Pro/Cons for Sigma 12-24 II & Canon 16-35 II
Started Nov 28, 2012 | Discussions
OP vvv14 Forum Member • Posts: 56
Re: Pro/Cons for Sigma 12-24 II & Canon 16-35 II
Thank you all for your input and for the pictures. The landscapes from Sigma look great and the architectural shoots are ok.
I was well biased into buying the Canon before starting this thread, now Sigma looks like the more likely candidate.
jrarsenault wrote:
In reference to your last question with respect to 'space', I am assuming that you are asking about how much of the photo is lost when distortion is corrected.
This is exactly what i meant.
Your corrected sample doesn't show much “loss of picture estate” but the original is not so badly distorted either. Was the picture taken at 12mm? Thanks for taking the time to post them!
The image below was downloaded from the samples posted in the review of Sigma 12-24 II at lenstip.com (http://pliki.optyczne.pl/sig12-24II/sig12-24_fot09.JPG)
Notice the loss of picture space is quite severe after applying the corrections. I know it’s probably the worst case scenario with parallel lines at both edges of the picture. I wonder if 16-35 would do any better.
Original @12mm from lenstip.com
distortions corrected
I know there's room for improvement in terms of correcting the above but it's beyond the point.
(unknown member) Contributing Member • Posts: 617
In your pictures you are not (only) correcting the lens distortion, but somehow the perspective (I don't know the exact name). That correction has nothing to do with the lens (unless you have a tilt-shift lens), so you will have to apply that correction anyway.
jrarsenault Senior Member • Posts: 1,151
I didn't realize but my photo example of the river boat was taken at 24mm... I just took a look at the original EXIF. I thought I had taken it at 12mm.... sorry about that. Regardless, the 'lost space' would be greater on the Sigma 12-24 @ 12mm than the Canon @ 16mm simply because the Sigma is wider causing distortions to be greater.
Going back to my original post, I use the Sigma 12-24 when I really need something to be shot very wide. Sigma fills that need and then some. The 5mm difference between my Sigma and Canon 17-40 is huge. I use the Canon 17-40 for just about everything else. Here is an example of something I took with the Canon 17-40 (slightly corrected):
Canon 17-40 with slight distortion correction
There are some photos in which the distortion kind of works and I leave it in for creative purposes. Other times I will simply correct it as much as I can. It all depends on the photo.
With the Sigma 12-24, I find I can be very creative. Taking a facial shot up close can produce some interesting results. Taking a person's 'thumbs up' very close and their face in the background is also creative. There is a lot of fun to be had with UWA's.
I wish you good luck on your buying decision.
Robert Sheldon Senior Member • Posts: 2,272
vvv14 wrote:
Robert, thanks for your reply.
I own both the Canon 17-40 and the Sigma 12-24 Mk II.
Am I correct to assume you acquired the Canon prior to Sigma? You plan on keeping both?
I will be keeping both.  Not sure which I had first as I previously owned a Sigma 12-24 Mk I.
When I need a wider lens than the Canon (quite often when photographing covered bridges) I use the Sigma.
Does this mean that you prefer Canon at 17mm and over?
Nor really.  For IQ I do not prefer one over the other.  At f/13-16 I do not see a big difference (I am not a pixel peeper but have sold prints up to 24" X 36" in size).  For me photographing covered bridges the 17-40 covers the range I need 90% of the time.  I very seldon have to change lenses.  If I used the 12-24 I would change lenses to my 24-105 maybe about 40% of the time.  So, it is for convience that I like the 17-40 for covered bridges.  When I go on long hikes and want to minimize weight I take the 12-24.
Now, perspective distortion is an other story on loss of image space but that is what you have to work with all UWA lenses, including primes.
Can you roughly quantify the loss on image space in any way or is it more like a "case by case" scenario (i.e. shoot at 12mm and after distortion correction looks like it was shoot 14mm)?
No, for the sigma 12-24 shooting at 12 mm you loose practically nothing due to optical distortion correction.
You loose image space depending on how far from horizontal you are shooting due to perspective distortion.  Point any 12 mm lens (prime, zoom, any manufacturer) at 10 degrees above horizontal and you will get the same amount of loss due to perspective correction.  This is a matter of physics, not lens quality.  The only way you can get around this is with perspective control lenses which are very expensive.
Bob Sheldon
Photo Gallery at
www.bobsheldon.com
As I mentioned earlier, when I posted the question here, I was almost sure Canon was the better option. After reading your comments and looking at your samples, I stopped worrying that Sigma might not be on par with Canon in terms of corner sharpness and distortions. It might not have the edge in terms of IQ or speed but the extra 4mm are huge, it puts it in a different category.
I put an order for Sigma last night, it should arrive sometime next week. I’m sure it will find a permanent place in my camera bag. For the future, should I require the ultimate sharpness and quality I might consider 17-TS. However, I hope I’ll keep my sanity and invest the money in something wiser.
Once again, thank you all for sharing your experience, it definitely help me decide on this occasion. I’ll get back with pictures and impressions as soon as it arrives.
Cheers!
Rock and Rollei Senior Member • Posts: 2,916
Good choice. I've had a Sigma 12-24 since the first Photozone review 9 years ago - it convinced me that it was good enough, and I bought a 10D which was only usable for me because there was a wideangle option. When I upgraded to a 5D, I bought the 17-40L intending to sell the Sigma, but realised that there was actually nothing in it in image quality terms. That remained true on the 5D II. I've kept both lenses - if I want to use filters, I use the 17-40, if I'm shooting both APS-C and FF I use the Sigma, otherwise I use whichever lens is in the bag. The Sigma is certainly not shamed by my L lenses.
Additionally, 12mm is just stunning when used effectively!
