Canon Extenders don't fit 70-300 f4-5.6L IS ???
Started Dec 21, 2012 | Discussions
Dave Seeley Senior Member • Posts: 1,760
I just got my extenders delivered today, and clearly they do NOT fit the lens, as the rear element is far too shallow to accept the extenders.  I thought i'd heard otherwise in an on line review, and this shows it with the 2x iii, on The Digital Picture.
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=738&Camera=453&Sample=0&FLI=6&API=0&LensComp=687&CameraComp=453&SampleComp=0&FLIComp=3&APIComp=2
It's the 2x and 1.4x version iii extenders I am trying out.  Is there something else for this lens?
Dave
pro photo-illustration
http://www.DaveSeeley.com/
current kit: 5DmkIII, 17-35/2.8L, 28-70/2.8L, 70-200is/2.8L II, 70-300/4.0-5.6L is, 100 macro/2.8L, 50/1.2L, 2x II extender, 8x550ex Speedlites, Phottix Odin Flash Triggers
 Dave Seeley's gear list:Dave Seeley's gear list
Canon EOS 5DS R Canon EOS R Canon EOS R5 Canon EF 50mm f/1.2L USM Canon EF 70-200mm F2.8L IS II USM +8 more
jbjones Regular Member • Posts: 411
Re: Canon Extenders don't fit 70-300 f4-5.6L IS ???
 jbjones's gear list:jbjones's gear list
Canon EOS 60D Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 2x III Sigma 35mm F1.4 DG HSM Art
Lemming51
Lemming51 Forum Pro • Posts: 15,278
before you send them back ...
You can't just go by the abbreviations on the ISO-12233 page, you have to read the review:
http://www.the-digital-picture.com/Reviews/Canon-EF-70-300mm-f-4-5.6-IS-L-USM-Lens-Review.aspx
"The Canon 70-300 L is officially NOT compatible with Canon extenders. This is the only Canon L zoom lens with a widest focal length of 70mm or longer that is not compatible with Canon extenders (as of review time). I've tried mounting Canon extenders to the 70-300 L - and they do not fit. The rear 70-300 L lens element physically hits the front element of the extender.
"Then, in a major firmware update announcement for the Canon EOS 1D X, Canon included the 70-300 L and Canon EF 1.4x III Extender combo on a compatibility list. Intrigued, I did more experimenting. What I learned is that the 70-300 L's rear element retracts into the lens far enough that, at about 250mm, there is enough clearance for Canon extenders to mount.
"The available with-1.4x focal length range is about 350-420mm and 500-600mm with the 2x installed. Zooming out wider than the 250mm-or-so zoom ring mark results in a physical bump inside the lens. I'm guessing that it is the rubber around the edge of the extender element contacts the rear 70-300 L lens element or its barrel. I do not recommend mounting this combination due to potential damage the to lens. ..."
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
OP Dave Seeley Senior Member • Posts: 1,760
Re: before you send them back ...
Thanks Lemmings51...  that certainly explains it.
Dave
Loren Charif Veteran Member • Posts: 3,759
Some have had success with the Kenko PRO DGX 1.4 TC.  I use it with a 7D, and find it works best with the outer focus points (contrary to my expectation that center point would work best).  IQ is good (but probably not as good as the naked lens and cropping the image).  Some hunting, especially with the inner focus points, but the hunting isn't bad if you pre-focus the lens close to the subject.
Loren
SportsClicker New Member • Posts: 2
It appears to be Canon EF extenders are only for those costly lenses. Canon says "If you want to use our extenders you need to be worthy enough to buy our costly lenses".
Each lens in the compatibility list for both 1.4x and 2x are $1500 and above.
 SportsClicker's gear list:SportsClicker's gear list
Canon EOS 70D Canon EF-S 17-85mm f/4-5.6 IS USM Canon EF 70-300mm f/4-5.6 IS USM
Lee Jay Forum Pro • Posts: 56,673
Have a look at these and see if it makes sense:
70-300:
70-200/2.8L IS II
100-400L II:
Note the distance between the back of the lens and the rear lens element. Also note that the Canon extenders protrude inside the lens:
2x TC III:
1.4x TC III:
Lee Jay
 Lee Jay's gear list:Lee Jay's gear list
Canon PowerShot SX50 HS Canon EOS 7D Mark II Canon EF 70-200mm F2.8L IS II USM Canon EF 8-15mm f/4L Fisheye USM Canon Extender EF 2x III +10 more
Geronimo73
Geronimo73 Regular Member • Posts: 201
Well, this is the only reason why I sold mine... But otherwise, this lens was my first >1K$ L lens and I truly like it. Since that, I bought several more expensive L lens and never regret it.
Also remember that many cameras are not made to focus well with extenders. Something about the focus point beyond f/8 (1.4 extender + f5/6)...
 Geronimo73's gear list:Geronimo73's gear list
Canon EOS R6 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 50mm F1.8 STM Canon Pixma Pro-100
Hinder Contributing Member • Posts: 819
I have the Kenko PRO DGX 1.4 and use it with the 5D3 and the SL1 combined with the 70-300L, works great.
 Hinder's gear list:Hinder's gear list
Canon EF 50mm F1.8 II Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6L IS USM Canon PowerShot S100 (2000) Canon PowerShot SD500 +21 more
underpaid Contributing Member • Posts: 603
That's strange. I used a Canon 1.4X extender on a Canon 70-200 F4 and it worked just fine. That lens is about HALF the price of the 70-300L. Were you quoting Canon there or are those your words?
I used to be indecisive, but now I'm not so sure.
p5freak Senior Member • Posts: 2,998
Not true. There are plenty of lenses below 1.5k :
135 f2
180 f3,5
200 f2,8
70-200 f2,8
70-200 f4
70-200 f4 IS
300 f4 IS
Stupid is as stupid does - Forrest Gump
70-300:
70-200/2.8L IS II
100-400L II:
2x TC III:
1.4x TC III:
Thanks a lot, I only have 70-300 f4-5.6 IS USM, which is never going to accommodate those extenders. I will have to wait till I get a 100-400 f4-5.6L IS USM.
