Help! Olympus E-PM2 skin tones versus Nikon D7000
Started Dec 5, 2012 | Discussions
Alex Notpro
Alex Notpro Senior Member • Posts: 1,013
The skin tones on the E-PM2 come out very different from the Nikon D7000 by default. See comparison below. Some reviewers seem to find the warmer/redder Olympus tones more lively, but it must be a matter of preference, as I find them a bit unflattering (giving some subjects a gritty/angry look... probably great for street photography, not so much for family photos). I'm able to correct the tones on the computer but does anybody know some quick settings to have them come out the same as the D7000 straight out of camera? The D7K tones are more natural, when compared to the subject next to the computer monitor.
Here's one representative sample comparison. Trust me, I did several, but I'm not going to post them all:
http://www.flickr.com/photos/atramos/8247423184/in/photostream/lightbox/
 Alex Notpro's gear list:Alex Notpro's gear list
Sony FE 35mm F1.4 Sony a5100 Sony a7 II Sony E 16mm F2.8 Pancake Sony E 10-18mm F4 OSS +7 more
Nikon D7000 Olympus PEN E-PM2
PStu Regular Member • Posts: 342
Re: Help! Olympus E-PM2 skin tones versus Nikon D7000
I don't know whether it was the light or what, but the baby looks jaundiced in the Nikon photo.
 PStu's gear list:PStu's gear list
Olympus XZ-2 iHS Canon EOS 450D Olympus PEN E-PL2 Panasonic Lumix DMC-G6 Canon EF 50mm F1.8 II +9 more
Alex Notpro
OP Alex Notpro Senior Member • Posts: 1,013
Yeah I know, but I think that's more of a perception thing, due to the lack of context in the crop.
There was daylight coming in thru translucent blinds from top-left of frame. The blinds are off-white, not exactly photo-quality diffusers, I don't know if that makes a difference here.
And I think I sort of figured out the difference. If I take color saturation down two notches on the E-PM2, I get the same result on the skin tones. But then everything else in the frame gets desaturated too. It's almost like Nikon desaturates just the skin, somehow. BTW, I used the "Portait" picture control in both cameras for this test.
Kevdog
Kevdog Senior Member • Posts: 1,432
There's a setting for keep warm white balance on many Oly cameras.  If you turn it off, then the red tones down a lot and it looks much much better!
I just googled and it looks like the E-PM2 has the same setting.  Turn it off and try again!
 Kevdog's gear list:Kevdog's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Leica 100-400mm F4.0-6.3 ASPH Olympus 12-100mm F4.0
Robert Garcia NYC Senior Member • Posts: 2,200
wow, the nikon looks green. I prefer the Olympus.
dingenus Senior Member • Posts: 2,016
Use muted on the Oly.
 dingenus's gear list:dingenus's gear list
Olympus E-M1
James A Rinner
James A Rinner Senior Member • Posts: 1,611
You prefer the Nikon colors over the Oly?
The Olympus colors are much more natural than the Nikon's.  The Nikon's is very greenish and kind of zombie like.  I would check your monitor calibration.  Is your monitor calibrated?
Sincerely,
James A. Rinner
 James A Rinner's gear list:James A Rinner's gear list
Olympus E-10 Olympus E-20 Olympus OM-D E-M10 Olympus PEN-F Olympus E-M1 II +15 more
joachim05 Regular Member • Posts: 373
I assume you are showing us "out-of-camera-jpegs" here.  Nikon and Olympus profiling is different.  Mixing files from Nikon and Olympus is like mixing Kodak and Fuji slides in the olden film days.  You don't get a homogenous colour representation.
You might have a chance to overcome (or improve on) the issue by shooting RAW and using the same RAW converter for both cameras.  Then you get Adobe, Apple, ... profiling for both cameras.  It now depends how much they try to mimic the original profiling or just do their own thing - get a trial of a few RAW converters and see what you get. With modern products such as Apple's iPhoto and Aperture shooting RAW is not really more difficult as shooting JPEG.  For many photos you don't have to do very much - only if you need to rescue mistakes or want more than JPEG can give you, you need to work.  I am not a LR user, so no comment here from me on this, but I assume this is also easy.  I have used PSE6 and 9 in the past and that is not as easy.
I addition it looks to me, that on the Nikon shoot the white-balance might be troubled?  A green cast is a common reaction of a DSLR when being faces with a redish-pinkish target such as the baby skin.  If that happens you can fix in the RAW converter easily.  With JPEG you are doomed.
Hope that helps.
(unknown member) Veteran Member • Posts: 3,915
I've used Nikons before.  In jpeg, I find Nikon to have sallow (for me) skin tones, and Olympus has a warmer, more "romanticized" look.  This is evident in your comparison.  I note and emphasize that this is all personal preference, and there's no absolute "better."  If you want a more Nikonish look to your Oly files, then I'll suggest cooling the WB and go from there (in raw or in camera tweaks).  I would suggest, however, that you shoot the Oly in portrait jpeg for a while and see if you acclimate.  You may yet prefer it, and it never hurts to shoot Raw + jpeg.
