Pro/Cons for Sigma 12-24 II & Canon 16-35 II
Started Nov 28, 2012 | Discussions
vvv14 Forum Member • Posts: 56
I'm looking for a wide angle zoom and I narrowed my search to these two lenses. I intend to use them on a full frame (5d3) mostly for landscapes but some architecture as well.
The main criterion of selection is sharpness. A prime would do a better job but, as an amateur I can’t justify the price of a good prime, plus the zoom is handy.
Distortions are also important, but I don’t mind PP. As long as distortions can be corrected I can live with them. 12mm sounds very tempting but once corrected for distortions how close does it get to 16mm?
The aperture doesn't really matter as they will be mainly used at F8 or slower. Also, I don’t intend to use either lens at 24mm or more as I have better glass for that.
Being able to use filters and weather protection are a plus to Canon.
Photozone doesn't praise much 16-35 II in their review (actually about as much as 12-24 II). The-digital-picture doesn't have Sigma mk2 in their IQ charts to compare it with Canon.
What are your opinions? I hardly expect anyone to own both but do you think Sigma is sharp enough? Do you have to crop to compensate for distortions? Is Canon just ok or is it top class L glass as the name (and the price) suggests? Is it a no brainer to buy this third-party lens when Canon has the best? Or am I throwing money at Canon when there’s a much wider zoom out there with similar IQ?
Cheers!
trulandphoto Senior Member • Posts: 1,019
Re: Pro/Cons for Sigma 12-24 II & Canon 16-35 II
You should head over to lensrentals.com and read Roger Cicala's take on these lenses. Comments are located at the bottom of the lens description on the rental pages.
 trulandphoto's gear list:trulandphoto's gear list
Canon EOS R Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F2 Macro IS STM Canon RF 50mm F1.8 STM +3 more
BAK Forum Pro • Posts: 26,019
What's wrong with the Canon 17-40?
A 17-40 saves lots of money and works fine at f8.
BAK
Henrik Herranen Senior Member • Posts: 1,732
How about the Samyang 14/2.8?
Actually, there is one prime that might fit your bill by being both inexpensive and having impeccable image quality (except one feature that can be post-corrected).
The too-good-to-be-true Samyang 14 mm f/2.8 E AS IF UMC has been my and many others' wide angle choice since they re-engineered the glass (the old version didn't have UMC it its name and it was a much worse lens). The lens costs less than 350€ in Europe, so it is by any definition a dirt-cheap piece of glass. It is also sold by many other brand names, but I don't know if they are the non-UMC or the UMC version.
When Canon's 14/2.8L II costs over seven times that much, you wouldn't think you could get anything usaful for 350€, but the Samyang is one wonderful piece of glass. The lens is mechanically sound and the focus ring has the MF era feel that is smoother and better than on any L lens I've used. 14 mm is wiiide, and usable even with fully open f/2.8 aperture.
Sounds too good to be true? Well, don't believe me. Have a look at what PhotoZone and LensTip say.
My Pros:
  • Sharp. Bitingly sharp. And did I say it was sharp?
  • Mechanically sound.
  • Good flare resistance.
  • Nice saturated colours. At least part of it comes from the good flare resistance.
  • Surprisingly good bokeh if you shoot nearby subjects with fully open aperture. Of course bokeh isn't the reason to buy a super wide, but it doesn't hurt either, does it?
  • A joy to use.
  • No chromatic aberration. None. Zero.
My Cons (there always has to be some...):
  • The lens is fully manual. You focus yourself, you set aperture yourself. However, with a 14 mm lens and its native depth of field, manually focusing really is easy.
  • The lens has complex moustache distortion, and a lot of it. Not often problematic with nature, but worse with architecture. This can of course be corrected with software. And, actually, because it is moustache distortion (edges less distorted than areas closer to the center), minimal amounts of focal length is lost when correcting for it. As everything in lens design is a compromise, my guess is that the engineers designing the Samyang decided to let the lens have lots of distortion to get both sharpness and good chromatic aberration. In my opinion that was a great compromise.
  • The distance scale is way off on many copies. If you cannot select your copy, this is something you just have to live with. So learn that e.g. 3 meters actually means infinity. I'm not too happy about this, but I'd rather take this fault than bad IQ.
So, there you are. I know I didn't directly answer the question you made, but thought you might still be interested.
I'll end this message with two, no, make it three quotes.
PhotoZone: Well, we were stunned by the results in this category and I reckon you will join us once you've had a look at the charts below. The Samyang produced nothing short of outstanding resolution figures for a lens in this class. [...] I reckon that you will not believe us so please have a look at our field image section.
