Image Quality: Is newer better?
Started Dec 2, 2012 | Discussions
Kevin Omura
Kevin Omura Senior Member • Posts: 2,388
Re: Image Quality: Is newer better?
Really depends on the particular camera IMHO. In some cases there could be a major feature or set of features added to a camera that would make it a stand out. For example the Panasonic FZ200 which has gone back to a 25-600 constant f2.8 lens. :^P
In your case you have a couple of things happening, you really liked your old Canon so perhaps the smart thing to do since you are so familiar with it is to find a good condition used one either online or at a local camera store.
One thing I'm not sure of is what is your comfort level in terms of size. Is something a bit larger such as a used Canon Pro1 within limits or are we talking about something really nice and pocketable such as the Canon S100 or perhaps something with more zoom like the Panasonic ZS10?
Based on what you are saying I have a feeling you might want to check out a used Pro 1 if you can find one at a decent price. It does have L glass, has the ability to use EOS EX flashes
Maybe even the EOS M if you have EOS DSLR gear? Granted what you gain in size from the body you loose back to the size of the standard M lenses.
Like the guy in the deli, I feel like saying "everything is good" these days so it may just boil down to size, features and cost.
 Kevin Omura's gear list:Kevin Omura's gear list
Canon EOS D60 Canon PowerShot S100 (2000) Canon PowerShot S5 IS Canon PowerShot G2 Canon PowerShot G6 +69 more
(unknown member) Forum Pro • Posts: 15,724
Image Quality: Yes, it's better.
samualson Regular Member • Posts: 180
hannenberg wrote:
IMO the short answer is no. I believe there was a jump in IQ from the SX30 to SX40 probably mostly due to the decrease in megapixels. There was a discernible improvement in CA . I haven't seen a lot of evidence that the most recent models from Canon and Panasonic have better IQ. In the case of the SX50, I think there's some evidence that CA is worse.
The newer models certainly have other features that might be desirable, e.g., faster autofocus, longer zoom. etc. Speaking for myself, I'm content to wait until the next generation of superzooms before trading in my trusty SX40
Agree 100%. The difference is definitely not worth upgrading for and i also see a negative with the CA on the new SX 50.
RedFox88 Forum Pro • Posts: 30,738
averagjoe wrote:
I never had an issue with the IQ I got out of the 630, so I don't see the need to spend the extra several hundred on the latest model, when on a good day a used A630-640-650 model (all highly acclaimed and much beloved by their users) can be had for around $100.
Thing is that ISO 1600 really isn't "low light".  It can be indoor with decent window light without flash.  Your a630 might have had ISO 800.  I have an a620 and it only has ISO 400.   Even the G11 blows away the a650 at ISO 1600.  But if you really don't shoot in non bright conditions, maybe just use your mobile phone to snap pics.
ISO 100... LOL
Hank3152 wrote:
Hi Joe,
Image quality?.......simply put, no...not noticeably better. I bought a G11 just before my A610 died and was able to do some comparisons......only after careful scrutinizing of the corners of 100% crops at ISO100 did I observe a slight difference of contrast and sharpness.
You are wasting your time trying to see differences at base ISO, 100.  Your G11 should trounce your a610.  You are also comparing probably 5 MP vs. 10 MP.  Plus the a610 probably has ISO 400 as a highest ISO while the G11 is probably better at ISO 1600 than your a610 was at ISO 200.
Hank3152
Hank3152 Forum Pro • Posts: 13,499
ISO100........LOL
The G11 did trounce the A610. You missed my point completely.....I was comparing apples to apples, as I was well aware the A610 went downhill above ISO200...you should've read the rest of my post........
"However, the big difference was in being able to consistently nail shots I couldn't even attempt before.........the features, i.e., IS, high ISO, AF, resolution, build, etc., were greatly improved......."
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm F2.8L Macro IS USM +5 more
Dimitri Khoz Contributing Member • Posts: 943
Re: ISO 100... LOL
It may be true for A610,
but from 2006 untill 2011, there were almost no significant improvements in IQ area.
Here is ISO800 Canon A640 from 2006 vs ISO800 Canon G11
Canon G11 vs Canon A640 in ISO800
Here is ISO800 Canon G7 from 2006 vs ISO800 Canon G11
Canon G11 vs Canon G7 in ISO800
There is no IQ gain at all for G11, just some extra NR.