SLOtographer
"If we limit our vision to the real world, we will forever be fighting on the minus side of things, working only too make our photographs equal to what we see out there, but no better." -- Galen Rowell
Vlad S Veteran Member • Posts: 3,766
Turn off warm color
Like Kevdog suggested, try the "Warm color off" setting on your PM2. It is found in Custom Menu (the cog wheel) section G (Color/WB) -> WBAuto Keep Warm Color-> Off. This option does not work in iAuto, so you need to be in one of the PASM modes.
Vlad
 Vlad S's gear list:Vlad S's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +2 more
Ulfric M Douglas Veteran Member • Posts: 4,828
Alex Notpro wrote:
... I'm able to correct the tones on the computer but does anybody know some quick settings to have them come out the same as the D7000 straight out of camera? The D7K tones are more natural, when compared to the subject next to the computer monitor.
The one on the right is hideous.
The one on the left may be slightly too pink but in any case it is pleasant.
Go with the camera that took the photo on the left.
The camera for the right photo needs some serious tweaking! Maybe some serious tweakers have a jpeg profile to advise?
I have a friend who uses his Nikon D7000 in Auto for family photos : every single comparison shows my Olympuses making nicer out-of-camera Jpegs, despite me using the oldest Pens.
photodan1
photodan1 Contributing Member • Posts: 974
Re: Turn off warm color
Vlad
Try this if you haven't. It makes all the difference.
G3, E-PM2, E-PM1, 45 Oly, 19 Sigma, 14-42 RII, 14-42 Pany, 40-150 Oly, Metz 50-AF
Flickr stream: http://www.flickr.com/dankanephotography/
 photodan1's gear list:photodan1's gear list
Nikon Z6 II Nikon Z 24-70mm F4 Nikon Z 50mm F1.8
Ulric Veteran Member • Posts: 4,559
IMHO, it is not the colours on the left that need tweaking.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
agott123
agott123 Senior Member • Posts: 2,579
A friend of mine started shooting sport pics with E1+50-200 then moved to E3 but never really worked out the AF C issues, so got D300 first and added D7000, wich do very good for him. After 3 years shooting with the Nikons (he kept one E1 and the E3) he decided to give a try again to the E1 for some group shots. Man, he was nearly in tears when he saw the difference in the skin colors. Believe me, he'll never do group shots again with Nikon.
Alex
Couldn't help but make me feel ashamed to live in a land
Where justice is a game. From Bob Dylan's 'Hurricane'
 agott123's gear list:agott123's gear list
Panasonic Lumix DMC-GF1 Olympus PEN E-P2 Olympus PEN E-PL1 Panasonic Lumix DMC-GH3 Olympus PEN E-P5 +21 more
Alex Notpro
I had the "keep warm colors = off" setting on the E-PM2 for this test. It was one of the first things I changed on the camera, like, after 2 test shots
But now I found this interesting article:
http://www.h2hreviews.com/article/Mini-Head-2-Head-Review-Olympus-E-P1-vs-Canon-Rebel-T1i-vs-Nikon-D5000/Portrait-Session-Skin-Tones1.html
It essentially confirms my observation except for the subjective part of which one is "better" - they claim the Nikon is more accurate but "not as nice". They sort of agree with most of you who responded. Oh well. Thanks for the feedback...
Thankfully I always shot "RAW+JPEG" and make a permanent archive of all RAWs, so I could go back and re-process should my tastes change in the future
roned Regular Member • Posts: 118
I change olympus cameras so the colors aren't so warm. I like a bit more natural color. I would agree with Ulfric M Douglas though. The right one is hideous. The left is nice.
Banger
Banger Contributing Member • Posts: 607
Well, the Nikon shot isn't very nice at all, on my monitor it has a greenish cast.  On the other hand the Oly shot is a bit too pink,  not unusual for Oly cameras and that's the reason I always have the reds dialed down a bit on all my Oly 4/3 & u4/3 cams (easy to do using the SCP),  generally -1 but often -2 when shooting flowers etc.
Rgds, Rob
 Banger's gear list:Banger's gear list
Olympus E-30 Olympus E-M1 Olympus OM-D E-M10 II Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +6 more
Daniel Lauring
Daniel Lauring Veteran Member • Posts: 9,346
IMHO, the Nikon is HORRIBLE...zombie looking.  The Olympus might pop more than you are used to but it looks much nicer.
 Daniel Lauring's gear list:Daniel Lauring's gear list
Sony a7R IVA
roned wrote:
I change olympus cameras so the colors aren't so warm. ..
Every Olympus camera I own with the 12mpx sensor has global whitebalance turned to Green+1 ( =Red minus 1) otherwise woodland scenes come out a bit too brownish.
The newer cameras have a similar tendency but I don't own a 16mpx body.
Of course Green+1 will make skins less pinkish, which is a good thing as long as the pleasant tones are retained.
VolodymyrCZ Regular Member • Posts: 296
Hi Alex,
on my calibrated monitor Nikon's picture has strong green and yellow tints.
Best regards,
Vlad
