Help! Olympus E-PM2 skin tones versus Nikon D7000
Started Dec 5, 2012 | Discussions
GingerBread Regular Member • Posts: 384
Re: Help! Olympus E-PM2 skin tones versus Nikon D7000
VladimirCZ wrote:
Hi Alex,
on my calibrated monitor Nikon's picture has strong green and yellow tints.
Best regards,
Vlad
Same on my calibrated monitor.  I'd not want to set the Oly to match the pic on the right.  But, I do find Oly's skin tones too warm.  I did a white balance adjustment on my Oly and I turn down saturation to minus 1, then I'm satisfied with the skin tones.
I read all the raves about Oly's amazing colors before buying one, and discovered that "amazing" means highly saturated, overly warm and high contrast.  That also means inaccurate, but often pleasing colors.
Ging
 GingerBread's gear list:GingerBread's gear list
Sony RX100 Panasonic Lumix DMC-LX7 Nikon D700 Sony Alpha NEX-7 Panasonic Lumix DMC-GX1 +3 more
Daniel Lauring
Daniel Lauring Veteran Member • Posts: 9,346
Daniel Lauring wrote:
Alex Notpro wrote:
The skin tones on the E-PM2 come out very different from the Nikon D7000 by default. See comparison below. Some reviewers seem to find the warmer/redder Olympus tones more lively, but it must be a matter of preference, as I find them a bit unflattering (giving some subjects a gritty/angry look... probably great for street photography, not so much for family photos).
IMHO, the Nikon is HORRIBLE...zombie looking. The Olympus might pop more than you are used to but it looks much nicer.
I'm eating crow a little bit. I just was trying some portrait shots comparing a bunch of cameras and under incandescent light and I could not get the Oly to not turn my face pink. I tried natural colors...muted colors...setting the white balance manually to incandescent. Actually, setting the white balance manually to incandescent and using muted colors was worse than just letting Oly do AWB. I need to play with the individual color channels next I guess. It surprises me because generally I really like the Oly white balance but it wasn't handling the small room set up with three bright incandescent bulbs well.
This was with an Olympus PM2, btw, coupled with the Pansonic 45mm F2.8 macro.
 Daniel Lauring's gear list:Daniel Lauring's gear list
Sony a7R IVA
Alex Notpro
OP Alex Notpro Senior Member • Posts: 1,013
I don't think it's an AWB problem.
I got satisfactory results by just setting Saturation and Sharpness both to -2.
I did a bit of research into the Nikon "Portrait" picture mode and found that's essentially the same thing it does.
Not an "exact" match to the Nikon settings but close enough. I would need saturation about "-1.5" which is not an available setting on the camera.
 Alex Notpro's gear list:Alex Notpro's gear list
Sony FE 35mm F1.4 Sony a5100 Sony a7 II Sony E 16mm F2.8 Pancake Sony E 10-18mm F4 OSS +7 more
Rolfens Forum Member • Posts: 97
PStu wrote:
I don't know whether it was the light or what, but the baby looks jaundiced in the Nikon photo.
Nikon photos have a greenish-yellowish cast to them, and that's one of the reasons why I ended up buying an E-PM2 instead of a Nikon DSLR. I'm not saying the Olympus has better color reproduction...
You can manually correct the colors it in the Nikon camera menu.
I would suggest to the original poster to shoot RAW and set up his own workflow if he's that picky about colors.
 Rolfens's gear list:Rolfens's gear list
Olympus PEN E-PM2 Sony a7 Panasonic 20mm F1.7 II Samyang 12mm F2.0 NCS CS +11 more
Just shoot RAW, man!
You don't need to manually correct every photo afterwards... you just set up a profile that give you a result that you like, and apply it to all your raw photos.
PS: I have to say that my own tip doesn't really work that well.
I am shooting raw and tried a bunch of RAW processor software in addition to the Olympus bundled software. Even with color profiling, the skin tones still manage to look either too pink or too green.
Should've gotten a Canon, maybe
harvo Regular Member • Posts: 419
I would say a bit cyanotic!
Harvo, MD
 harvo's gear list:harvo's gear list
Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus 12-40mm F2.8 Pro +2 more
Bas Hamstra Senior Member • Posts: 2,071
Check your monitor
In your example the boy looks very very sick in the Nikon shot.
Maybe your monitor is tuned way too magenta and on your monitor the Nikon looks better. But then your monitor is basically tuned wrong AND your prints will look very different from your monitor.
Bas
Alex Notpro wrote:
The skin tones on the E-PM2 come out very different from the Nikon D7000 by default. See comparison below. Some reviewers seem to find the warmer/redder Olympus tones more lively, but it must be a matter of preference, as I find them a bit unflattering (giving some subjects a gritty/angry look... probably great for street photography, not so much for family photos). I'm able to correct the tones on the computer but does anybody know some quick settings to have them come out the same as the D7000 straight out of camera? The D7K tones are more natural, when compared to the subject next to the computer monitor.
Here's one representative sample comparison. Trust me, I did several, but I'm not going to post them all:
http://www.flickr.com/photos/atramos/8247423184/in/photostream/lightbox/
 Bas Hamstra's gear list:Bas Hamstra's gear list
Canon EOS 5D Canon EOS 6D Olympus OM-D E-M10 Olympus E-M1 II Canon EF 35mm F1.4L USM +11 more
andysoup New Member • Posts: 5
I agree that the PM2 produces extremely unnatural tones. I tried everything too (all profiles including custom, and measured custom white balance) and nothing seems natural. I like its colors for lanscape but not for people.
The nikon colors dont look so good either, even if they are accurate.
In my experience only fuji cameras show natural skin colors in any light and without any fiddling.
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
If the nikon color is "natural", then get ghe kid to a doctor…
Ulfric M Douglas wrote:
Alex Notpro wrote:
... I'm able to correct the tones on the computer but does anybody know some quick settings to have them come out the same as the D7000 straight out of camera? The D7K tones are more natural, when compared to the subject next to the computer monitor.
The one on the right is hideous.
The one on the left may be slightly too pink but in any case it is pleasant.
Go with the camera that took the photo on the left.
The camera for the right photo needs some serious tweaking! Maybe some serious tweakers have a jpeg profile to advise?
I have a friend who uses his Nikon D7000 in Auto for family photos : every single comparison shows my Olympuses making nicer out-of-camera Jpegs, despite me using the oldest Pens.
…immediately -- might be suffering from anemia!
In my view, Oly does warm up stuff just a touch more than I like. Can you pull the red and yellow down just a tiny bit in camera? Or maybe pull saturation down just a little. I can't remember, as I am now shooting with a Panny G6 which does offer this facility (but its "Standard" balance is just a touch cool and I have moved red up just a little -- you might find it perfect).
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
