24-70 L or 5DMK3
Started Dec 2, 2012 | Questions
asterix07 New Member • Posts: 9
24-70 L or 5DMK3
Hi,
I do mostly street and travel photography and am currently using a 60D with 35 L as my main lens, but recently I keep finding that this setup doesn't give me the wide angle i am looking for in most of my shots.
Looking for advice on whether I should go for a new lens such as 24-70 L or for a FF 5DMK3?
Canon EF 24-70mm F2.8L II USM Canon EOS 5D Canon EOS 5D Mark III Canon EOS 60D
BillsLIPhotos Contributing Member • Posts: 734
Re: 24-70 L or 5DMK3
If you are happy with the features/performance of your 60D I would go with a new lens. The EF-S 15-85 is a good all around lens giving you a 24mm equivalent at the wide end on a crop body. The 24-70 on the 60D still won't be that wide. Just me 2 cents. Good luck with your decision.
Kevin Jorgensen Contributing Member • Posts: 745
If you can borrow one try the Samyang 14f2.8 as a walk around lens, you'll be pleasantly surprised.
 Kevin Jorgensen's gear list:Kevin Jorgensen's gear list
Canon EOS 5D Mark III Canon EF 85mm f/1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Samyang 14mm F2.8 IF ED MC Aspherical +2 more
bdjalins New Member • Posts: 7
You have the 35L already. If its me, I'll go FF with 5DM3.
5dM3 with 35L, just perfect for street photography and not only you get new body you'll feel you have new lens as well. 35L on FF is different with 35L on crop.
My 2 cents
OP asterix07 New Member • Posts: 9
that was actually another of my concerns that the 24 won't be wide enough or be as sharp as the 35 i absolutely love other than the crop factor.
think i'm leaning towards a new body.
thanks!
Marcos Villaroman Veteran Member • Posts: 5,814
5DMK3
I went from 40D w/ 17-55/2.8 to 5D2 w/ 24-105 and now to 5D3 w/ 24-70 II.  I've also borrowed a 5D1 for about six months.
I would definitely go with the 5D3 for the improved AF.  As far as I'm concerned, the 5D3 is the first 5D camera that can focus.  I didn't know how poorly the 5D1 and 5D2 focused until I bought the 5D3.
Buying a 24-70 II doesn't mean I no longer need my old 24-105.  I still like the 24-105 for the IS and it is excellent stopped down at f/8.
Consider there were deals out there where you can buy just about buy the 5D3 with a 24-105 tossed in for free.
 Marcos Villaroman's gear list:Marcos Villaroman's gear list
Sony RX100 IV Canon EOS 5D Mark III Fujifilm X-H1 Canon EF 24-70mm F2.8L II USM Fujifilm XF 56mm F1.2 R +52 more
oldfartwitha5d Senior Member • Posts: 1,486
5DMK3, no contest
I own both, and I could do fine without the 24-70 f2.8 mkII, but not at all without my 5Dmk3.
And you already have the 35L, so you are all set for some fantastic photographic opportunities
Eyvind
 oldfartwitha5d's gear list:oldfartwitha5d's gear list
Canon EOS 5DS R Canon EOS-1D X Mark II Canon EF 135mm F2L USM Canon TS-E 90mm f/2.8 Canon EF 100mm F2.8L Macro IS USM +13 more
