Maybe it's my monitor calibration?
Started Dec 8, 2012 | Discussions
The Photo Ninja Senior Member • Posts: 2,242
To everyone that says their d800 / d4 is fine, how do you calibrate your computer monitor?  I'm using a spyder3pro which is probably four or five years old.
Nikon D4 Nikon D800
anotherMike Veteran Member • Posts: 9,273
Re: Maybe it's my monitor calibration?
I'm using an NEC 24" monitor with it's own "spectraview" calibration puck and software. Dead accurate on color which is why I use this particular combination.
-m
5tve Contributing Member • Posts: 678
I'm using a NEC 26" monitor that  covers 97.3%  of the Adobe RGB colour space & I calibrate with a eye-one display 2 & the Spectraview II software that allows hardware calibration , very accurate & easy to use.
http://www.necdisplay.com/spectra-view-II
 5tve's gear list:5tve's gear list
Nikon D7000 Sony a6000 OnePlus One
Kaj E Veteran Member • Posts: 9,380
The Spyder 3 pro was not known to be very accurate. The Spyder 4 was a great improvement, but still not the best alternative.
i1 Display Pro is probably the best reasonably priced calibrator puck right now. Don't fall for Color Munki.
The best software is ColorEyes Dsplay Pro (works with a variety of pucks and can be used with L-star instead of the traditional gamma, and gives you natural and better tonal separation particularly in the shadows). I use L-star RGB also as a working space and get superior equivalence from display to print compared to earlier gamma 2.2 calibration
http://www.integrated-color.com/cedpro/coloreyesdisplay.html
http://www.drycreekphoto.com/Learn/Calibration/MonitorCalibrationHardware.html
Kind regards
Kaj
http://www.pbase.com/kaj_e
WSSA member #13
It's about time we started to take photography seriously and treat it as a hobby.- Elliott Erwitt
JRDavis Veteran Member • Posts: 3,311
NEC PA241W with Spectraview and the NEC flavored puck. The PA series has internal 14-bit LUT, is 10-bit per channel over Display port with a ATI V4800. Calibration is simple and dead on.
John
 JRDavis's gear list:JRDavis's gear list
Nikon D200 Nikon D800 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Micro-Nikkor 60mm F2.8G ED Nikon AF Nikkor 50mm f/1.4D +10 more
OP The Photo Ninja Senior Member • Posts: 2,242
Would you please look at my newest post and advise...
Re: Would you please look at my newest post and advise...
http://forums.dpreview.com/forums/thread/3348850
It may give you better result than with the Spyder 3 (although I find the poor Spyder 3 results you describe puzzling).
A properly calibrated monitor should still give you superior results.
Kind regards
Kaj
WSSA member #13
Marianne Oelund Veteran Member • Posts: 7,386
Would *you* please keep all posting on this topic within a single thread?
You're not doing yourself a favor, by scattering this issue about in multiple threads.
- Marianne
Veni, vidi, exposui
BeachnCruz Senior Member • Posts: 2,034
NEC flavored Pucks plus X-rite i1 Display Pro for NEC Monitors now.
NEC Monitor Users are no longer limited to only using a "NEC flavored X-rite Puck". Thanks to the latest updates to NEC Spectraview II calibration software the X-rite i1 Display Pro and the NEC branded X-rite Pucks are fully compatible with NEC Spectraview II software when calibrating a NEC Monitor plus the X-rite i1 Display Pro is compatible with other brands of calibration software for calibrating other brands of Monitors, including Eizo.
http://blog.xritephoto.com/?p=5346
Jim
Calibration Hardware and Software has improved.
I think the DryCreekPhoto Calibration Hardware review may be a real eye opener for those who have not kept up with the latest calibration hardware and software improvements available now.
Jim
Sal Baker Forum Pro • Posts: 10,984
I don't know about matching your display to a camera LCD, but for calibrating to my 3880 printer I bought ColorMunki and I'm now enjoying near-perfect (as near-perfect as one can get between a print and a monitor) screen to print matching.  I'm on a Mac and a 30" Apple display.  Very impressed with ColorMunki.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Fujifilm X-E2 Fujifilm X-T100 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
