Zoom lens not behaving.
Started Nov 28, 2012 | Discussions
Richard Hesketh New Member • Posts: 1
My NX1000 50-200 zoom lens delivers a lovely, enticing high magnification preview when I use the focus ring, only to pop back to 'zoomed out' view when left alone. What is the problem? Am I using the 'wrong' settings? Very frustrating for a new Camera/lens combination!
timedrun Contributing Member • Posts: 683
Re: Zoom lens not behaving.
it sounds like you have the lens in manual focus and the focus assist set to magnify.
A little green rosetta......a tiny green rosetta........
 timedrun's gear list:timedrun's gear list
Samsung NX20 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake Samsung NX 45mm F1.8
nx200USER1 Senior Member • Posts: 1,097
I'll second that, I just checked on my nx200 and indeed I was able to reproduce your condition. I get to choose 5x or 8x magnification or Focus Assist in manual mode from within the menu settings. Even in Auto Focus mode, you can still take advantage of the manual focus ring and the magnification feature but you have to have the shutter button half pressed.
viking79
viking79 Forum Pro • Posts: 14,157
I think you are using DMF (direct manual focusing)?  If set to magnify in the menus, when you half press the shutter to focus it will attempt to focus, and you can override the autofocus by turning the focus ring.  When you stop focusing it should pop back out to the normal view.
I am confused by your post on what the actual issue is, it sounds like expected operation.  If you switch from autofocus to manual focus, and leave the magnify option on in the menus it should do the same whenever you turn the focus ring (not only when the shutter is half pressed).
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Eric
what eric says is the answer i think.
random78 Regular Member • Posts: 288
Are you confusing zoom and focus rings?
Its not clear what you are trying to do here. I am sure you are aware that the zoom and focus rings  have completely different purposes. If you want to zoom in you have to use the zoom ring. The focus ring is there if you want to focus manually and the magnified view that you see is to help you in determining critical focus. This is why the magnified goes away once you are done focusing.
Also camera doesn't allow you to focus manually in regular AF mode, so if you are getting the magnified view then your camera must be set to either manual focus mode or DMF mode. You might want to make sure that it is not set to MF mode as the camera won't autofocus in that mode.
 random78's gear list:random78's gear list
Nikon D7000 Canon EOS M Sony a6000
zziplexi New Member • Posts: 11
As above your question has been answered, but I think the real query was like me , when you first got the ccamera and found this magnification you presumed the camera had a much longer zoom than it has.
i had the same thing with the 20-50 lens the preview picture was much larger than the photo you could take.
As I wanted to tha photo,s of  birds in my garden about  30-40 feet away I have just bought the 50-200 lens , I expected it to be able to take close up shots of the birds at  this short distance but it really doesn't at all.
Another problem I found with the lens was when I tried movie recording if you use the zoom at all , all you can hear on playback is the noise of the lens moving in and out.
