field of view m4/3 vs APS-C
Started Dec 20, 2012 | Discussions
tamras29 Regular Member • Posts: 441
Sorry if this has been asked before, or it's the wrong place to do so, but a a landscape lover, will swapping from M4/3 to APS-C give me a wider field of view for any given "28mm equivalent lens".
I have a 14-45 (28-90) on my M4/3 - looking at Fuji XE1 with 18-55 (27/82.5) - OK 1mm more but does the wider aspect ratio of APS-C effectively give more field of view?
Many thanks
 tamras29's gear list:tamras29's gear list
Ricoh Caplio GX100 Fujifilm X-E2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +2 more
Fujifilm X-E1
bartjeej Regular Member • Posts: 328
Re: field of view m4/3 vs APS-C
Many thanks
Using the Pythagoran theorem you can calculate that for any 3:2 sensor with a given diameter, a 4:3 sensor with the same diameter will have a width (and horizontal field of view) of 0.96 the 3:2's width / fov, and a height (and vertical fov) of 1.08 the 3:2 sensor's height / vert. fov.
So, a 28mm equivalen lens on a 3:2 sensor will have the same diagonal field of view as a 14mm lens on a m43 sensor, but for the horizontal fov to be the same, you'd have to use a lens of 14mm*0.96 = 13.46mm. That would mean the diagonal fov of the 4:3 lens would be the same as on a 27mm equivalent lens.
Similarly, if you wanted the vertical fov to be the same as a full frame's 28mm, you'd need a lens of 14mm*1.08 = 15.14mm, which has the same diagonal fov as a 30.3mm lens on a full frame sensor.
To answer your specific question, a 27mm equivalent lens on a 3:2 sensor would have the same horizontal FOV as a 25.9mm equivalent lens on a 4:3 sensor (so that'd be a 13mm lens on a m43 camera).
dfstarman
dfstarman Contributing Member • Posts: 535
The crop factor on apsc is either 1.5 or 1.6 depending on the sensor the 4/3 is 2.0
so 28mm x2 on 4/3 =56mm
28mm on apsc x 1.5 =42mm
 dfstarman's gear list:dfstarman's gear list
Sony RX100 Sony Cyber-shot DSC-HX50V Sony SLT-A77 Fujifilm X-Pro1 Olympus E-M1 +30 more
Tazz93
Tazz93 Senior Member • Posts: 1,930
I guess they are both saying there's a difference, but I'm curious why you want to limit yourself to a crop cam? I have APS-C and H cameras and would not consider using the C for landscape anymore. If its a cost based decsion consider a cost friendly FF alternative, especially if you ejoy shooting landscape.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 350D Canon EOS 7D Mark II Canon EOS 5DS Canon EF 50mm f/1.8 II +19 more