LensTip: Honestly, I’ve never expected I might sing the praises of a low-end lens produced in Korea. As you see, though, an excellent image quality is not just a privilege of expensive devices produced in Japan or Germany.
LensTop: It’s enough to say that it definitely surpasses in image sharpness the expensive, professional Nikkor 14-24 mm f/2.8 set at 14 mm and also it corrects most of optical aberrations better than that lens.
Kind regards,
- Henrik
And if a million more agree there ain't no great society
 Henrik Herranen's gear list:Henrik Herranen's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 135mm F2L USM Canon EF 100mm f/2.8 Macro USM +7 more
OP vvv14 Forum Member • Posts: 56
I just had a look at lensrentals.com. The short descriptions don't reveal that much. In Sigma's case, I know from other reviews (i.e. lenstip.com) what he means by "improvement with some tradeoffs" over mk1. Corner softness seems to be an issue for all reviewers. His take on Canon is also in line with other reviews: good lens but nothing special.
Re: What's wrong with the Canon 17-40?
BAK,
There's nothing wrong with 17-40: it's an excellent lens for its price. It's just that i'm looking for something better. I know 16-35 is better and I'm trying to find out if Sigma comes close to it or if the extra 4mm at the wide end are worth the other shortcomings. You might say that if it's quality i'm looking for, I should got for 17TS or a Zeiss, but those are out of my price range.
Re: How about the Samyang 14/2.8?
Hi Henrick,
I am aware of Samyang’s 14mm and I read extensively about it. I agree that it’s rare example of a brilliant lens when you consider the price/quality. I didn’t go for it because of my limitations rather those of the lens. I’m not always great at framing, so beside cropping, being able to zoom is a help.  For the same reason I refused a used Canon 14mm mk2 at just under 1000 euros, which is cheap.
In terms of budgeting for a wide lens, I am willing to spend as much as a new Canon 16-35mk2, but no more. What I don’t want to do, is spend that money knowing that there is something better (or close) out there, not to mention cheaper. If I think about it, I could get the Sigma and the Samyang for the price of the Canon and still save more than 100 euros. Sigma would have to be very bad to justify the extra premium for Canon. None of the reviews suggest that.
Robert Sheldon Senior Member • Posts: 2,272
vvv14 wrote:
BAK,
I have the Canon 17-40.   I use it for scenics and covered bridge photographs.  At f/13-16 I can see nothing wrong with its sharpness.  From all the reviews I read the 16-35 is better at f/2.8 but by the time you stop down to f/8 it is very hard to tell the difference.
Bob Sheldon
Photo Gallery at
www.bobsheldon.com
Cheers!
I own both the Canon 17-40 and the Sigma 12-24 Mk II.  When I need a wider lens than the Canon (quite often when photographing covered bridges) I use the Sigma.   Stopped down the softness in the corners is gone.  To correct for distortion I use PTlens and never have had any significant loss of the image.  Now, perspective distortion is an other story on loss of image space but that is what you have to work with all UWA lenses, including primes.
Bob Sheldon
Photo Gallery at
www.bobsheldon.com
mu55 Senior Member • Posts: 1,423
I have the first version of the 12-24sigma and LOVE it - version 2 is meant to be better, i highly recommend the extra 4mm, it's a HUGE difference. I shoot 95% of my realestate and architectural shots on this lens.
thats assuming you don't need F2.8 and don't plan on using it to shoot events (where the 35mm end might be useful)
there isn't much distortion on my 12-24 but i know the new one has alittle bit more - the 16-35L has more i think, you won't lose much correcting it
The Samyang has alot of distortion, but i am considering it just for weddings, wish it was half the size for that though...
So i say go the Sigma
 mu55's gear list:mu55's gear list
Canon G1 X III Ricoh GR III Sony a7R IV Canon EOS R5 Canon EOS R7 +19 more
CameraCarl Veteran Member • Posts: 9,204
I read someplace, maybe Popular Photography, that their tests revealed the first generation to be a bit better than the version II, so if you can find a good used one, this might be your most affordable option for a zoom.
Robert, thanks for your reply.
Am I correct to assume you acquired the Canon prior to Sigma? You plan on keeping both?
Does this mean that you prefer Canon at 17mm and over?
Can you roughly quantify the loss on image space in any way or is it more like a "case by case" scenario (i.e. shoot at 12mm and after distortion correction looks like it was shoot 14mm)?
snapperZ
snapperZ Contributing Member • Posts: 873
The Mk II Sigma is a bit sharper and contrastier, most noticeably in the corners/at the edges but at the expense of much more distortion.
I have the old Sigma 12-24 and to me it is bizarre to rule out the 17-40L on IQ grounds and then consider the Sigma which is demonstrably worse (Its principal and possibly only redeeming faeture in comparison with the Canon is it's really extreme field of view).
