you choose based on your priority - range vs low light with other factors - price and weight and if you will upgrade to FF in near future.
www.photozone.de
ak1999 Contributing Member • Posts: 542
I've used 24-70 and 24-105 on my 60D before and I noticed that images were softer than ones from kit lens 18-55mm.
I also tested 17-40 lens against 18-55mm kit lens on another APS-C body and had similar result.
I believe that these older full frame lenses are not up to resolution of modern cropped sensors.
The newer 24-70II (and maybe 24-70F4) may work better with cropped sensor cameras and higher resolution full-frame sensor camera which I expect Canon to offer one next year.
Dave Throgmartin
Dave Throgmartin Contributing Member • Posts: 878
Most people suggest you use EF-S lenses on APS-C cameras, but I've been using 17-40 on a crop body (60D) and honestly it's been a revelation for me.  Images are sharper and have more pop than 18-135 IMO.  I've got a bunch of them at:
http://www.flickr.com/photos/68255851@N05/tags/1740/
I'm sure 15-85 and 17-55 are both good lenses although I haven't used them.
This guy likes the 17-40 too. He did a direct comparison versus 15-85.
http://www.parkcamper.com/17-40-versus-15-85IS/Canon-15-85-versus-17-40L-comparison.htm
My comments are the minority so take them with a grain of salt.
Dave
Wow so I am between about 5-10 different lenses now. Someone please help me narrow these down!
The possible candidates are...
  1. Canon EF 17-40mm f/4L USM
  2. Canon EF 16-35mm f/2.8L II USM
  3. Canon EF-S 17-55mm f/2.8 IS USM
  4. Canon EF-S 15-85mm f/3.5-5.6 IS USM
  5. Sigma 17-50mm f/2.8 EX DC OS HSM FLD
  6. Any of the other mentioned lenses
By the way my budget is "about" 1000$ so please don't offer top shelf lenses unless there is a great reason to invest in it... Thank you to everyone who has assisted me, I was very lost before finding this forum! You are all a huge help in the buying process of a new lens. Thanks
Lenny_D Forum Member • Posts: 55
Hi, I would like to  suggest yet another lens: the Canon10-22mm EFS. On a crop sensor camera, this lens has the same FOV as a 16-35 on a FF camera and is a true joy. Its image quality is excellent and you'll be surprised about its versatility and the creative shots you can make with it. It quickly became my favourite. Just go to a shop and try it! It is really fantastic.
Lenny
 Lenny_D's gear list:Lenny_D's gear list
Canon PowerShot S90 Canon EOS 20D Canon EOS 6D Canon EOS M6 Canon EF 50mm F1.4 USM +5 more
rebel99 Veteran Member • Posts: 4,025
i have a 17-40mm f4 and have been enjoying the excellent photos it produce's for a long time. contrary to common nonsense i hear about using this lens on a FF camera, i have used mine on a 40D and have gotten much better result instead of my 5D! from the test results i have read, 17-40 produce's the same IQ as the more expensive 16-35mm f2.8 with exception of one click faster aperture and a lot less in price!
cheerz.
cheerz.
Although I don't recommend 17-40L on APS-C as there are better alternatives in overal performance, my copy of 17-40L is very sharp on my 60D and actually slightly edges out Sigma 17-50/2.8 OS and 24-105L when I tested indoor on a dollar bill or outdoor among three lenses on 60D. But I picked up Sigma 17-50/2.8 OS as it has F2.8 that still sharper at least in center, 'OS' (Sigma version of 'IS') and longer range but also a bit heavier than 17-40L.
Some test shots from 60D with 17-40L before I got Sigma 17-50/2.8 OS.
cheerz.
Nobody said it is a bad choice.  Many said there are better alternatives (more range, f2.8, cheaper) designed for APS-C. I've used my 17-40 on crop bodies and it performed great, but I would take the crop lenses instead if it were my primary body.
arty H Senior Member • Posts: 1,546
I recommend considering the Canon 24-105L. My copy has looked sharper, with better contrast, than the 17-40 I just got. The range is excellent. If you want a wider lens, then the 17-40L will give you that. Both of these lenses are under your price limit. I see a bigger improvement over the 18-55IS with the 24-105L than with the 17-40L.
The only reason for getting the 16-35 would be for the F2.8.
If you will never go full-frame, then you might consider the 17-55IS. It is a fine lens and has F2.8. I use a 60D, but plan to get a full-frame camera soon. If I didn't want to go this route, I'd probably be interested in the 17-55IS. I like the range of the 15-85IS, but not the F5.6 at the long end.
I should point out that you see more for your money when you get a good fast prime. I have the 35F2, and it gets used a lot. If I didn't have the older version (now $290), I'd be in the market for the new 35F2 IS.
