What lens to purchase for Canon DSLR
Started Dec 1, 2012 | Discussions
ma9alem New Member • Posts: 3
Hello All
I currently have the following Canon items:
1) Canon 550 Flashgun
2) Canon 50mm 1.8 lens (Primiarily used to take children portrait pictures)
3) Canon 350D with standard kit lens
I wanted to replace the 3rd item above for a Canon 650D, however, was not sure which lens to go for? Options are:
A) Standards kit lens 18-55mm
B) 18-135 STM
C) 17-55mm f/2.8 IS USM
D) Any other suggestions
Main usage will be to take photo's of children, family occasions and holidays.
Thank in Advance.
Has
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: What lens to purchase for Canon DSLR
ma9alem wrote:
... I wanted to replace the 3rd item above for a Canon 650D, however, was not sure which lens to go for? Options are:
B) 18-135 STM
Depending on how much you have to spend, and whether you prefer max aperture to zoom range I think the hierarchy is
  1. EF-S 17-55 f/2.8 IS USM
  2. EF-S 15-85 f/3.5-5.6 IS USM
  3. EF-S 18-135 f/3.5-5.6 IS STM
  4. EF-S 18-55 f/3.5-5.6 IS
But even choice 4 is pretty good, as well as very easy on the wallet.
IMHO YMMV.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Sandy05 Regular Member • Posts: 186
If photographing your children and family is a priority, and you will be relying on one lens for most occasions it is nice to get something that has a bigger zoom range. While the 17-55 lens is a very high quality lens you might find the zoom range is a bit limiting if, for example, you were trying to capture photos of your children on a ride a Fair, or if you want to be a greater distance away to capture a candid moment while they play. While I have not tried the new 18-135mmm STM, it seems to be getting some good reviews. Particularly if you could get it as part of kit, it may be a good, cost effective option. If you are buying the lens separately anyway, however,  consider the Canon 15-85mm lens as well. I have the 15-85 and I have found it be an excellent all around performer.
brightcolours Forum Pro • Posts: 15,885
2 I would choose from
ma9alem wrote:
Hello All
B) 18-135 STM
This lens has nice optics for its type, so if you want a longer range, I would suggest this lens.
Instead of the 17-55 f2.8 IS USM I would opt for the cheaper but very good also Sigma 17-50mm f2.8 EX DC OS HSM. Equal optics, a bit better build quality and also f2.8 and IS and USM. And comes with lenshood standard (the canon has that optional, so it adds to the price).
Thank in Advance.
Has
Peter too Contributing Member • Posts: 909
For photographing children indoors I would use a 17-55 but outdoors when they are likely to be running around I would use a 70-200 F4 IS but they are fairly pricy options.
OP ma9alem New Member • Posts: 3
Thanks for the feedback. I like the idea of getting the candid pictures as currently as soon as they see the camera they stop or make an artifical face.
I will review all the options you have mentioned and evaluate what is the best option within my budget.
Once I decide I will update you all and thank you very much for the responses.
amosf
amosf Contributing Member • Posts: 680
Another budget option is the Tamron 17-50 2.8 non-VC. Nice lens that stays on my 550D most of the time.
But as others have said, the 18-55 IS kit is nice to.
Of course the trouble is there are too many great options
 amosf's gear list:amosf's gear list
Canon EOS 550D Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Tamron AF 18-200mm F/3.5-6.3 XR Di II LD Aspherical (IF) Macro +3 more