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
Sigma arrived this morning. 12mm is shocking! I owned Canon’s 10-22mm a while back before full frame, but it was nothing like this one. It’s a completely new shooting experience.
I only had the time to take a few snaps outside, first impressions are very good.
Samples below are all at 12mm.
Fleour - one of my 5 cats. (cropped)
GtoJon
GtoJon Veteran Member • Posts: 3,553
Very nice images
Welcome to the world of Sigma   Only people with blinders on or a bad lens would say otherwise
Cheers
www.JonSmithers.com GtoJon -
Taken any photographs lately?
http://www.jonsmithers.com/postedimages/EagleTeal-Zoo.jpg
 GtoJon's gear list:GtoJon's gear list
Sigma 120-300mm F2.8 EX DG OS HSM Canon EF 24-105mm f/4L IS USM Sigma 12-24mm F4.5-5.6 II DG HSM Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
kevindar
kevindar Veteran Member • Posts: 4,625
fair bit of experience
the short of it, if utter sharpness and image quality is the most important criteria for you, go with the Nikon 14-24 2.8, adapted to canon.  If you are willing to make a bit of comprimise in image quality, go with the 16-35 II.  I have owned, tested and shot with the following ultrawide lenses.
Samyang 14 2.8, simga 12-24 I, canon 16-35, canon 16-35II, canon 17-40, canon 15mm fe 2.8, canon 24 tse II, and nikon 14-24.  so I consider myself well versed.  each lens has its strenghts and weeknesses.  the best zoom of the bunch is 14-24. the most versatile of the bunch with very good image quality stopped down is 16-35 II.
all that said, I think much of the difference is academic.  I admidetly have not taken an image with any of these lenses which I disliked b/c of the lense's shortcoming (plenty b/c of my shortcomings)
 kevindar's gear list:kevindar's gear list
Canon EF 85mm F1.2L II USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Sony a7R II Sony a6300 +25 more
Thanks GtoJon,
I'm sure 16-35mm lens would do as good if not better job (but surely not as wide!) than Sigma.
I noticed Sigma can be soft at edges when shooting up to f5.6, but since I intend to shoot mostly landscapes it shouldn't be an issue. I'm happy with it.
Re: fair bit of experience
There aren't many WA lenses missing from that set. Everybody seems to agree with you that Nikon has the best WA zoom out there. I haven't tried it yet and using it with an adapter on a Canon body would be too extreme for me.
As I already purchased the Sigma, i'll stick with it for a good while before I'll consider another WA lens. I know this lens might be a good bit off from my initial goal (ultimate sharpness and image quality for a WA zoom) stated at the beginning of the thread, but I came to realise first, as you put it, "much of the difference is academic" and second - I think Sigma will be more fun to use.
billythek Veteran Member • Posts: 5,260
Re: How about the Samyang 14/2.8?
Although this thread is a couple weeks old, a few points regarding the Samyang 14mm:
- Yes the 14mm has complex moustache distortion, but if you use the lens profile in LR/ACR, one click and poof, it's gone.
- The distance scale can be easily corrected if it's off.  Google to find out how.
Unless you are truly printing billboard size prints, why bother with a zoom?  Just get the 14mm and crop, if you have to.  If you are shooting at 20MP+, you've got lots of pixels to spare before anything becomes noticeable at normal picture sizes.
The only other WA landscape lens I'm tempted to get is the 17TS-E.  Of course, I have the 24-70II to fall back on for shots in that range..
- Bill
 billythek's gear list:billythek's gear list
DxO One Canon EOS 5D Mark III Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM
StickmanBangkok Forum Member • Posts: 72
vvv14 wrote:
icture doesn't have Sigma mk2 in their IQ charts to compare it with Canon.
What are your opinions? I hardly expect anyone to own both but do you think Sigma is sharp enough? Do you have to crop to compensate for distortions? Is Canon just ok or is it top class L glass as the name (and the price) suggests? Is it a no brainer to buy this third-party lens when Canon has the best? Or am I throwing money at Canon when there’s a much wider zoom out there with similar IQ?
Cheers!
I played around with a friend's Sigma 12-24 II tonight and was quite impressed.  It was sharper than I thought it would be and it renders the colours nicely.  If I was in the market for an ultra wide I think I would be quite happy with it.
ISO 3200 F5.6 1/30 sec
 StickmanBangkok's gear list:StickmanBangkok's gear list
Yeah, I choose it too over Canon, mainly for the extra 4mm at the wide end. I only have it for a week and I didn't get a chance to shoot with it yet (bar some samples posted above). While so far I am very happy with it, I realised that probably I won't use the zoom as much as I thought. So maybe I was better off with the highly recommended Samyang 14mm at less than half the price.
Anyways, the main priority now is to go out and shoot with my new Sigma.
Rexgig0
Rexgig0 Veteran Member • Posts: 7,399
I have found this thread very informative! Thanks to the OP, and to all who responded!
Until last night, I did not know there was a II version of this lens, nor that these were suitable for full-frame cameras, nor that any Sigma lenses were splash- resistant. I now have another contender for an UWA to be used on my 1.3x-crop and FF Canons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +54 more
I’m very pleased to have an UWA in my kit. And it’s not because it’s a Sigma or that it goes as wide as 12mm. It’s because it opens many new opportunities for shooting.
aru1971 New Member • Posts: 1
Hi thanx fo r sharing i too want  to go for sigma 12-24 !! Now u have fair bit of exp
Do u recommend it
Thnx in advance
DarrynM New Member • Posts: 14
Thanks all for sharing the info here - I'm now torn between the Sigma 12-24mm and a Samyang tilt-shift 24mm......
I reckon the Canon 14mm is too expensive for me as I will only use this lens a little bit at weddings.
