6D GPS and autonomy
Started Dec 16, 2012 | Discussions
Morflex
Morflex New Member • Posts: 11
6D GPS and autonomy
Hi,
A GPS track done with a 6D GPS. 6D is configured to save one point each 5 seconds.
Be carefull, when you turn off the 6D, it continuing to save track ("GPS log" on top lcd screen). For a ~1 hour track, battery start from 68% to 65% so 1 hour = 3% of battery (even if 6D is turned off).
What do you think ?
the log -> http://vincent-thoorens.dyndns.org/12121600.log
Canon EOS 6D
onlooker Veteran Member • Posts: 4,001
Re: 6D GPS and autonomy
Dies it only save in the .log format you posted, or also in the .gpx format?
Morflex
OP Morflex New Member • Posts: 11
it seems that it's only on .log file. But the NMEA format is very easy to understand.
example :
$GPGGA,151350.000,4849.6762,N,00228.3038,E,1,06,1.9,2.0,M,,,,0000*04
$GPGGA = after the $ the name of the line type : GGA or RMC
151350.000 = 15hour13min50sec
4849.6762,N,00228.3038,E = 48°49.6762North    2°28.3038 East
1 = GPS fix
06 = number of satelites
1.9 = horizontal dilution of position (parameter giving the quality of GPS precision)
2.0,M = altitude in meters
0000*04 = Checksum
for more info : http://aprs.gids.nl/nmea/
very easy to use in a soft (geosetter, change .log in .nmea) or excel sheet.
Nigel Wilkins
Nigel Wilkins Senior Member • Posts: 1,006
I'd be leaving the GPS on all the time...as it happens, mine is the w version, so no GPS.  A blessing in disguise for me.
 Nigel Wilkins's gear list:Nigel Wilkins's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 56mm F1.2 R +1 more
Mais78 Senior Member • Posts: 1,161
Morflex wrote:
Hi,
What do you think ?
I have a problem with my battery, it does not last more than 100-150 shots (no GPS). Make sure you don't have the same problem, might not be the GPS.
 Mais78's gear list:Mais78's gear list
Olympus OM-D E-M5 Sony Alpha a7R III Olympus M.Zuiko Digital 45mm F1.8 Tamron SP 24-70mm F2.8 Di VC USD Canon EF 40mm f/2.8 STM +4 more
Wintergreen
Wintergreen Regular Member • Posts: 135
I left the GPS log on sunday and the battery was completely empty on monday evening.
Since then the GPS is off.
 Wintergreen's gear list:Wintergreen's gear list
Nikon D750 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Tamron SP 70-300mm F/4-5.6 Di VC USD Nikon AF-S Nikkor 24-120mm f/4G ED VR +2 more
hiki08 Regular Member • Posts: 143
slightly off topic but I notice your GPS log follows very very nicely along the road on the map..
Comparatively, I've tried logging 2 walks out on the streets of Hong Kong and the log is pretty much not useable. It might be because of the skyscrapers but if it is then it's pretty horrendous a feature. The only part possibly right is the part out in the open at Victoria Park. The rest I'm pretty sure didn't happen that way...
Can't comment on the battery atm as I haven't been paying attention to it. Around 300 shutter count of RAW+L with 2 days of GPS plus lots of playing around with the menu settings I think.
Lawn Lends
Lawn Lends Senior Member • Posts: 1,306
That's a shame, I guess they wanted something left for the 6DII to improve upon, namely the accuracy of the GPS system.
 Lawn Lends's gear list:Lawn Lends's gear list
Canon EOS 6D Canon EOS Rebel SL1 Sony Alpha a7R III Canon EF 50mm f/1.4 USM Canon EF 28mm f/2.8 +12 more
I did some tests myself and GPS+Log at 1m drains the battery at 1% per hour if the camera is not used.My Tamson lense drains it more..
Is the 15 sec refresh really needed? I think 1m is enough
Deak Regular Member • Posts: 152
GPS signals are actually quite weak, it's no surprise that reception is poor between the tall buildings and hills of Hong Kong. Don't forget that reception from multiple satellites is required for a good position fix.
Deak
 Deak's gear list:Deak's gear list
Canon PowerShot S100 Canon EOS 7D Mark II Sony Alpha a7R II Fujifilm X-T2 Canon EOS 5D Mark IV +36 more
