Cracked plastic "window" on EF 70-200 2.8L IS USM ... should I be concerned?
Started Dec 20, 2012 | Discussions
DCWC12 New Member • Posts: 3
On my EF 70-200 2.8L IS USM lens, the small plastic "window" just to the left of the black "70-200mm" marking on the top of the lens that shows the 'Distance scale', 'Distance index', and 'Infrared index' is cracked.  I dropped a small plate on it it cracked.
Overall, there is nothing wrong with the lens, it works fine. I would simply like to understand if I should be concerned about this crack, if it in any way compromises the lens, and what it might cost cost to repair.
I'm new to the forums and this is my first post.
Thanks!
happysnapper64 Veteran Member • Posts: 5,421
Re: Cracked plastic "window" on EF 70-200 2.8L IS USM ... should I be concerned?
First, welcome to the forum. My reply would be "yes". It is an expensive item, I bought the f/4 version because I could not afford the 2.8. It is expensive for a number of reasons, one being that it is weatherproof, meaning that you can use it outdoors when the weather is, shall we say, less than perfect. It will be risky getting it wet now. Not only rain damage but taking it from a cold envirament outside to a warm house will cause damage with condensation. These things don't fix themselves, & I have never had to have a repair done on a lens, but the cost of a repair will be far less than a new lens.
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 5D Mark II Canon EOS 7D Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM +6 more
Gearóid Ó Laoi, Garry Lee
Gearóid Ó Laoi, Garry Lee Veteran Member • Posts: 6,496
I would find out from a Canon repair centre, how much it cost to replace. If very expensive, I would use colourless silicon sealant or suchlike on it. Somebody's got to have tried that. Google it.
 Gearóid Ó Laoi, Garry Lee's gear list:Gearóid Ó Laoi, Garry Lee's gear list
Canon PowerShot S90 Fujifilm X10 Panasonic FZ1000 Sony Alpha NEX-7 Canon EOS-1D X +30 more
msowsun
msowsun Contributing Member • Posts: 744
You could try ordering the parts from Canon and replace it yourself.
You can also get replacement windows on ebay: Canon focus window replacement
The window is secured in place with a specially made "window tape":  Window Tape
You might be able to find the parts at USCamera if your local Canon Parts supplier doesn't have them.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
OP DCWC12 New Member • Posts: 3
This is very useful information.  I didn't even know that this was possible.  I will surely check it out.  Thanks!
Has anyone here replaced a window on Canon lenses?  Is it a difficult endeavor?  Any tips or pointers?
hotdog321
hotdog321 Forum Pro • Posts: 21,150
No.
I had the exact same issue on my 70-200 f/2.8 IS. I just kept using the lens as normal until I had a REAL issue (the barrel sections started getting loose and there was no way to tighten them), then sent it off to Canon and had them fix the whole shebang at once.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