There are plenty of landscape professionals using the 17-40L (and the 24-105L for that matter). If you've dismissed primes on grounds of your inexperience I dont think the 17-40L stopped down holds anything to fear even if the 16-35II is modestly better in the extreme corners at f11.
 snapperZ's gear list:snapperZ's gear list
Canon EOS Rebel SL1 Canon EOS 5D Mark IV Canon EOS R5 Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM +29 more
vvv14 wrote:
Hi Henrick,
Fair enough. If you definitely want a zoom, then a prime - even an excellent one - just won't cut it.
Kind regards,
- Henrik
GtoJon
GtoJon Veteran Member • Posts: 3,553
I had a good 17-40mm lens ..... but the Sigma 12-42mm II lens is a fantastic lens! A lot better that any 17-40mm lenses I have had (4 of them). Even the version 1 12-24mm lens is better Lately after getting a 17mm TS-E lens, I considered the 16-35mm II lens. I found that normally it is good until 19-21mm & nothing told me it was really better in any way that my 17 TS-E lens or even my previous Sigma 12-24mm II lens. The 16-35mm is fasterm but from what I saw from my 12-24mm II lens, it's not that much better. .....I have tried 5 times to insert a sample & it won't work ..... I do this all the time Will try & rely with a sample ....oney & quality wise, you can't go wrong with the Sigma 12-24mm II lens
..... Still can't insert an image   I DO THIS ALL THE TIME  .... DP is lacking in this area lately
Cheers
www.JonSmithers.com GtoJon -
Taken any photographs lately?
http://www.jonsmithers.com/postedimages/EagleTeal-Zoo.jpg
 GtoJon's gear list:GtoJon's gear list
Sigma 120-300mm F2.8 EX DG OS HSM Canon EF 24-105mm f/4L IS USM Sigma 12-24mm F4.5-5.6 II DG HSM Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
GtoJon
Had 4 17-40mm L lenses & the Sigma 12-24mm I & II ..... the version 2 is better in every way except distortion is only slightly worse.  The 17-40mm L is not that great!!!  I now have the 17mm TS-E lens & if I were to replace it .... it would be the Sigma 12-24mm II lens!
Cheers
GtoJon
12-24mm II sample
Here is the sample I tried earlier ....
Dan_168 Forum Pro • Posts: 11,055
Here's a few old pictures from the 12-24 II.
I shoot with primes most of the time these days and used to own the 17-40L and 16-35L, also shot with the Sigma 12-24 II a little bit, never really like any of them that much, here is a few old ones I found still on my album.
And here is a few more from different camera/lens combo, just for fun, one from 5D2+ TSE 17, second one from 1DS MK II + Zeiss 21. if you "have to get the 12-24, please get the Versin 2, it's much better in edge sharpness, the version is pretty horrible even on my 1D2 when I tried many years ago, but the version 2 has worse distortion though if you care about it. Also look into the Samyang 14, I like a lot, very sharp edge to edge, but has more distortion, which doesn't bother me for my landscape shooting, another option would be the Nikon 14-24, I love that lens and shoot a lot with it when I don't want to carry bag full of TSE and Zeiss, it can be use on my Nikon body and also on a Canon body with adapter, it's one of my "universal" landscape lens. it's day and night better than the 16-35L II.
jrarsenault Senior Member • Posts: 1,151
I too own both the Canon 17-40 and Sigma 12-24.  I had the Canon for about 2 years and decided to get the Sigma 12-24 II last summer because I enjoy architectural photos and wanted something wider. I find that the Sigma 12-24 is significantly wider and a joy to use.
In reference to your last question with respect to 'space', I am assuming that you are asking about how much of the photo is lost when distortion is corrected. This really depends on the angle your camera is relative to the surface of the earth. If you are pointing your camera completely parallel to the earth, then distortion is next to nothing. However, the more angled your shot, the more distortion is created. Of course, the more distortion means that the more space will be lost in your photo.
I have provided two photos taken about 1-1/2 years ago when I was testing the 12-24 Type I lens. It was a rental but built like a brick. The quality of Type II is equally good although they have removed the "EX" designation which means that there is less warranty coverage. I think that it went from 10 years of warranty coverage with the Type I which has the "EX" designation to 5 years with the Type II lens without the "EX" designation. I find this very strange but warranty coverage will vary from region to region. Make sure that you check for your region.
You can see from the two examples below that the distortion correction caused a small amount of 'lost' space. This is primarily because my shot was slightly angled.
Sigma 12-24 Type I - With Distortion
Sigma 12-24 Type I - Distortion Corrected
Here's one from the Samyang 14
