RX100 Performance Question
Started Dec 19, 2012 | Questions
felicity Regular Member • Posts: 258
How well will this camera perform with moving subjects?  I have the SLT-33 and the 50mm f1.4 prime lens to take pictures indoors of puppies.  Will the RX100 work for this purpose?  Thank you.
 felicity's gear list:felicity's gear list
Sony RX100 Sony RX1 Sony RX100 IV Sony SLT-A33 Panasonic Lumix DMC-GM1 +1 more
Sony RX100
RezaTravilla
RezaTravilla Regular Member • Posts: 305
Re: RX100 Performance Question
Performance of the AF?
The is focus tracking so there is no problem with it.
 RezaTravilla's gear list:RezaTravilla's gear list
Nikon D300S Olympus E-M5 II Olympus PEN-F Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +5 more
BertIverson Veteran Member • Posts: 3,795
No real answer here since I do not own the A33. However, the A33 has full time PDAF which might be faster than CDAF on the RX100. Furthermore, your 50mm f1.4 (75mm Eq) is more than 3 stops faster than the RX100 lens so the possibility of faster shutter speeds / lower ISO. The larger sensor of the A33 probably is a bit less noisy (however, sensor technology moves up quickly and the RX100 has the latest). My best guessis the A33 probably somewhat better for your application. (but the RX100 fits in your purse very nicely  )
Disclaimer -- I own the RX100
Bert
 BertIverson's gear list:BertIverson's gear list
Sony RX100 Sony RX10 IV +5 more
Dennis12345 Regular Member • Posts: 287
The RX100 is a point and shoot, albeit a terrific point and shoot. It is not best suited for subjects that move in unpredictable ways. A DSLR wins here. Just my observation.
 Dennis12345's gear list:Dennis12345's gear list
Ricoh GR Digital II Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8
I thought that is what I said.
Albeit, with suggestions as to why I thought the A33 would be the better solution.
Bert
stdavid Senior Member • Posts: 1,842
The only way you will ever know for sure is to try it. Go to a store with a return policy if you have one in your area and put the RX 100 thru it's paces.
In the end it is the only way to be sure the camera does what you want it to do and fills your needs.
Quote: Experience is simply the name we give our mistakes Oscar Wilde
felicity --- RX100 Performance Question
stdavid,
I think your post was aimed at OP Felicity
Bert
OP felicity Regular Member • Posts: 258
Thanks.  I wasn't sure if the larger sensor of the RX100 would compensate for the the lens being not quite as fast.
Re: felicity --- RX100 Performance Question
stdavid,
Bert
I was indeed Bert
Sorry
Yes, true.  I was trying to ascertain if there was even the point of going through the process.  Thx.
h00ligan Veteran Member • Posts: 3,102
Very well in my experience. Certainly better than ally other compact I've owned.
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 7,547
I would not use the RX100 for moving subjects indoors. AF is not good in poor light.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Ricoh GR Canon PowerShot G7 X Fujifilm X-T1 Sony a6000 Fujifilm X-Pro2 +12 more
Pankrac
Pankrac Regular Member • Posts: 121
Hit and miss in my experience
You may get a good shot, but the results are unpredictable. Burst mode could help to a degree. Puppies standing still (do they ever?) would help too. Another option instead of trying to freeze the motion is to try and emphasise the motion blur, but that would take you into a more abstract area. Something like this:
My grandson playing cold and warm weather front
ericN2
ericN2 Forum Pro • Posts: 17,067
With PRACTICE - Patience and Perseverance I'd say..  Yes...
A shot of such kind ALWAYS needs thiose important factors.. even a dSLR.. things that move do NOT often care what YOU're doing..   !!
/eric
Staffordshire, UK
nick_j007 Contributing Member • Posts: 519
Indoor shots with dogs is doable, but you'll need daylight on your subject ideally to allow decent exposure speeds. ISO of up to 800 will enable faster shots with no noticeable increase in noise.
Here's a shot of Max (albeit outdoors) jumping yesterday!
Exif shows:
f1.8
1/1600
ISO 125 (should have gone higher!)
Nick (UK)
