Samsung Galaxy Camera - does the High Speed Video (120fps) have manual shutter options ?
Started Dec 10, 2012 | Discussions
osirisjem New Member • Posts: 8
Re: Samsung Galaxy Camera (aka GC100)
In the specs, I see this Camera has:
  • Shutter speeds go from 1/2,000 second to 16 seconds.
  • 768x512 pixels at 120fps (slow motion)
But can you do both at the same time ?
ie. Does high speed video (120fps) allow for manual shutter setting (ie. 1/2,000 second) ?
Knallberto Veteran Member • Posts: 5,478
Re: Samsung Galaxy Camera - does the High Speed Video (120fps) have manual shutter options ?
http://forums.dpreview.com/forums/post/50440793
Questions do not grow more intelligent if you ask 2x, 3x, 10x, .... the same question.
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
Good question; too bad you didn't get a straight answer. I looked in the GC100 manual, looks like the answer is no.
However, it looks like my NX200 has 1280x720 @ 60fps or 640x480 @120fps. The NX20 is very similar.
Also, for my purposes for golf swings the 15fps for 2 seconds Burst mode at 5MP works great for golf swings. Speeds up to 1/4000 are available for all these modes. Works real well for stopping even some of the fastest club head speeds. There are also available Burst modes of 30fps for 1 second and 10fps for 3 seconds. Since the typical golf swing is a little less than 2 seconds, I use the first method mentioned.
Hope this helps.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
