Canon EOS 6D quiet mode: better sharpness?
Started Dec 12, 2012 | Discussions
RStyga
RStyga Regular Member • Posts: 298
Is it correct to assume that the quiet mode (used for discrete shooting by slowing down the mirror/shutter assembly resulting also in lower fps) reduces the mirror/shutter vibration and thus increases sharpness (all other things equal)?
Canon EOS 6D
salamander1 Senior Member • Posts: 1,427
Re: Canon EOS 6D quiet mode: better sharpness?
i don't know if the silent shutter increases sharpness, maybe it does if there is  less vibration, but it's an awfully nice feature to have anyway. i love it too.
JimP Forum Member • Posts: 98
which menu is used to set silent mode?  I see modes for Live View, but not for noon-live view.
thanks,
jim
rndman Senior Member • Posts: 1,595
thanks,
jim
On 5D3 it is part of the AF-Drive (where you set Single shot, Low burst and Hight burst). It is not in the menu.
May be same for 6D..
 rndman's gear list:rndman's gear list
Rokinon 14mm F2.8 IF ED MC Rokinon 8mm F3.5 Aspherical Fisheye
Blastophaga Regular Member • Posts: 109
On 5 D III it makes a real difference at low speed. sharpness is increased.
Finn
Sharky Forum Member • Posts: 77
It's part of the drive selections with the drive button on top - single shot, multi, single Quiet, multi Quiet (Q)
All my photos can be downloaded and used for free: http://freerangestock.com/view_photog.php?photogid=2
(unknown member) Veteran Member • Posts: 5,590
It's a reasonable assumption but to know for sure it would need to be tested at a range of shutter speeds.  It could be that it just shifts the critical speeds at which vibration is most evident - usually somewhere within the range 1/8s to 1/60s with most SLRs.
Esseti New Member • Posts: 8
I think you will get more sharpness by wiping your lens down, or in lower ambient temperatures, that from mirror shake. Especially when you are holding your camera.
I also want the top most sharpness, but this is ridiculous
 Esseti's gear list:Esseti's gear list
Canon EOS 7D
RStyga
OP RStyga Regular Member • Posts: 298
"wiping down your lens"??
It's been an issue with other DSLRs, mirror-slap vibration that is. It's no small thing, especially at borderline shake-free speeds (i.e., 1/FL  +/- 2 stops).
thanks,
jim
hi jim!
what i do is, i turn the live view on. then i go to the af-drive button located  in front of the small lcd panel on the top of the camera.  i press it and the af-drive menu  magically appears on the big live view screen. then i choose "silent single shooting" from the many options there.
