Pentax K01:Focusing Problem with Pentax 43/1.9 Limited Lens
Started Nov 30, 2012 | Discussions
babujr
babujr Forum Member • Posts: 89
With the K01 camera on Auto setting, a  red "F--" appears in the lower left hand corner of the LCD screen. The lens does not focus.I cannot find the "F--" symbol explained in the Owners Manual.
This lens operates fine on my *ist DS. Other Pentax lenses operate on the K01 fine. Something wrong with this particular 43/1.9?
babujr
 babujr's gear list:babujr's gear list
Sony RX100 VII Canon PowerShot Zoom
Pentax *ist DS Pentax K-01
miles green
miles green Veteran Member • Posts: 7,827
Re: Pentax K01:Focusing Problem with Pentax 43/1.9 Limited Lens
Are the contacts of the lens clean?
(a quick guess to get the easy stuff out of the way..)
F-- sounds like an aperture thing. Check if the lens is in A mode. That could explain the "F--", but it has nothing to do with focus.
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
babujr
OP babujr Forum Member • Posts: 89
Thank you, Miles! Yes, when I put the green A on the lens to align with the red line on the lens, the camera focuses. Any explanation as to why? Much appreciated.
babujr
awaldram
awaldram Forum Pro • Posts: 13,271
You need 'allow aperture' enabled in the menu system.
Otherwise any none 'A' lens (or swicthed off A) will not function.
When the lens is in the 'A' position it set to allow the camera to control the aperture, any other position and the aperture is set manually on the lens.
The camera has no means of knowing this so shows F-- rather than the aperture set and without the menu enabling it blocks the use of the lens to protect accidental mis setting.
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Olympus PEN E-PM2 Pentax Q7 Pentax K-3 +17 more
brandrx Forum Pro • Posts: 28,337
Set Custom menu, Tab 3, Item #16 to equal 2. Leave it in that setting at all times.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
miles green
Strange... Maybe it was on f/22 and there wasn't enough light for the K-01 sensor-based AF to work? Just guessing... Glad it works now!
Miles Green
Corfu, Greece
babujr
Thanks to all . Problem solved.
babujr