Only in 2012 with G15 and its bright lense and G1X with its huge sensor
Canon made a leap forward.
G1X and G15 started new era of IQ progress for Canon advanced compacts.
Re: ISO 100... LOL
Not true.  I have compared the a650 to the g11 at ISO 1600 and well the a650 falls apart.
Re: ISO 100... LOL
Re: ISO 100... LOL
OH, and I just checked ISO 800 in DPR's a640 and G11 review and the G11 clearly beats the a640.  I mean clearly because the G11 details are much clearer since the a640 had old blurring noise reduction going on.  Sometimes people think the old stuff is better than the new without really wanting to see if the new is better.
Re: ISO 100... LOL
DPReview test shot with a640 is underexposed by 1 stop comparing to G11, f5.6 vs f4.0 at the same 1/640 sec ISO800
http://a.img-dpreview.com/reviews/CanonA640/Samples/Comparedto/A640_ISO800.JPG
http://a.img-dpreview.com/reviews/CanonG11/Samples/comparedto/higheriso/G11_ISO800_0310.JPG
therefore noise is much more pronounced in a640 image (a640 had almost no NR for JPEGs).
Here is IR controlled test using same exposure and same test set
ISO800 image made with G11
http://www.imaging-resource.com/PRODS/G11/FULLRES/G11hSLI0800.HTM
here is ISO800 G7
http://www.imaging-resource.com/PRODS/G7/FULLRES/G7hSLI0800.HTM
here is ISO800 a640
http://www.imaging-resource.com/PRODS/A640/FULLRES/A640hSLI800.HTM
and you will find that a640 retains same amount of details as G11, just chroma noise is a bit more visible in prints.
I run NeatImage over G7 and a640 shots, and the difference in IQ between ISO800 G11 and ISO800 G7 is about 1/2 stop.
It is very small difference, especially considering age difference between the cameras.
And it is ISO800, not even ISO200 or ISO80.
Re: ISO 100... LOL
Canon A640 ISO800 + NR (underexposed by 1 stop and with the bottle further from camera)
Canon G11 ISO800
If A640 shot was given same amount of light like in the G11 shot,
it would completely match newer G11 in details after NR.
Steen Bay Veteran Member • Posts: 7,418
Re: ISO 100... LOL
What's most important for the sensor performance is the QE and the read noise. The QE only increases slowly, but the read noise has been reduced quite a bit. If we compare the G9 and G15 on DxO we can see that "SNR 18%" (mostly determined by the QE) has improved by something like 1/3 stop at low ISOs to app. 2/3 stop at higher ISOs, and the DR (where the read noise is more important) has increased by app. 1.5 to 2 stops across the whole ISO range.
tarmov Forum Member • Posts: 94
There is at least one family of cameras which provide better image quality at ample light: the Sigma DP family.
I have had A610 since 2006 (when it became apparent that it was leaving the market). My A610 is still working.
I was able to withstand the temptation to buy Sigma DP1 or DP2 for several years, but DP2 Merrill proved out to be too good, so I finally bought that. So now A610 is my backup camera.
I still like a lot about A610. Its image quality, swivel screen, incredible stamina of taking images with 4xAA batteries, raw and bracketing and much more with CHDK, very good hand grip (I can operate it with one hand on a bicycle), decent burst ability (2.5 fps), etc. They don't make such universal cameras any more.
As to the future, I would encourage Canon to start producing cameras with Foveon-style sensors.
-Tarmo
 tarmov's gear list:tarmov's gear list
Sigma DP2 Merrill Sony RX100
cab321 Regular Member • Posts: 151
I have an Powershot A640, love it, I even have the underwater housing for it. I've splashed around on the surface but I'm too chicken to apply the grease provided and submerge to 20+m.
The new ones like G12, Nikon P7700, etc have a better screen, a bit more resolution (for stills and video), but they don't take better pictures. It comes down to the photographer, lighting & composition.
I would get a G15 but it has no articulating viewfinder. IMO the new stuff is a bit more competent but not much better than your A640/650.
 cab321's gear list:cab321's gear list
Canon PowerShot A640 Canon PowerShot G7 X Google Nexus 7 +14 more
